The Cessna instructors are probably showing that the servos
can be over-powered with pilot muscle, no reason to lose control. But I'm sure they also teach the location of CWS, the trim switch, the red disconnect button and the A/P CB and avionics master. wrote in message ups.com... | | Robert M. Gary wrote: | | | However, it is very easy to hand fly the plane while the autopilot is | on. | -Robert | | Ouch. | | My old Skylane has a KAP-150. | | "Easily" over power the yoke/trim with the AP on? No. | | I have a nice big red circuit breaker handle on the trim breaker just | for this reason. | | Pre-start includes saying out-loud: "Run-away trim, pull red breaker." | | Fly an approach while overpowering the AP? | | Who are these Cessna instructors? | | They might want to RTFM, that's what CWS is for. | | Adam K. | |
On Tue, 10 Oct 2006 21:35:47 -0500, "Jim Macklin"
wrote: The Cessna instructors are probably showing that the servos can be over-powered with pilot muscle, no reason to lose control. But I'm sure they also teach the location of CWS, the trim switch, the red disconnect button and the A/P CB and avionics master. There's no CWS on the KAP140 install in the NAV3 equipped Cessna line. Probably on the Mustang when it comes out, but not the SEPs. It's been a few years so things might be different now, but IIRC, the class doesn't teach leaving things in NAV mode to fly procedure turns, but teaches doing a partial-panel approach by selecting wing-level and flying it that way. Personally with a working aircraft I always fly a procedure turn w/ autopilot by changing it to HDG mode, flying the procedure turn with the bug, and then re-arm APR on the inbound intercept. |
Peter Clark wrote:
.. There's no CWS on the KAP140 install in the NAV3 equipped Cessna line. Probably on the Mustang when it comes out, but not the SEPs. I've got CWS on my 55X. Frankly, I never use it. Personally with a working aircraft I always fly a procedure turn w/ autopilot by changing it to HDG mode, flying the procedure turn with the bug, and then re-arm APR on the inbound intercept. That's what works for me. On the 55X, you can HDG+NAV+APR at the same time and it holds the heading until the needle comes alive (if you just NAV+APR, it may make a more agressive turn towards the course). |
If the autopilot is over=powered the auto-trim will run to
try to get control forces back in the acceptable range. This will place the airplane seriously out of trim. A pilot can over-power the autopilot, but if this is done it should be either as a demonstration during checkout or in response to an autopilot actuator run-away. The pilot should maintain attitude control, over-powering the autopilot while they 1 push the disconnect button 2 pull the circuit breaker 3 manually retrim 4 land ASAP -- James H. Macklin ATP,CFI,A&P "Robert M. Gary" wrote in message oups.com... | | Mxsmanic wrote: | In simulation, if I set the autopilot to maintain the altitude, and | then try to change pitch with the controls, the control surfaces | barely move, and I can hardly have any effect on pitch. | | I think this is a limitation of the simulator. My guess is that, in | real life, the autopilot continuously adjusts trim, and so, if you try | to change pitch with the yoke, the A/P retrims to cancel out your | efforts, and the net effect is that you can change pitch, but you must | exert very high control pressures to do it (in order to overcome the | trim that the A/P is applying to neutralize your efforts). | | Is this correct? I can see why this is difficult to simulate with | controls that don't provide feedback, but I want to make sure that I | understand the difference between the sim's way of doing it and the | real thing. | | It takes pretty minimual control to over power the autopilot. However, | if you disrupt it a great deal (make a big pitch change for instance) | the autopilot may overcorrect a few times before settling back to the | correct pitch. The ability to return to the correct pitch with minimal | over correcting is a function of the quality of the autopilot. | Sometimes when you make changes such as lowering flaps you need to | "help" the autopilot but holding the yoke in the right place for a bit | until the autopilot figures out what is going on. This even with the | more expensive autopilots (like the new KAP140). | | However, it is very easy to hand fly the plane while the autopilot is | on. The Cessna training instructors told us that they routinely hand | fly procedure holds on approach w/o changing the mode on the autopilot, | just over powering it. | In my plane I'll hand fly through turb but I'll leave the autopilot on | because it gives me a nudge back to course (i.e. I can feel it trying | to pull me back on course). If I take my hands off during turb though | it will make the turb worse. | | | -Robert | |
Mxsmanic wrote:
In simulation, if I set the autopilot to maintain the altitude, and then try to change pitch with the controls, the control surfaces barely move, and I can hardly have any effect on pitch. There's a big difference between airline control movement and it's relationship to trim than light aircraft. I'll restrict our talk to light aircraft. I think this is a limitation of the simulator. My guess is that, in real life, the autopilot continuously adjusts trim, and so, if you try to change pitch with the yoke, the A/P retrims to cancel out your efforts, and the net effect is that you can change pitch, but you must exert very high control pressures to do it (in order to overcome the trim that the A/P is applying to neutralize your efforts). My autopilot has both pitch servos and trim. You push on the yoke it has the same impact that it would if the autopilot wasn't there. However, what the autopilot does endeavor to do is adjust the trim so that it's always "trimmed" which means it may try to trim away your force (if you are pitching it away from where it thinks it should be). The autopilot does this so that if you kick off the autopilot it's giving you a plane that is in trim. |
![]() Ron Natalie wrote: My autopilot has both pitch servos and trim. You push on the yoke it has the same impact that it would if the autopilot wasn't there. However, what the autopilot does endeavor to do is adjust the trim so that it's always "trimmed" which means it may try to trim away your force (if you are pitching it away from where it thinks it should be). The autopilot does this so that if you kick off the autopilot it's giving you a plane that is in trim. Some autopilots don't have trim servos and have "up" and "down"lights on the autopilot display asking the pilot to retrim. The autopilot normally flys a bit out of trim but anything outside the params results in a request of the pilot to trim. The purpose is just as you mentioned. You would be sad to find yourself in a nose down dive after disconnecting the autopilot. The autopilots that have "pitch control" (terminology used to denote that it does more than hold altitude, it holds VS) usually have trim control as well. The familiar "Trim, in motion" annunciator that seems to go off everytime I click the mic to call tower in the G1000 aircraft. ![]() -Robert |
Robert M. Gary writes:
The autopilots that have "pitch control" (terminology used to denote that it does more than hold altitude, it holds VS) usually have trim control as well. The familiar "Trim, in motion" annunciator that seems to go off everytime I click the mic to call tower in the G1000 aircraft. ![]() Doesn't trim make its own noise? I've read notes in voice recorder transcripts that mention "trim wheel moving at autopilot speed," although that is in large aircraft. I assume it must make quite a noise if this gets recorded. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Mxsmanic wrote: Robert M. Gary writes: The autopilots that have "pitch control" (terminology used to denote that it does more than hold altitude, it holds VS) usually have trim control as well. The familiar "Trim, in motion" annunciator that seems to go off everytime I click the mic to call tower in the G1000 aircraft. ![]() Doesn't trim make its own noise? I've read notes in voice recorder transcripts that mention "trim wheel moving at autopilot speed," although that is in large aircraft. I assume it must make quite a noise if this gets recorded. Its an annunciator just like any other. There is one annunciator that has multiple preprogrammed channels. I believe mine has 40 different things it can say, although few are hooked up. A signal goes down the wire to the annunciator and the voice speaks. Its not part of the autopilot or trim system itself. Mine often says "Check landing gear" just as I call up tower when on approach. Its a bit annoying. -Robert |
Mine often says "Check landing gear" just as I call up tower when on approach. Its a bit annoying. The simulated Baron I have says "Check gear!" constantly below certain throttle settings (I'm not exactly sure what sets it off, though). It's very irritating, but if it's in the sim, it must be doing that in real life as well. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Ron Natalie writes:
There's a big difference between airline control movement and it's relationship to trim than light aircraft. I'll restrict our talk to light aircraft. The 737-800 sim has a very fancy autopilot (like the real thing), and when you touch the controls, it switches to CWS pitch or roll mode. Unfortunately, I don't understand how that works yet (especially when it comes to getting the A/P to take over again), so I don't use it much. The A/P in the Baron seems straightforward enough. I note that if I set it to hold altitude only, it resists any change in heading as well; not sure if that is the sim or an accurate representation of real life (the A/P is marked KFC225, whatever that is). My autopilot has both pitch servos and trim. You push on the yoke it has the same impact that it would if the autopilot wasn't there. However, what the autopilot does endeavor to do is adjust the trim so that it's always "trimmed" which means it may try to trim away your force (if you are pitching it away from where it thinks it should be). The autopilot does this so that if you kick off the autopilot it's giving you a plane that is in trim. Do you feel more pressure in the controls as the A/P tries to trim away your pitch change? -- Transpose mxsmanic and gmail to reach me by e-mail. |
KAP140 autopilot and a KLN94 GPS question | STICKMONKE | Instrument Flight Rules | 5 | November 12th 05 04:06 AM |
FS: 1986 "Fighting Jets" Hardcover Edition Book | J.R. Sinclair | Aviation Marketplace | 0 | October 10th 04 11:27 AM |
FS: 1986 "Fighting Jets" Hardcover Edition Book | J.R. Sinclair | Aviation Marketplace | 3 | January 22nd 04 05:01 PM |
FS: 1986 "Fighting Jets" Hardcover Edition Book | Jim Sinclair | Military Aviation | 0 | September 8th 03 07:43 AM |
