Lidle, Langewiesche, and turns
Old October 17th 06, 10:02 AM posted to rec.aviation.misc
Ron Hardin
Default Lidle, Langewiesche, and turns
Don Tuite wrote:
You get additional horsepower from going downhill, letting you maintain
your speed.
Telegraphic as ever, Ron.
So, because I'm using the same throttle position as I was using in
level flight, I'm descending while in a turn and banked at A degrees.
The airplane seat is pushing on my butt at an angle A degrees from
vertical. That can be resolved into a vertical vector and a horizontal
vector aimed at the center of the circular path I'm describing.
Meanwhile the back of the seat is exerting another force on my butt
tangential to the circular path I'm describing in the horizontal, er,
"plane." That force is a reaction to the thrust of the prop.
If I "maintain my speed," I get the same lift I would have got from
adding enough throttle so as not to lose altitude. That means the
magnitude of the vertical component of the lift vector is still equal
to mg and my rate of descent is constant.
You were agreeing with me? (Never happened before.) Maintaining
vertical equilbrium depends on maintaining the same speed as in
straight and level flight, doesn't it?
There's no force on you from the back of the seat, unless you're also getting
a force from the wind in your face, say it's a powered hang glider. The
additional thrust on the airplane from its spiraling downward into gravity
is also a thrust on you yourself, so you don't feel it.
If you keep the turn coordinated, you're pointing the nose slightly down the
vertical to streamline into the downward spiral.
The additional horsepower lets the wings run fast enough at their angle of
attack to maintain the lift they need to hold the turn, where the engine alone
does not suffice.
Ron Hardin
On the internet, nobody knows you're a jerk.
Old October 17th 06, 01:41 PM posted to rec.aviation.misc
Ron Natalie
Ron Hardin wrote:
Losing altitude at a constant rate (rather than accelerating downward)
would be the same as maintaining a constant altitude, wouldn't it?
(Vectors on a free-body diagram and all that)
Don
your speed.
Power is a different issue than g-loading. Power has only
coincidental impact on stall speed (you do get a small gain
from the prop blast).
Old October 17th 06, 01:44 PM posted to rec.aviation.misc
Ron Hardin
Don
your speed.
Power has a significant impact on airplane speed, however.
Ron Hardin
Old October 17th 06, 02:12 PM posted to rec.aviation.misc
Ron Natalie
and on whether you are climbing or descending.
Old October 17th 06, 05:56 PM posted to rec.aviation.misc
Brian Whatcott
On Mon, 16 Oct 2006 23:22:40 GMT, Don Tuite
On Mon, 16 Oct 2006 22:41:58 GMT, Ron Hardin
Don Tuite wrote:
On 16 Oct 2006 13:28:37 -0700, "Snidely"
Blanche Cohen wrote:
Aircraft Turn Calculator
www.csgnetwork.com/aircraftturninfocalc.html
Interesting -- but doesn't speak to asltitude issues (loss of, or
adjustments to avoid loss of).
Don
your speed.
Don
I'll try this time:
altitude = potential energy.
Losing altitude means giving up potential energy.
Where does that energy go?
Into providing a greater (effective) angle of attack than
you could at constant altitude and airspeed and thrust
OR
providing more airspeed than you could at constant altitude
and AoA and thrust.
Untelegraphic enough?
Brian Whatcott Altus OK
Old October 17th 06, 07:32 PM posted to rec.aviation.misc
Don Tuite
On Tue, 17 Oct 2006 16:56:26 GMT, Brian Whatcott
I'll try this time:
OR
and AoA and thrust.
Yes. Energy conservation is always a good way to clarify things.
Over the years, I've played Menos' slave boy to Ron's Socrates several
times, but he usually requires that I show some effort before he moves
out of ultar-terse mode.
Don
Old October 18th 06, 03:10 AM posted to rec.aviation.misc
Brian Whatcott
On Tue, 17 Oct 2006 18:32:42 GMT, Don Tuite
I'll try this time:
OR
and AoA and thrust.
Don
Good attitude, Don!
