There are no low cost/power TCAS, and as far as I understand there will
never be. You may refer to TPAS, which are indeed low cost/power but they are a far cry from TCAS or FLARM, as they only tell you that there is an aircraft somewhere nearby (if it has a transponder which is beeing interrogated) , no direction or resolution, and they don't determine if it is actually a threat or not. However they are much better then nothing, and deffinitly worth the $500. The ultimate solution would be the ADSB, which, AFAIK, has similar functionality to FLARM but also act as conventional transponders so covering both worlds. But it may take long time until the FAA will implement it, and meanwhile there will likely be more midairs fatalities, so the FLARM sounds like the current best solution. The good news is that the FLARM is effordable, can be used as a data logger (hopfully it will be certified as well) and does not require much instalation. Since powered aircrafts will not likely use it, it will be good idea to have both a TPAS and a FLARM. They both small and I bet they can be fit together on the glare shield without noticable obstruction. Ramy (who never really saw a FLARM or an ADSB, but stayed at the Holliday Inn Express ;-) Mike Schumann wrote: My question is whether introducing another technology that isn't common with powered aircraft is the answer. I would think that a combination of a transponder that is visible by ATC and conventional TCAS, along with a low cost low/power TCAS type device designed for gliders wouldn't be more appropriate for the US environment. Mike Schumann "Ramy" wrote in message ps.com... I don't have any numbers but I heard of many more midairs between two gliders or gliders with tow planes than between gliders and other powered aircrafts. I'm afraid the White Mountains in Nevada are a midair waiting to happen. On a good weekend you can have 20-50 gliders flying in a very narrow band in both directions. It is very difficult, almost impossible, to spot on time a glider flying straight and level at closing speeds of over 200 knots, unless you know exactly when and where to look. Remember, the moving targets we often spot easily are not the threat, it is the one which don't move on the canopy which will hit us. If we equip all gliders and tow planes with Flarm you will significantly reduce midairs, as it has been proved in Europe and OZ. One would wish that one of the local US manufactures of glider avionics or an entrepreneur would have try to license flarm in US. If it is possible to manufacture and sell TPAS like equipments in the US without liability concerns, it should be possible to sell Flarms. Just my humble opinion, Ramy Mike Schumann wrote: Another interesting question for the US is what percentage of mid-airs are between two gliders vs. between a glider and a powered aircraft. Mike Schumann "John Galloway" wrote in message ... Does anyone know of a source of any statistics that might indicate the effectiveness or otherwise of FLARM in reducing the rate collisions between FLARM fitted gliders in those European countries in which it is in widespread use? Thanks in advance. John Galloway |
You may well be correct. Does such equipment exist? If not, when is it
likely to be available? Meanwhile, Flarm does exist, has sold some 5,000 units worldwide, is known to work, and in some environments is fitted 100%, in quite a few 90% Flarm is sufficiently low priced, small, low powered and easy to install that if it becomes obsolete in say 5 years time it is still a very sensible fit today. I have never flown in the USA. If I were flying out of Minden I rather think I would like to have a transponder. This was advocated by Gordon Boettger in an article dated 13th July http://www.mindensoaringclub.com/int...=87&Itemi d=1 written of course before the mid-air of 28th August. In the UK I want Flarm provided enough other people fit it. I should think that in the USA anyone flying the White Mountains would welcome it. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Mike Schumann" wrote in message news ![]() My question is whether introducing another technology that isn't common with powered aircraft is the answer. I would think that a combination of a transponder that is visible by ATC and conventional TCAS, along with a low cost low/power TCAS type device designed for gliders wouldn't be more appropriate for the US environment. Mike Schumann "Ramy" wrote in message ps.com... I don't have any numbers but I heard of many more midairs between two gliders or gliders with tow planes than between gliders and other powered aircrafts. I'm afraid the White Mountains in Nevada are a midair waiting to happen. On a good weekend you can have 20-50 gliders flying in a very narrow band in both directions. It is very difficult, almost impossible, to spot on time a glider flying straight and level at closing speeds of over 200 knots, unless you know exactly when and where to look. Remember, the moving targets we often spot easily are not the threat, it is the one which don't move on the canopy which will hit us. If we equip all gliders and tow planes with Flarm you will significantly reduce midairs, as it has been proved in Europe and OZ. One would wish that one of the local US manufactures of glider avionics or an entrepreneur would have try to license flarm in US. If it is possible to manufacture and sell TPAS like equipments in the US without liability concerns, it should be possible to sell Flarms. Just my humble opinion, Ramy Mike Schumann wrote: Another interesting question for the US is what percentage of mid-airs are between two gliders vs. between a glider and a powered aircraft. Mike Schumann "John Galloway" wrote in message ... Does anyone know of a source of any statistics that might indicate the effectiveness or otherwise of FLARM in reducing the rate collisions between FLARM fitted gliders in those European countries in which it is in widespread use? Thanks in advance. John Galloway |
I don't know what the right answer is. Here in the US, there is a lot more
power traffic than in Europe. Unless you are flying in contests or in high glider traffic areas, I suspect that the biggest risk is not other gliders, but power traffic. It's very frustrating that the FAA doesn't accelerate the deployment of ADSB here in the US. Then everyone could focus on developing cost effective technology that will cover all traffic. In the mean time, the best investment might be a ballistic recovery chute. Mike Schumann "W.J. (Bill) Dean (U.K.)." wrote in message ... You may well be correct. Does such equipment exist? If not, when is it likely to be available? Meanwhile, Flarm does exist, has sold some 5,000 units worldwide, is known to work, and in some environments is fitted 100%, in quite a few 90% Flarm is sufficiently low priced, small, low powered and easy to install that if it becomes obsolete in say 5 years time it is still a very sensible fit today. I have never flown in the USA. If I were flying out of Minden I rather think I would like to have a transponder. This was advocated by Gordon Boettger in an article dated 13th July http://www.mindensoaringclub.com/int...=87&Itemi d=1 written of course before the mid-air of 28th August. In the UK I want Flarm provided enough other people fit it. I should think that in the USA anyone flying the White Mountains would welcome it. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Mike Schumann" wrote in message news ![]() My question is whether introducing another technology that isn't common with powered aircraft is the answer. I would think that a combination of a transponder that is visible by ATC and conventional TCAS, along with a low cost low/power TCAS type device designed for gliders wouldn't be more appropriate for the US environment. Mike Schumann "Ramy" wrote in message ps.com... I don't have any numbers but I heard of many more midairs between two gliders or gliders with tow planes than between gliders and other powered aircrafts. I'm afraid the White Mountains in Nevada are a midair waiting to happen. On a good weekend you can have 20-50 gliders flying in a very narrow band in both directions. It is very difficult, almost impossible, to spot on time a glider flying straight and level at closing speeds of over 200 knots, unless you know exactly when and where to look. Remember, the moving targets we often spot easily are not the threat, it is the one which don't move on the canopy which will hit us. If we equip all gliders and tow planes with Flarm you will significantly reduce midairs, as it has been proved in Europe and OZ. One would wish that one of the local US manufactures of glider avionics or an entrepreneur would have try to license flarm in US. If it is possible to manufacture and sell TPAS like equipments in the US without liability concerns, it should be possible to sell Flarms. Just my humble opinion, Ramy Mike Schumann wrote: Another interesting question for the US is what percentage of mid-airs are between two gliders vs. between a glider and a powered aircraft. Mike Schumann "John Galloway" wrote in message ... Does anyone know of a source of any statistics that might indicate the effectiveness or otherwise of FLARM in reducing the rate collisions between FLARM fitted gliders in those European countries in which it is in widespread use? Thanks in advance. John Galloway |
Hi,
My question is whether introducing another technology that isn't common with powered aircraft is the answer. My answer is no. I doubt there is _the_ answer, anyway. "See and avoid" most obviously isn't. For the time being FLARM is small, uses next to no power, minimal panel space, does not distract the pilot and is comparatively affordable. In my environment it warns me of almost all the gliders I am likely to encounter and the towplane. I cannot see a reason why _not_ to use it. Not using it because it does not solve the problem of potential mid-airs by 100% does not seem reasonable to me. For people flying in the alps there is the added benefit of FLARM warning of cables spanning valleys (IF they are in the database). These, I am told, are mostly invisible from the air against the ground. No transponder can help you there and fleet coverage is not an issue. Ciao, MM -- Marian Aldenhövel, Rosenhain 23, 53123 Bonn http://www.marian-aldenhoevel.de "Success is the happy feeling you get between the time you do something and the time you tell a woman what you did." |
Ramy wrote:
One would wish that one of the local US manufactures of glider avionics or an entrepreneur would have try to license flarm in US. If it is possible to manufacture and sell TPAS like equipments in the US without liability concerns, it should be possible to sell Flarms. This is my belief, also, and perhaps the TPAS manufacturers are the ones to approach about this. They might be able to convince the FLARM folk that they could manufacture and sell the units without any liability for FLARM, or develop one their own. A unit for North America wouldn't need to be compatible with units in other countries. I think the biggest problem is disinterest in the US community. In preparation for a presentation on FLARM at the 2005 SSA convention, I contacted a number of pilots about potential interest in it. I thought the Minden pilots would be very excited about it because of the White Mountains issues, but there was almost no interest in it. I was stunned. I now think the potential for collision with another glider is widely perceived (rightly or wrongly) as so low, it's not worth the effort or cost to use something like FLARM. One way to reduce the cost would be a FLARM with an IGC secure recorder, so the additional cost of the FLARM capability is, say, less than $200 (I don't know if that is possible). Still, since so many pilots already have a secure recorder, it might take years for a significant number to be in use. Perhaps a simpler, cheaper, "proximity" alert unit would be more acceptable in North America. It wouldn't be completely passive, but would broadcast a periodic weak signal with an ID code that can be detected a mile or two away. It would receive signals from other units and estimate their distance by the signal strength (no GPS). TPAS manufacturers could easily convert their current designs (like the Zaon MRX) just by fitting a different RF "front end". The box, power supply, displays, logic, etc would remain the same. This would make it much cheaper for them to develop and manufacture than a FLARM style unit. It wouldn't be as effective as a FLARM, but if it were available for less than $500, there might be a market for it. The Zaon MRX unit, for example, already has an altimeter function in it, so the altitude could be broadcast along with the ID code, allowing display of the relative altitudes of the two gliders. In the ideal world, this detection capability would be an "add-on" to a company's standard TPAS unit, allowing detection of transponder equipped aircraft AND aircraft with just the dual TPAS. It just occurred to me the reason the TPAS unit manufacturers don't seem to have a liability issue is their units only alert based on proximity, and not on predicted flight path. If this is true, perhaps a modified FLARM could be sold in North America by FLARM folks or a licensed dealer/manufacturer. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
![]() Eric Greenwell wrote: I think the biggest problem is disinterest in the US community. In preparation for a presentation on FLARM at the 2005 SSA convention, I contacted a number of pilots about potential interest in it. I thought the Minden pilots would be very excited about it because of the White Mountains issues, but there was almost no interest in it. I was stunned. I think you would get a very different reaction now, that it's been discovered that the sky is not that big after all, not even on a weekday over Minden nor over the remote Amazonas rainforest. I'll be the first one in line to replace my volkslogger with a flarm. The cost should be minimal. Ramy |
![]() "Ramy" wrote in message oups.com... I think you would get a very different reaction now, that it's been discovered that the sky is not that big after all, not even on a weekday over Minden nor over the remote Amazonas rainforest. I'll be the first one in line to replace my volkslogger with a flarm. The cost should be minimal. Ramy Ramy, I'm not so sure. Mid-air awareness has probably risen some. However, the Minden incident would not have been averted by Flarm, nor would the SA mid-air between two jets. And because of the far flung "wide open spaces" in the US, there are but few places, such as the Whites in NV, where glider density comes close to the Alps (though I've not been there). To make something universally acceptable in the US, if it only works between gliders it'll have to be cheap and small. Such a device would be much better received if it warns of both power and glider threats. The bigger catastrophic risk at Minden is that an airliner and glider will try to occupy the same airspace. Many of us worry about that and transponders seem the best answer for now. -- bumper ZZ (reverse all after @) "Dare to be different . . . circle in sink." Quiet Vent kit & MKII yaw string |
Thanks for all these replies.
Below is a message I got from Swiss FLARM today: ========================================== 'Unfortunately it is impossible to do a correct (and honest) statistic since there are simply too little datapoints. However, we can say that to the best of our knowledge there have been no collisions with fatal outcomes between Flarm equipped aircraft or between Flarm equipped aircraft and obstacles. But, there have been multiple collisions with fatalities this summer (French Alps) between aircraft that did not carry Flarm. Currently more than 5000 Flarm devices are in use worldwide. No pilot has ever returned a (non defective) device because he was not satisfied with it. We are in the process of getting to know the UK situation, but expect to become more visible and vocal within days/weeks.' ========================================== If, as we are told, only 10% of the gliders in the Alps are FLARM free and they have had all the mid-air fatalities then it is quite a significant finding, albeit short term. It was interesting to read on the board about the collision in a thermal between two Swiss FLARM equipped gliders who already knew of each other's presence. It just goes to show that no matter whether a glider is spotted by eyeball or FLARM you still have to avoid it. I presume that was not a fatality. I think that European clubs are fitting FLARMS in the tugs because it is mentioned in some off-board messages I have received. Apparently early on it gave false alarms on tow but that this now has been addressed in the updates. Thanks, John Galloway |
![]() John Galloway schrieb: ... It was interesting to read on the board about the collision in a thermal between two Swiss FLARM equipped gliders who already knew of each other's presence. It just goes to show that no matter whether a glider is spotted by eyeball or FLARM you still have to avoid it. Exactly. FLARM does not avoid collisions. It helps finding the "opponent" before it's too late. I presume that was not a fatality. Yes. One landed the damaged glider, the other one bailed out. I think that European clubs are fitting FLARMS in the tugs because it is mentioned in some off-board messages I have received. Apparently early on it gave false alarms on tow but that this now has been addressed in the updates. Also correct. Regards Marcl Duenner |
All this talk about FLARM and other alternatives to
a transponder in the USA is just so much wasted energy. The fact is that transponders are the established aircraft identification system in the USA and all anti-collision systems in the USA work off of this system. The USA is a very different environment than flying in the Alps. I have flown in the Alps and there you have several hundred gliders slope soaring and flying around cliffs, valleys, buttes, and mountains in very low ceilings. You will be flying the face of Pic de Burre and round a corner to have three gliders flying formation at your altitude coming straight at you. Power traffic is a non issue. Here in the USA it is probably more likely to have conflict with power traffic. Transponders are relatively affordable, use relatively little power, fit easily in a panel, and work. For most glider pilots in the USA who never fly above 10,000 feet and are in the country this is a fantasy situation. But for those of us in California, the Denver area, most of Florida, Dallas and Chicago, we share the air with heavies and I think we should step up to the bar and be full participants in the air traffic system. Guy |
Glider Crash - Minden? | Mitch | Soaring | 141 | September 13th 06 07:31 PM |
FLARM | Robert Hart | Soaring | 50 | March 16th 06 11:20 PM |
Flarm | Mal | Soaring | 4 | October 19th 05 08:44 AM |
Pilot statistics: SSA vs non-SSA | DrJack | Soaring | 6 | March 10th 04 05:55 PM |
Safety statistics | F.L. Whiteley | Soaring | 20 | September 4th 03 05:50 PM |
