Why are the yokes always turned?
Old October 16th 06, 08:54 AM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
Default Why are the yokes always turned?
Often the ailerons are connect to the rudder with a bungee.
The rudder is connected to the nose wheel steering. Ergo.
"Ron Wanttaja" wrote in message
| On Mon, 16 Oct 2006 07:03:12 +0200, Mxsmanic
| Why does it seem that the control yokes of small
aircraft are always
| turned completely to one side or the other in
photographs? Is there
| some sort of convention about doing this? A safety
reason? Why is it
| so common?
| I've never seen this. Can you post a link to some
examples?
| Ron Wanttaja
Old October 16th 06, 12:10 PM posted to rec.aviation.piloting,rec.aviation.student
Ron Natalie
Mxsmanic wrote:
Why does it seem that the control yokes of small aircraft are always
turned completely to one side or the other in photographs? Is there
some sort of convention about doing this? A safety reason? Why is it
so common?
Without any airflow over the ailerons, it's kind of hard to hold
them in the center. As soon as the control flops over to one
side or the other, it tends to stay there.
Old October 16th 06, 07:57 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Ron Natalie writes:
Aren't they balanced such that they have no tendency to turn either
way? I should think the forces on them in a parked aircraft would be
symmetrical.
Old October 16th 06, 09:00 PM posted to rec.aviation.piloting,rec.aviation.student
Ron Natalie
Mxsmanic wrote:
Ron Natalie writes:
symmetrical.
They are balanced aerodynamically so they go neutral. As I said,
with no wind blowing on them in a lot of planes they'll sit
on the stops once they are knocked to one side or another.
Old October 16th 06, 09:11 PM posted to rec.aviation.piloting,rec.aviation.student
Neil Gould
Recently, Mxsmanic posted:
Ron Natalie writes:
symmetrical.
The forces on a parked airplane would only be symmetrical if the plane was
always headed into the wind. Obviously, this will rarely be the case
except for those parking spaces that are built on a turntable with a
large rudder on the back.
Neil
Old October 18th 06, 01:21 PM posted to rec.aviation.piloting,rec.aviation.student
Dylan Smith
On a point of pedantry, the turntable parking space would not need a
rudder. The plane tied down to this turntable tiedown would cause it to
point into the wind, since the turntable/aircraft combination would
behave like a large weather vane.
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old October 18th 06, 03:27 PM posted to rec.aviation.piloting,rec.aviation.student
Mark Hansen
Yea ... it's a good thing you caught that.
Old October 16th 06, 12:45 PM posted to rec.aviation.piloting,rec.aviation.student
Viperdoc[_1_]
There are usually slight differences in weight between the control surfaces,
due to the manufacturing process. For example, it is not uncommon for one
aileron to be a pound or two heavier than the other.
Gravity, plus the force of winds, will inevitably cause one to droop.
Likewise, rudders are not always hinged in a straight line, and the hinge
lines are off center, so the rudder will tend to tilt toward the heavier
side.
This is simply a factor in owning planes that are frequently over 20+ years
old.
rivet squeezer yokes Jim Burns Home Built 13 May 4th 06 01:52 PM
1966 Cessna 172 Control Yokes --- What Alloy? jls Home Built 0 November 4th 04 05:02 PM
Helicopter exercise turned scary: report Otis Willie Military Aviation 0 July 5th 04 01:43 AM
Anyone wrapped their yokes in leather? Jay Honeck Owning 13 March 3rd 04 02:59 PM
Vintage Cessna Yokes Al Gilson Owning 8 September 12th 03 03:27 PM
