Does a Cessna 152 have an afterburner?
Old October 17th 06, 06:32 PM posted to rec.aviation.piloting
Jim Logajan
Default Does a Cessna 152 have an afterburner?
"Jim Macklin" wrote:
Agreed, better to test the switch, or as Ronald Reagan said,
"trust, but verify."
OT: My understanding is that Reagan was "quoting" an old Russian proverb.
Old October 17th 06, 07:06 PM posted to rec.aviation.piloting
Kingfish
RK Henry wrote:
That's what I was taught years ago in primary training: Test the mag
switch as part of EVERY shutdown. I still follow that routine.
You never know when some fool is going to be messing with the prop
while the airplane is parked.
I never really understood the reason behind that. If you kill the
engine with the mixture pulling the prop through will do nothing other
than close the impulse coupler and fire the mag. With no fuel present,
nothing will happen. However, if you kill the engine with the mag
switch (and have a busted P lead) the carb is still primed and the
engine could start and turn a few revolutions if said fool were to pull
the prop through. Granted the hot mag check only takes a moment, but if
the engine is shut down properly there shouldn't be any danger, correct?
Old October 17th 06, 08:01 PM posted to rec.aviation.piloting
Jim Macklin
Double safety. Idle cutoff valves can also leak, primers
can leak and they by-pass the carb in some engines.
"Kingfish" wrote in message
Test the mag
routine.
with the prop
kill the
nothing other
fuel present,
the mag
and the
were to pull
moment, but if
danger, correct?
Old October 18th 06, 12:30 AM posted to rec.aviation.piloting
Morgans[_2_]
Explorers at OSH are not allowed to ever touch a prop, while helping a pilot
move an airplane, because of that fact.
Old October 18th 06, 03:39 AM posted to rec.aviation.piloting
Jim Macklin
About 50 mechanics are killed or injured by props every year
because they have to work near running engine to do some of
their work.
I always cringe when I see people leaning on a prop.
"Morgans" wrote in message
Test the mag
routine.
with the prop
| Jim in NC
1/72 Cessna 300, 400 series scale models Ale Owning 3 October 22nd 13 03:40 PM
Wow - heard on the air... (long) Nathan Young Piloting 68 July 25th 05 06:51 PM
