Do your straps up tightly for winch launches!
Old October 18th 06, 11:00 AM posted to rec.aviation.soaring
phil collin
Default Do your straps up tightly for winch launches!
For the full report see the following URL
http://www.aaib.dft.gov.uk/publicati...ber_6 56_.cfm
Bert Willing wrote:
Doug,
the reading of an ASI is very rarely connected to winch launch accidents,
and certainly not in the initial climb.
Sliding back in the seat (or movement of a seatpan) during initial rotation
has already claimed a number of lives.
Bert
"Doug Haluza" wrote in message
Derek Copeland wrote:
Wouldn't the exact effect depend on the relative areas
of the pot pitot and the usually very small holes in
the T.E. probe? The AAIB are normally very thorough
in their investigations, so I am happy to believe them,
and that this error was not the primary cause of the
accident. Neither am I recommending that you should
connect your instruments up in this way.
No, the area of the openings would not matter, unless there was a
significant leak.
If your description is correct, then I would not assume that the
primary cause was the straps, which as you point out could not be
conclusively determined due to post impact damage. Can you check the
report again and make sure you have correctly reported the results?
Phil Collin
Partner Manager
T: 0870 861 0 300
E:
W:
www.voicehost.co.uk
Old October 18th 06, 06:20 PM posted to rec.aviation.soaring
Derek Copeland
Looking at the diagram of the instrument layout in
this glider, it would appear that the total energy
tube was connected to the fuselage statics and then
in turn to all the pressure instruments. I would guess
that effect of the total energy tube on the ASI would
therefore be greatly reduced due to leakage through
the normal static holes.
Derek Copeland
http://www.aaib.dft.gov.uk/publicati...ptember_2006/g
laser_dirks_dg600_glider__bga_3445__tail_number_ 656_.cfm
Bert Willing wrote:
Doug,
Bert
'Doug Haluza' wrote in message
in
them,
there was a
significant leak.
that the
could not be
Can you check the
the results?
Phil Collin
Partner Manager
T: 0870 861 0 300
E:
W:
www.voicehost.co.uk
Old October 19th 06, 03:20 PM posted to rec.aviation.soaring
Nyal Williams
This is somewhat analagous to reported accidents by
Cessna pilots on takeoff; if the adjustable seats
are not properly locked in their rails the seat can
slide backward, making it impossible to push the yoke
forward.
Perhaps we need a two-point attachment for each of
the shoulder straps -- the one above the shoulders
that already is in place and which keeps the body from
being thrown forward, plus a second one from be bottom
of the seat pan, and which would prevent the body from
moving upward and aft. This second strap could also
protect against cranial collision with the canopy.
Anyone for seven-point harness?
At 09:30 18 October 2006, Bert Willing wrote:
Doug,
launch accidents,
Bert
roups.com...
in
them,
there was a
significant leak.
that the
could not be
Can you check the
the results?
Old October 19th 06, 03:41 PM posted to rec.aviation.soaring
Bert Willing
I guess we just need to secure the shoulder straps properly ? ...
"Nyal Williams" wrote in message
forward.
Doug,
launch accidents,
Bert
groups.com...
in
them,
there was a
significant leak.
that the
could not be
Can you check the
the results?
Old October 19th 06, 04:44 PM posted to rec.aviation.soaring
Bill Daniels
forward.
That brings back nightmares. I had a Cessna 180 seat come off badly worn
tracks on takeoff. Somehow, I was able to scramble into the right front
seat before crashing.
Bill Daniels
Old October 19th 06, 06:18 PM posted to rec.aviation.soaring
Nyal Williams
Bert, I think you must not have read all this thread;
it was pointed out that shoulder strap connections
are too high and, while preventing the upper body from
going forward, do not prevent an upward and aft movement.
With current setups, no amount of tightening will
prevent this for short/small persons.
properly ? ...
'Nyal Williams' wrote in message
forward.
from
from
Doug,
launch accidents,
Bert
egroups.com...
in
them,
there was a
significant leak.
that the
could not be
Can you check the
the results?
Old October 19th 06, 09:48 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Just be wary of where the shoulder straps attach in the glider. If they
are anchored below shoulder height there's no problem.
ASW-19/Pegase/ASW-20 and Libelle are OK from this respect, as are Juniors.
Some gliders need careful checking because the exact seat arrangement
matters: Some of the early Discii, those fitted with a padded ply seat
back pivoted on a horizontal rod about half way up, have the strap
anchors set too high and you can float up slightly no matter how tight
the straps are. I think the straps run over the top of the seat back
which stops them pulling down on your shoulders quite hard enough.
However, the later models with a shaped glass fibre seat back that
pivots at the bottom don't show this problem.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old October 20th 06, 08:57 AM posted to rec.aviation.soaring
Bert Willing
Nyal, I do have read this thread.
If the attachment point of the shoulder straps are too high, a thin layer of
foam or rubber on the seat pan is all what's needed.
Having double attachment points on the shoulder straps is big means to solve
an easily solved problem - you go through a certification loop, you need to
think about egress restrictions and all this stuff.
properly ? ...
forward.
from
from
Doug,
launch accidents,
Bert
legroups.com...
in
them,
there was a
significant leak.
that the
could not be
Can you check the
the results?
Old October 21st 06, 10:06 PM posted to rec.aviation.soaring
Tim Ward[_1_]
forward.
I've been reading this, and I wonder if you couldn't just sew some straps to
the back side of the existing straps, then bring those down to a rectangle
of ballistic cloth that would lay on and more-or-less cover the seat back
and seat pan.
The higher the nose rotates, the more your weight would tend to squeeze the
ballistic cloth between your parachute and the seat back.
Tim Ward
Old October 22nd 06, 03:39 PM posted to rec.aviation.soaring
Nyal Williams
Crouch Strap story Ed Byars Soaring 43 September 23rd 13 05:43 PM
Air Force launches new ad campaign Otis Willie Military Aviation 0 September 14th 04 09:41 PM
Vandenberg AFB Rocket Launches Brian Webb Military Aviation 1 September 5th 04 06:13 PM
Vandenberg AFB Rocket Launches Brian Webb General Aviation 0 September 4th 04 11:42 PM
NOTAMs for non-US space launches? Allen Thomson Military Aviation 0 September 25th 03 04:01 PM
