Glass Panel Longevity
Old October 20th 06, 10:30 AM posted to rec.aviation.piloting
Neil Gould
Default Glass Panel Longevity
Recently, Sylvain posted:
Guy Elden Jr wrote:
Do people repair mechanical gauges or simply replace them when they
stop working?
It's a lot easier / cheaper to replace one mechanical gauge than an
entire instrument panel.
I don't know much about the G1000, but I am currently reading Max
Trescott's book on the subject; isn't the whole idea of this system
that it is made up of easily serviceable and replaceable (and
presumably upgradable) modules?
I don't know, but I would design the system that way. Even at the level of
integrated circuits, there are plug-in replacements for obsolete parts,
and I don't see any advantage to using unique components in this kind of
application.
Neil
Old October 20th 06, 03:47 PM posted to rec.aviation.piloting
stop working?
When digital watches first came out, they cost a lot more than
the old wind-ups even though they cost far less to produce. As more
manufacturers got into the act, the cost came down to more reasonable
levels.
I had an attitude indicator overhauled the other day. Cost
$675 Canadian. This stuff is only going to get more expensive as labour
goes up, since it can't be totally assembled by some robot. The life of
a gyro is rather short, too, especially in an operation like ours where
starting the airplane in cold weather is hard on gyro bearings. Engine
vibration eats gyros, and dry vacuum pumps last maybe 1200 hours.
If there are enough EFIS systems in use when a manufacturer
quits making them, some aftermarket manufacturer will find profit in
making replacement boards and displays for them under PMA rules. And as
more companies start making them, the up-front costs will come down. It
won't be instrument replacement costs that finally ground us; it will
be lawyers and insurance companies and heavyhanded regulation.
Dan
Old October 20th 06, 09:54 PM posted to rec.aviation.piloting
Grumman-581[_3_]
"Neil Gould" wrote in message
t...
application.
Unfortunately, some of the people making the decisions in these companies
don't necessarily see it that way... I was looking for a way to hook up the
output from my Northstar M1A LORAN to my laptop a few years ago so that I
could use it as input to a situation awareness program that I was writing...
Although NMEA 0183 was used by all the handheld LORANs and GPSs at that
time, it seems that Northstar chose to use a proprietary format for the data
stream coming out of their unit... While talking with them, I learned that
this was not uncommon within the avionics industry... A system like the
Argus moving map had to be able to understand all the possible data formats
of the various units that it supported...
Standards are great if everyone agrees to support them... Supposedly FireFox
is a true W3C compliant browser (unlike MS's IE)... I've encountered various
web sites that do not work correctly with it, but they work with IE... It
seems that developers get sloppy in that IE allows them to get away with
things that are not W3C compliant... Hell, I've even had to go back and
modify some of my own web apps that I created in the pre-FireFox days to
make them work with FireFox... Luckily it's only been needing to add
"document.getElementById" for each field accessed by a JavaScript function
variable... It seems that IE allowed you to be lazy and not require this...
Oh well, I'm digressing... The point is, don't assume that companies will
make decisions that will give you the most flexibility... They have a vested
interest in tying you to their products... Even if they have a common
interface like the TCP/IP interface that Rockwell was using on the systems
that I worked on, it doesn't necessarily help unless there is a standardized
command packet format... Otherwise, you will find yourself with one device
that although physically able to talk to another device, they might not be
able to understand what each other are saying... With some devices, it might
not be that difficult to come up with a common message protocol that the
device could support, with others, this could be quite extensive... For
example, consider the following devices and what they might need:
ADF:
1. Set frequency
2. Get frequency
3. Get bearing to transmitter
4. Enable audio output
5. Disable audio output
Transponder:
1. Set squawk code
2. Get squawk code
3. Set current mode (standby, Mode-A, Mode-C, Mode-S)
4. Get current mode
5. Initiate IDENT
6. Get IDENT status
Of course, every unit would also need a "Get system health / status" message
for retrieval internal diagnostics... It would be *nice* to know when a
particular device could not be relied upon... grin
I would like to see a system where you could put the actual measuring
devices in one location and the panel only needed to contain the devices
that display the information... For example, you could buy a small 2"-4"
generic display that could be set to display the output for various types of
devices... If one of the displays was acting up, you could change another
display so that it would display the output from the particular measuring
device... One advantage of this might be that although you might have
redundant measuring devices, only one display for the pair might need to be
on the panel... A failed health check might cause an indication to the pilot
that the backup device needs to be made active... Maybe it would even be
possible to toggle between the two devices...
Hell, as long as we're at it, let's give it a panel mount plug so that we
can plug our laptop PC into it also... If you had the building blocks in
place with this sort of TCP/IP controlled devices, just think of what sort
of flexibility that you could get without having to buy a $20K+ avionics
package... Of course, my point of view is as a VFR pilot would would like
some of the capabilities of the flight director type systems, but are not
able (either from a monetary or a physical panel space point of view) to put
one in their aircraft...
Old October 19th 06, 08:09 PM posted to rec.aviation.piloting
Grumman-581[_3_]
"Jim Logajan" wrote in message
Is the same model artificial horizon designed decades ago still
manufactured today?
Do people repair mechanical gauges or simply replace them when they stop
working?
In a lot of cases, it's not so much if the item can be repaired, but whether
it is cost effective given the shop rate for the repair guy... If it wasn't
for the added cost (that gets passed on to us, of course) of FAA
certification, it would probably be cheaper for most items to be replaced
instead of repaired... After getting burnt on radio repairs a couple of
times for my old Narco, I replaced it with an MX-11 like was in my other
radio slot... With repairs to the Narco running a few hundred dollars a pop,
I could have bought the MX-11 with the money that I wasted on the Narco
repairs... Since I still ended up buying the MX-11, all that money was
wasted... A MX-11 runs around $900 these days and installation is just a
slide in replacment for the Narco that it replaces and as such, you don't
need an A&P or avionics shop to do the replacement... If it wasn't for the
cost of FAA certification, I suspect that the MX-11s might approach the cost
of CB radios... It's not unreasonable to think that their price might drop
to the $100-200 range... At that price, repairs start getting the same as
the cost of a new radio, so it's more unlikely that someone would choose to
repair the item... Since the newer circuit boards are less component
repairable, technicians are more likely to just be replacing a complete
subassembly board instead of troubleshooting down to a component level...
This saves some time (i.e. money) in the troubleshooting stage, but it
increases the price in the repair parts stage...
Personally, I'm not a big fan of the one system does everything approach in
some of the glass panels... I have no problem with mechanical gauges being
replaced with electronic gauges, but I would prefer for them to be
independent, possibly communicating to some other system through some sort
of standard interface... At Rockwell, many of their new systems were
communicating via TCP/IP packets... I kind of liked this approach... It
seemed rather simple and elegant... A device would have a particular IP
address and port number associated with it... You could send information to
that device or retrieve information from it as appropriate... For a
non-compliant device, you could just design a TCP/IP interface to the device
that translated from the proprietary device information format to the TCP/IP
format...
Old October 19th 06, 09:01 PM posted to rec.aviation.piloting
Mxsmanic
"Grumman-581" writes:
format...
Minimizing the software improves reliability and safety. TCP/IP
interfaces generally require software, and that's not a good thing.
Old October 20th 06, 12:06 AM
Rich Anderson Rich Anderson is offline
Junior Member
First recorded activity by AviationBanter: Aug 2006
Jim,
I make a very good living repairing mechanical instruments. My company (The Gyro House) repairs over 500 instruments every month. It often amazes me how old some of those instruments are, many are older than me and I'll be 53 in December. It is true that it is difficult to find parts for some of the older instruments, but it is just as difficult to find chips for electronic instruments that were built in the 1970 -1990 time period. Again I can say this with certainty as my shop works on electronic instruments as well as the mechanical ones.
Concerning replacing instruments: it is sometimes the case that an instrument can become so worn out that it is no longer repairable,however out of the over 500 we do per month I can confidently say that less than 2% are found to be non-repairable.
Rich
Old October 19th 06, 06:58 PM posted to rec.aviation.piloting
Barney Rubble
Don't forget the GPS-90, which no longer has updates from either Garmin or
Jepp, so the question is for both of them, the G1000 would be useless if
Jepp pull the plug. The price of keeping all this data up to date in these
modern machines is a very real hidden cost (XM, nav data etc).
"john smith" wrote in message
The recent thread regarding the lack of parts for the Garmin 480 got me
to wondering just how long the G-1000's will "live"?
Steam gauges are forever, but integrated circuits are produced for a
given period, then production is ceased as newer chips come along.
Does Garmin mention anywhere how long they will support their products?
Their earliest GPS handhelds are coming up on 20 years.
We have seen Lowrence discontinue support for some of their products
that are less than 10 years old.
Old October 22nd 06, 03:48 AM posted to rec.aviation.piloting
Roger (K8RI)
On Thu, 19 Oct 2006 12:58:12 -0500, "Barney Rubble"
I wouldn't call it hidden. It's right there just like a chart
subscription and it's in a propritary format so we can't download and
install the updated goverment information.
www.rogerhalstead.com
Old October 23rd 06, 05:27 AM posted to rec.aviation.piloting
cjcampbell
Just like everything else that gets disontinued, either you have to
throw it away or someone starts manufacturing short runs of
discontinued parts. That is not unfeasible, by the way, for a G1000.
The big problem would be overcoming any legal obstacles thrown up by
Garmin.
The thing is, most chips and circuit boards should last for a very long
time, possibly longer than the airplane, and there will be replacement
parts from scavenged airplanes available.
Glass Panel construction DVD [email protected] Home Built 0 July 20th 06 05:41 AM
Glass panel upgrade to a Turbo Arrow? Tauno Voipio Owning 9 March 12th 06 04:29 AM
A Glass Panel for my old airplane? Brenor Brophy Owning 8 July 25th 05 07:36 AM
Glass Panel Scan? G Farris Instrument Flight Rules 6 October 13th 04 04:14 AM
C182 Glass Panel Scott Schluer Piloting 15 February 27th 04 03:52 PM
