I've had a 172M for 31 years, now with 1700 hrs TTSN that still makes
compression (which never never has been that great) and still gets over 25 hrs/qt. It has been preheated religiously, run on Shell 15W50, mostly autofuel, & mostly cruised at ~55% power. Oil analysis still shows low and declining ppm metal contamination. It has a full flow filter. Given your operating conditions, you shouldn't break anything from simple fatigue. You will eventually wear it out at some prolonged point, corrode it internally or damage it on a cold start. All these should give warning. But I don't think you can make 2X TBO. You should critically look for any signs of deterioration as you approach or exceed TBO. I assume you have a full flow filter. Given the quality problems the manufacturers seem to be having with recent OH components, I'd think it safe vs an unnecessary overhaul. Let me guess it is also an O-320 in a Cessna installation. I think Cessna has better cooling provisions than Piper or especially Grumman etc. |
| Thread Tools | |
| Display Modes | |
| Recommended source for 4130 sheet and tubing? | Michael Horowitz | Restoration | 3 | April 16th 06 08:23 PM |
| Anywhere recommended near Rochester MN? | Dave | General Aviation | 0 | April 8th 04 12:48 PM |
| Anywhere recommended near Rochester MN? | Dave | Aerobatics | 0 | April 7th 04 04:46 PM |
| Anywhere recommended near Rochester MN? | Dave | Aerobatics | 0 | April 1st 04 06:18 PM |
