during normal air refueling join ups.. the contrail may give away the
location sometimes about 15 miles distant the aircraft can be picked up especially with a sun glint 10 miles, very easily BT "Jose" wrote in message om... When you are at flight levels, due to the curvature of the earth, on first apperance, the "higher" aircraft may appear to be lower, The curvature of the earth is greater in the bugsmasher altitudes. How far away are you seeing these airplanes? Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
Jose writes:
When you are at flight levels, due to the curvature of the earth, on first apperance, the "higher" aircraft may appear to be lower, The curvature of the earth is greater in the bugsmasher altitudes. How far away are you seeing these airplanes? FWIW, at FL360 aircraft will be already be in line of sight as much as 200 nm away (ground distance). Of course, human vision and atmospheric conditions put more restrictive limits on visibility. -- Transpose mxsmanic and gmail to reach me by e-mail. |
You can see the curve 20 miles away.
![]() "Kyle Boatright" wrote in message We flew commercial back to Atlanta yesterday.... .... When another airliner passes 1,000' right under you on a reciprocal heading with a closing speed of over 1,000 mph, it looks CLOSE. At normal cruising altitudes (ie, above 290) opposite direction vertical separation will be 2000 feet. |
"John Gaquin" wrote in message
At normal cruising altitudes (ie, above 290) opposite direction vertical separation will be 2000 feet. Are you current? Most of the modern world now uses 1000' seperation up to FL410. D. |
![]() "Capt.Doug" wrote in message Are you current? Most of the modern world now uses 1000' seperation up to FL410. I stand (or sit) corrected. Haven't flown a thing in eleven years, but your comment prompted a bit of research, and I see the reg. Just a couple of years ago, wasn't it? |
"John Gaquin" wrote in message Just a couple of
years ago, wasn't it? Yes, and it is a welcome addition. It gives us a lot more flexibilty to find smooth air, get shortcuts from ATC, and conserve fuel. D. |
"John Gaquin" wrote: "Capt.Doug" wrote in message Are you current? Most of the modern world now uses 1000' seperation up to FL410. I stand (or sit) corrected. Haven't flown a thing in eleven years, but your comment prompted a bit of research, and I see the reg. Just a couple of years ago, wasn't it? In the US NAS, yes. North Atlantic tracks started using RVSM in the later 1990's. -- Bob Noel Looking for a sig the lawyers will hate |
SPORTS CLASS/CLUB CLASS | 5 ugly | Soaring | 0 | July 2nd 06 11:14 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Carrying flight gear on the airlines | Peter MacPherson | Piloting | 20 | November 25th 04 12:29 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
