![]() Ron Wanttaja wrote: On 20 Oct 2006 15:47:10 -0700, " wrote: Howdy, After reading a bit about the early Lockheed Vega, the Focker Albatross DIII and the Dehavilland Mosquito I was a bit suprised that plywood monocoque construction hasn't been used in any more modern airplanes. (Or at least none that I can think of) What gives? Is it cheaper to use glass than wood? Anyone here have any experience with this type of construction and how it compares to truss style construction? Jim gave the Falco as an example of a monocoque wood aircraft, but keep in mind that the three you mentioned are *molded* wood aircraft. Not really efficient, for a homebuilt, unless you're planning on selling kits. Ron Wanttaja It also depends on what you consider more modern, the last of the all-wood european sailplanes were in the 70's but the performance had reached impressive levels. The most common would have to be the Ka6cr but the K6e was definitely the 15metre machine to have, far superior to most other 15m gliders of the time. Wood gliders finished for the most part with the SHK1, the 17m follow-on to the 15m Standard Austria. It was a plain timber monocoque, but it made good use of glass for finishing the wings and nose. There's still a few gliders for homebuilding made with a monocoque construction, but I think even a simple monocoque is probably just too much work for a one-off. Carlo Selman |
compound curves in plywood | BA-100 | Home Built | 58 | April 13th 05 05:29 AM |
cvjetkovic ca-65 skyfly- plywood spar? | patrick mitchel | Home Built | 3 | October 16th 04 05:26 PM |
Air Conditioning System for Homebuilts? | JPAviation | Home Built | 18 | February 6th 04 03:24 AM |
Homebuilts by State | Ron Wanttaja | Home Built | 14 | October 15th 03 08:30 PM |
Substitute for Mahogany plywood | Kelvin & Janice Rempel | Home Built | 1 | September 5th 03 08:02 PM |
