Tow Signals
Old October 11th 06, 08:29 PM posted to rec.aviation.soaring
Marc Ramsey
Default Tow Signals
Ramy wrote:
There had been yet another fatality recently as a result of
misinterpreting the open spoilers signal. True we all passed the
written test and know that wiggeling the rudder means check spoilers
and rocking the wings means release, yet so many students and
experienced pilots alike continiue to confuse this signal and releasing
the tow rope instead, often resulting in accidents.
No, we did not all pass a written test that had wiggling the rudder
meaning "check spoilers". This signal is a fairly recent innovation,
and there were several US sites that taught until recent years that
wiggling the rudder was a signal for the recommended release point,
hence some of the confusion.
1 - If radio is available (and it always should) - use it instead of
the rudder signal!
There are plenty of places where some tow planes lack functioning
radios, including at least one that you visit.
2 - If this doesn't doesn't work, the signal should be avoided until
the glider is at least 200
feet, unless of course, the tow plane is in immediate danger.
I'd go a bit farther and say that if the tow plane is climbing and not
in danger, it would be preferable to make the signal over the airport at
above pattern altitude.
3 - If the glider pilot sees the tow plane signaling something (wigling
the rudder or rocking the wings)
the FIRST look at the spoilers, then release the tow rope if necessary.
In this case, the pilot will do the correct action regardless of the
signal. I think this is what needs to be taught.
No, rocking the wings means release right *now*, not after you look
around and consider what is wrong. If you hesitate, in many cases
you'll end up with the rope heading your way.
I am not an instructor myself, so this is just my humble opinion...
Likewise.
Marc
Old October 11th 06, 09:40 PM posted to rec.aviation.soaring
Ramy
Default Tow Signals
the rudder signal!
There is absolutly no excuse for this. The tow pilot can use a $200
handheld if the tow plane is not equiped with one.
Agree.
It takes less then a second to look at the spoiler, but if the
situation is so urgent then the tow pilot can release the rope himself,
it shouldn't make much difference. But how often an immediate release
is required vs open spoilers? I think the later is much more common,
and as such, it would be statistcally better to treat it as such.
Likewise.
Marc
Ramy
Old October 11th 06, 10:27 PM posted to rec.aviation.soaring
Marc Ramsey
Default Tow Signals
Ramy wrote:
the rudder signal!
I suggest you bring this up next time you visit someplace like Williams.
I'm sure the response will be rather amusing...
Old October 12th 06, 12:25 AM posted to rec.aviation.soaring
Phil Jeffery
Default Tow Signals
Do not expect any tug pilot with a normal life expectancy to use a hand-held
radio whilst anywhere near the ground especially with a reduced climb rate
due to deployed glider airbrakes. Ramy, obviously you don't fly powered
aircraft or you would know that one hand should be on the stick/control
column and the other ensuring the throttle stays full forward until reaching
a respectable altitude. If the tug pilot is wearing a head-set and there's
PTT on the stick by all means give a radio call but without these it can
only be the rudder wiggle.
"Ramy" wrote in message
the rudder signal!
Agree.
Likewise.
Marc
Ramy
Old October 12th 06, 12:49 AM posted to rec.aviation.soaring
Ramy
Default Tow Signals
Ok, Ok, I stand corrected. Still, no excuse for no panel radio in a tug
IMHO.
Ramy
the rudder signal!
Agree.
Likewise.
Marc
Ramy
Old October 12th 06, 01:31 AM posted to rec.aviation.soaring
Tony[_1_]
Default Tow Signals
well gee, dont ya think that maybe the answer to this is to actually
learn the signals? apparently the towpilot took the time to learn the
standard signals, the least the pilot could do is return the favor.
As a towpilot, if i see airbrakes are out, but we are still climbing,
im not going to give the signal until i know you can make it back to
the airport. Ive heard too many of these stories. If we arent
climbing and are low, you are on your own, goodbye. if we are high but
not climbing you get the signal and i hope you figure it out.
also, for me, the biggest danger below 200 feet or so is not the
throttle slipping back. it is that you didnt hook up your elevator
right or something silly like that. I dont feel like getting taken out
with you so once the throttle is full, engine gauges checked,
everything normal, my hand is near the release ready to let you go.
Occasionally i come back to the throttle to double check it is at full,
which it always is. As we get higher and i have more time to recover
from the upset you cause while programming your geewhizbang palm
thingymajob then i go back to the throttle and mixture more,
controlling CHTs and all that stuff.
IMHO.
Ramy
the rudder signal!
Agree.
Likewise.
Marc
Ramy
Old October 11th 06, 11:56 PM posted to rec.aviation.soaring
Ken Ward
Default Tow Signals
In article .com,
the tow rope instead, often resulting in accidents. It is not hard to
understand why: The tow plane barely climb, the glider pilot suspects
something must be wrong with the tow plane, then he/she sees the rudder
signal which confirms his thought that something is wrong, then
releases the tow rope in panic, since this is what we were taught to do
if something is wrong with the tow plane.
I think that there is a relatively simple solution for this:
the rudder signal!
Ramy
It might be that there was a spoiler malfunction. I think there was a
crash during a landing at Truckee where the spoilers on a G103 were
opened as a test, but then because of wear in the mechanism, they went
into a configuration where they couldn't be retracted.
There could have been a medical event, or a medical event combined with
an equipment malfunction, leaving a student to make a critical decision.
As usual, this is just speculation until an investigation is performed.
Still, I'm very sad to hear about Joe. He made a better pilot out of
me, when I was a student. For one thing, I learned to politely decline
if he offered me half of his pickle sandwich, which was his way of
rewarding good flying. Talk about spicy!!
Ken
Old October 12th 06, 02:23 AM posted to rec.aviation.soaring
Burt Compton - Marfa
Default Tow Signals
Us a pretakeoff checklist - just like you did once on your FAA
Checkride!
CBSIFTCBE works - or any checklist that includes "airbrakes (spoilers)
closed and locked."
Left hand in a fist - behind the airbrake handle may alert you that
airbrakes are creeping open. The free video from the Soaring SAfety
Foundation has a good segment on signals and checklists. Order from
www.soaringsafety.org
Our procedure at Marfa, TX USA (developed from the towpilot's point of
view):
Ground crew refuses to hook up towrope until pilot closes and locks
airbrakes.
IF glider pilot wishes to use airbrakes open on takeoff for better
aileron control with water ballast, then ground crew confirms the
towpilot is aware of this.
Glider pilot radios towpilot "canopy and airbrakes closed and locked".
Towpilot (just before takeoff) repeats back to glider pilot "understand
your canopy and airbrakes are closed and locked."
If you do not follow our procedures - we don't launch.
No one gets a tow without a "Marfa Aerotow Briefing". Casual or "know
it all" glider pilots are refused a tow unless our procedures are
completed.
Sorry but as your towpilot we gotta do it my way. This cat has used up
8 of my 9 lives over the past 39 years towing gliders. Many glider
pilots view the tow as a means to an end- "just get me up there" like a
ski lift operator. Do the checklists, follow the procedures, and
remember the "joy of soaring"starts after you release!
Burt CFIG / DPE
Marfa Gliders west Texas
www.flygliders.com
Old October 12th 06, 03:08 AM posted to rec.aviation.soaring
Ramy
Default Tow Signals
All good advises from Burt and Tony, but since we are all human, and
human makes human mistakes, wouldn't you all agree that an amendment to
the "wing rocking" signal to first check airbrakes and then release
could save lives? It can take 5-10 seconds before recognizing that the
tow plane is rocking the wings and not just hitting turbulance, which
is plenty of time to take a quick look at the spoiler. This will also
cover the case where the tow pilot gives the wrong signal by mistake,
I'm sure this has happened before.
Ramy
Checkride!
closed and locked."
view):
airbrakes.
completed.
Burt CFIG / DPE
www.flygliders.com
Old October 12th 06, 03:38 AM posted to rec.aviation.soaring
Tony[_1_]
Default Tow Signals
My sentiments seem to echo Burts because he taught me to tow.
the towpilot rocks the wings cause you need to get off now, not
because you need to fiddle with a couple handles, pick your nose, and
then get off.
you should be happy that your towpilot gives you the courtesy of
rocking the wings. If I in the towplane am experiencing an engine
problem, first thing is to pull the red handle.
Im not sure what kind of turbulence you are flying in, but the thermals
we have here will not come anywhere close to mimicking a wing rock. my
kind of wing rock is +/- 30 degrees of bank rapidly.
Ramy
Checkride!
closed and locked."
view):
airbrakes.
completed.
Burt CFIG / DPE
www.flygliders.com
"Signal jamming a factor in future wars, general says" Mike Military Aviation 23 August 24th 11 02:17 AM
Glider - Towplane Signals Mike the Strike Soaring 24 March 26th 05 09:33 PM
The wrong signals to send to young visitors. Larry Dighera Piloting 57 November 26th 03 07:05 AM
