Does Lycoming make any sense?
Old October 21st 06, 01:52 AM posted to rec.aviation.piloting,rec.aviation.owning
Robert M. Gary
Default Does Lycoming make any sense?
Stan Prevost wrote:
Robert, does it matter whether the boost pump is on or not?
No, pressure holds solid at 22lbs.
-Robert
Old October 21st 06, 03:45 AM posted to rec.aviation.piloting,rec.aviation.owning
Stan Prevost
I was wondering if the excessive fuel flow indication changes with pump on
vs off.
-Robert
Old October 21st 06, 09:41 AM posted to rec.aviation.piloting,rec.aviation.owning
Jim Macklin
Your turbine JPI device may only report to the JPI display.
The fuel pressure indicator/fuel flow that was original
equipment shows high pressure is there is a blockage and low
fuel flow. But the higher indicated pressure is also
interpreted as a higher fuel flow.
If you have EGT on each cylinder, checking temperatures and
thus fuel being burned can help determine if the cylinders
are rich or lean.
ps.com...
|I just spoke with Lycoming regarding my very high fuel
flow. Recently
| I've had a problem where I'm getting almost double my
normal fuel flow
| at idle even with the mixture at the edge of cut-off. I
suspected a
| servo but called Lycoming. They said I may have a nozzel
with a
| blockage and the other nozzles are streaming because of
it.
| Does this make any sense? Could a blockage cause an
*INCREASE* in fuel
| flow?
| I have a JPI fuel transducor wheel that measures fuel flow
that has
| shown to be very accurate.
| -Robert
Old October 23rd 06, 03:54 AM posted to rec.aviation.piloting,rec.aviation.owning
Capt.Doug
"Emily" wrote in message Obviously I can't remember the exact cause, but
I've heard the same
exact thing before...blockage can cause an increase in fuel flow.
It causes an increase in the indication on the OEM indicator which in
actuality is a pressure guage, not a flowmeter. Mr. Gary's system uses a
true flowmeter and a clogged injector line should show a decrease in flow.
D.
Old October 23rd 06, 02:35 PM posted to rec.aviation.piloting,rec.aviation.owning
Stan Prevost[_1_]
I don't think so, at least not very much decrease. I think the fuel will
divide among the functioning injector nozzles. This is why the pressure
increases when one is blocked, the fuel is forced through a fewer number of
orifices, causing a greater pressure drop across them.
"Capt.Doug" wrote in message
but
I've heard the same
D.
Old October 23rd 06, 04:53 PM posted to rec.aviation.piloting,rec.aviation.owning
Capt.Doug
"Stan Prevost" wrote in message
of
If we are talking about the OEM 'flowmeter', how many transducers does it
have? It would need two to measure a pressure drop. It needs only one to
measure the pressure near the spider. If it has only one transducer near the
spider, and a nozzle clogs, the remaining nozzles won't flow enough to
relieve the increased pressure and the result will be an increased 'flow'
indication.
D.
Old October 23rd 06, 06:06 PM posted to rec.aviation.piloting,rec.aviation.owning
Robert M. Gary
But there is noticable change in pressure, just in flow. The flow is
very high. I could see that if 1 nozzle was plugged that the other 3
would have increased flow but I can't see that the total amount of fuel
delivered would be double. Fuel flow is measured by a spinning wheel
and is not pressure related.
-Robert
Old October 23rd 06, 06:07 PM posted to rec.aviation.piloting,rec.aviation.owning
Robert M. Gary
of
indication.
The fuel flow measurement does not take into account pressure. Its just
an inline wheel that spins around.
-Robert
Old October 23rd 06, 08:46 PM posted to rec.aviation.piloting,rec.aviation.owning
Stan Prevost[_1_]
The pressure drop across the nozzle orifice is the absolute pressure into
the nozzle less the absolute pressure in the manifold. I don't have a
system diagram here, but I believe the factory fuel flow gauge is a
differential pressure gauge referenced to manifold pressure.
of
indication.
But I believe they flow all the metered fuel (or nearly all of it) as long
as the fuel pump provides sufficient pressure. Do you think the fuel flow
out of the fuel injector body (fuel servo) decreases if one nozzle clogs?
Once there is enough restriction to flow so that the "back pressure" from
the spider approaches the fuel pump pressure, then flow will reduce, but
until then, I think the servo maintains the flow it wants.
Old October 23rd 06, 09:00 PM posted to rec.aviation.piloting,rec.aviation.owning
Stan Prevost[_1_]
of
I assume you meant that there is *no* noticeable change in pressure. But
I'm not sure we are talking about the same thing. You measured fuel
pressure out of the fuel pump and found that it doesn't change. My question
was whether the "flow" indicated by the pressure-based factory flowmeter
changes. This is related to fuel pressure after the fuel servo, which is
not the fuel pressure you measured, I don't think. If the indication of the
factory fuel flow gauge, actuated by fuel in the fuel distribution lines,
has not changed, but the true flowmeter indication has greatly changed, then
I think you have one of two problems: The true flowmeter is broke, or you
are spewing fuel out of the system somewhere before the fuel servo, or in
it. But since the high fuel flow indication is accompanied by poor engine
performance, I think it is fuel spewing inside the servo.
If I remember right, one thing that can happen in a fuel servo is that an
internal problem can cause fuel to spew out of one of the ram air sensing
ports in the venturi, and get sucked up into the manifold, making the
mixture way too rich. The nozzles might have reasonably correct flow, but
the total flow will be too much. If this is happening, you can see blue
fuel stains in the venturi section, and maybe dripping fuel. Also you would
experience high true fuel flow. And ye$, thi$ doe$ call for overhaul of the
$ervo.
Stan
Which overhauled Lycoming 0-360 A4M Engine To Fit In My Archer ? Roy Page Owning 7 February 2nd 06 02:19 AM
MAKE THOUSANDS NO SCAM [email protected] Home Built 0 February 28th 05 02:06 AM
Lycoming 0-360 factory overhaul core charges - Does Air Powertell the truth ? Mike Spera Owning 6 December 13th 04 01:13 AM
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
