Pilot deviations and a new FAA reality
Old October 10th 04, 02:47 AM
Chip Jones
"Matt Whiting" wrote in message
Chip Jones wrote:
Folks, I see at *least* one pilot deviation a week working traffic in my
small slice of the NAS. I don't report them unless separation is lost,
because I was trained under the "no harm, no foul" mentality. Pilots
help
controllers, controllers help pilots, and the NAS ticks along like an
old
clock. I'm not changing the way I do business, but I wanted you to know
that other controllers might, in order to cover themsleves against
antagonistic Management.
No offense, Chip, but runway incursions are a pretty serious deviation.
I'm not sure I can fault the Feds for wanting these reported given
some of the past fatal accidents caused by them.
Matt, no offense taken. I agree with you that runway incursions are a
pretty serious deviation, but where do you draw the line for a "pretty
serious" pilot deviation? It is my opinion that the controller working the
situation, the person who issued the ignored hold short instruction, is the
Fed on the scene. Not the tower chief coming in on the scene a few days
later, If the person issuing ATC clearances sees no harm, no foul and
gives the crew a pass, why not leave it there? No loss of separation
occurred in this event. In FAA speak, "Safety was never compromised." No
harm done. Why crucify the controller for not crucifying the pilot and
crew?
And if you go after the controller for not narcing on the flight crew in
this case, then you have to go after every controller in every case of every
observed but unreported pilot deviation. To me, such a policy is
counter-productive to air safety because it builds an adversarial
relationship between ATC and pilots. After all, the controller got a paper
slap on the wrist compared to the likely loss of pay and possible loss of
employment for the captain and FO of the airliner in question. I prefer "no
harm, no foul" unless actual harm was committed.
Chip, ZTL
Old October 10th 04, 03:36 AM
Steven P. McNicoll
news:tEW9d.211481$MQ5.87982@attbi_s52...
What Chip's talking about is basically removing some of that
discretionary
power from controllers. Now, perhaps when management gets deluged with
reports of 50' altitude deviations and other trivial mistakes, they'll
simply start punting things too, so the "no harm, no foul" policy just
gets
shifted to a new desk. But in the meantime the volume of trees
slaughtered
will increase, and with it the hours spent on pointless paperwork for
everybody. Safety will probably not benefit.
Hm, I assumed that it's not a deviation if the pilot is within PTS
standards; hence, being off by 50' in cruise wouldn't count.
Being off by 50' in cruise wouldn't be noticed.
Old October 10th 04, 06:04 AM
C Kingsbury
news:ze1ad.13857
OK, to be precise, 100'+/- is OK, and encoders click over at 51', right? So
you'd have to be 151' off for it to show as outside tolerance. Fly over some
building cumulus in a 172 sometime- that can left your skirts 100' before
you know it. Better have that altitude nailed or you've violated your
clearance.
-cwk.
Old October 10th 04, 01:15 PM
Steven P. McNicoll
"C Kingsbury" wrote in message
link.net...
So
some
clearance.
Call ATC with a PIREP on the turbulence.
Old October 10th 04, 02:11 PM
Kyler Laird
"C Kingsbury" writes:
Because mode c transponders only report altitude in even hundreds,
that isn't very likely.
OK, 51' then.
Plus the maximum allowed deviation for the encoder at your altitude. I
forget the table but I recall it being quite significant above 14,000'.
(I got a transponder check letter when mine wasn't making good contact
with my encoder.)
I will abort this line of argument if someone can show me that there is a
real safety issue here backed by something more than a gut instinct.
I'd like to think we'd all change our assumptions given sufficient
evidence to the contrary.
--kyler
Old October 10th 04, 02:32 PM
Matt Whiting
help
old
crew?
Chip, ZTL
If it was close enough to require a go-around, that seems close enough
to me to warrant a report. If nobody else was within 10 miles of the
airport, then I might feel differently.
Matt
Old October 10th 04, 02:33 PM
Matt Whiting
news:ze1ad.13857
clearance.
-cwk.
Last I knew, you had 300' of tolerance before a violation was a concern.
Has this changed recently?
Matt
Old October 10th 04, 02:37 PM
Stan Prevost
"Chip Jones" wrote in message
link.net...
OK pilots, try this one on for size. As you likely know, there is a wide
and growing rift between the career FAA bureaucrats (aka FAA Management)
who
run the monstrosity called the federal Air Traffic Organization, and the
career FAA air traffic controllers who make that monstrosity work in the
NAS
on a daily basis. Regardless of where you stand on the politics of US air
traffic control (funding, privatization, user-fees, labor issues,
whatever),
the ugly, on-going feud between Management and Labor in air traffic
control
may finally have reached a point where you as a pilot will be personally
affected.
Chip, increased emphasis on reporting of pilot deviations seems to lead to a
need for increased pilot understanding of what constitutes a deviation from
an ATC point of view. I doubt that controllers are required to know the
FARs to the depth required to determine if a pilot is operating within the
regulations that apply to pilots in all cases, so a large part of it would
seem to fall back on reporting deviations from an ATC instruction or
clearance. So what constitutes a deviation? As an example, what deviation
in altitude constitutes a reportable deviation, if no loss of separation
occurs? It has been suggested in this thread that the Instrument PTS
standard of +/- 100 ft applies, but I doubt if controllers are familiar with
the PTS. So is there an ATC document that defines deviation limits? How
far off the centerline of an airway can I be before being reported? How
much heading error? How long a delay is allowed before I begin a descent
after being instructed to do so? If I am VFR in Class E airspace, and using
flight following, will I be reported for flying WAFDOF? Should we expect a
report on every student pilot doing T&Gs and landing without clearance,
rather than being scolded for a one-time error, if no problem occured?
Looks like a big can of worms to me.
Sta
Old October 10th 04, 04:10 PM
Tom S.
link.net...
news:ze1ad.13857
So
some
clearance.
Hell, I remember vertical deviations of a lot more than that, with the VSI
being dam near pegged on the climb/descend scale in some sizeable twins,
during some turbulence.
I was on an Embrarer 55 out of Houston and heard the warning horn going off
in the cockpit during turbulence that I think got us zero gravity at a
couple of points.
Old October 10th 04, 04:11 PM
Tom S.
"Kyler Laird" wrote in message
Haven't been around Usenet very long, have 'ya? :~)
