Matt Young wrote:
Ok, a curious question just popped in my mind. Say that one was flying IFR in a piston single, maybe a 172 or 182. While enroute, either in actual or above a cloud layer, the engine fails. Will the windmilling prop keep the vacuum pump going enough to make the AI and DG usuable during descent through the clouds, or will the gyros keep spinning fast enough long enough to make the vacuum pump irrelevant? Whilst doing a engine runup at about 2000 rpm my vacuum indicates 'normal', and even during taxying at around 1000 rpm the AH is stable. So., if the engine fails *but the prop still keeps turning* at a reasonable rate (eg above 1000rpm) then I'd expect that there should still be sufficient 'vacuum' to operate the gyro instruments. With *no* vacuum, (eg after engine shutdown) my gyros starts drifting after about a minute. |
Matt Young wrote:
Ok, a curious question just popped in my mind. Say that one was flying IFR in a piston single, maybe a 172 or 182. While enroute, either in actual or above a cloud layer, the engine fails. Will the windmilling prop keep the vacuum pump going enough to make the AI and DG usuable Depends on your pump and what RPM's you can expect the prop to windmill at. My pump will produce 4" at idle and if you just shut off the fuel to the engine, the prop will windmill in the glide at well above idle (actually, you can't really tell by the RPM's that the engine isn't running). Of course, if your engine siezes, you're not going to get any windmilling. during descent through the clouds, or will the gyros keep spinning fast enough long enough to make the vacuum pump irrelevant? It's amazing how FAST the gyros spin down (and how long it takes them to spin up). I had a pump crump on takeoff roll and before I was at pattern altitude the AI had started to lean over (fortunately in VMC). |
In article et,
Matt Young wrote: during descent through the clouds, or will the gyros keep spinning fast enough long enough to make the vacuum pump irrelevant? I question the wisdom of relying on an instrument that you already know to have failed. You would need to know just how long you can stare at it in a very stressful situation before you can no longer believe what it tells you. I would think that immediately covering the instrument would be your best course of action in this scenario. |
No Such User wrote:
In article et, Matt Young wrote: during descent through the clouds, or will the gyros keep spinning fast enough long enough to make the vacuum pump irrelevant? I question the wisdom of relying on an instrument that you already know to have failed. What makes you think it has failed? If the vacuum guage still shows a vacuum, then the gyro's got to spin (unless you are unlucky enough to have a second failure of the vacuum system at the same time that the engine crumped). What I've never understood is why there isn't more obvious indication that there is no power (vacuum or electric as required) going to the instrument. Jeez, the VOR which isn't as essential to instrument flight has a better indication that it's not on. |
On Wed, 13 Oct 2004 04:39:47 GMT, Matt Young
wrote: Ok, a curious question just popped in my mind. Say that one was flying IFR in a piston single, maybe a 172 or 182. While enroute, either in actual or above a cloud layer, the engine fails. Will the windmilling prop keep the vacuum pump going enough to make the AI and DG usuable during descent through the clouds, or will the gyros keep spinning fast enough long enough to make the vacuum pump irrelevant? Your 're going to get answers all over the spectrum, but my take would be it might happen, but don't count on it to save your bacon. IOW, I'd not count on them working, or staying accurate which is _far_worse_ than not working when you are in the clouds. There are many variables such as the actual engine, prop, and vacuum pump combination as well as best glide speed. Its been my experience (which may not be typical) that a wet pump will do better with the low RPM than the dry pump. This is assuming you still have RPM which with a catastrophic failure you probably won't. In my particular airplane which has a wet pump and a constant speed prop, once the instruments are spun up even vacuum at idle (which is well below the minimum) will keep the AI and DG working. The AI stays accurate. The DG will start precessing but slowly although it does hold well with a prolonged idle on the ground. Actually it's close to being in tolerance. With full vacuum I don't have to reset it during a 3 to 4 hour flight. So, I'd expect to see the vacuum instruments "on mine" hold for some time, but even knowing them as well as I do, I'd still depend on partial panel and consider any use out of the vacuum instruments a bonus. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
| Thread Tools | |
| Display Modes | |
| Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 06:17 PM |
| Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? | Ron | Home Built | 2 | February 24th 04 05:34 PM |
| Tiny vacuum pump | Jim Weir | Home Built | 41 | January 24th 04 06:42 AM |
| IVO props... comments.. | Dave S | Home Built | 16 | December 7th 03 12:43 AM |
| Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 08:09 PM |
