Mike Schumann wrote:
That is NOT correct. TCAS was specifically designed to provide evasive maneuver info for airliners that are on a collision course with GA aircraft. However, the GA aircraft needs a Mode C Transponder (and it needs to be turned on). You are correct, I was confusing limitations of TCAS I with TCAS II... Marc |
Marc Ramsey wrote:
But doesn't TCAS gives you resolution without the need to spot the threat? I was under the impression that it does. Only if the threat is also equipped with TCAS... Marc A TCAS equipped aircraft with be given a resolution advisory for a threat aircraft that has a mode C or Mode S transponder. The threat aircraft does not need to have TCAS, and does not need to be interrogated by an ATC radar site. When both involved aircraft have TCAS the avoidance maneuver is agreed between them. If only one has TCAS it decides what to do on it's own. Andy |
After flying with the ZAON collision avoidance system,we became one of their
dealers. You can find it on our web site listed below. It was very interesting to have the device give warnings for aircraft I did not see. It works exactly as advertised, & seems well worth the cost, especially when flying near high density areas such as we fly. It receives it's data from other nearby aircraft equipped with a transponder. Our glider also has a transponder. Tom Knauff Knauff & Grove Soaring Supplies www.eglider.org |
Collision Avoidance and ATC | Bubba | Soaring | 5 | September 1st 06 04:31 AM |
Getting the MOCA | Dan | Instrument Flight Rules | 59 | July 3rd 06 01:43 AM |
Collision Avoidance Systems | [email protected] | Products | 0 | May 21st 06 10:15 PM |
WANTED: WTB - Portable Ox system | ecktoeman | Aviation Marketplace | 0 | November 26th 03 01:18 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
