lancair crash scapoose, OR
Old October 23rd 06, 04:35 PM posted to rec.aviation.piloting
gatt
Default lancair crash scapoose, OR
Yesterday, according to the news, a pilot and his grandson walked away from
a crashed Lancair after it had an electrical failure on takeoff and made a
gear-up crash landing.
Question: Do Lancairs not have a hydraulic dump or something to lower the
gear in the event of such a failure?
-c
Old October 23rd 06, 07:47 PM posted to rec.aviation.piloting
Peter Duniho
"gatt" wrote in message
from a crashed Lancair after it had an electrical failure on takeoff and
made a gear-up crash landing.
the gear in the event of such a failure?
What type of Lancair? If the certified Columbia, they must. From FAR
23.729:
(c) Emergency operation. For a landplane having retractable
landing gear that cannot be extended manually, there must be
means to extend the landing gear in the event of either—
(1) Any reasonably probable failure in the normal landing gear
operation system; or
(2) Any reasonably probable failure in a power source that
would prevent the operation of the normal landing gear
operation system
Since an electrical failure would be a "reasonably probably failure in a
power source...", a Columbia must have some sort of backup gear operation
system.
I'm less sure of how the experimental rules work, but I wouldn't be
surprised if one still needs some sort of backup operation system for the
gear, even for amateur-built experimentals.
Pete
Old October 23rd 06, 10:37 PM posted to rec.aviation.piloting
gatt
"Peter Duniho" wrote in message
23.729:
Don't know. Ironically, I can't find the story in any of the local news
sources. They showed it on the 11 o'clock news last night, but that's the
last I've heard of it. Everything forward of the firewall looked crushed
and knocked 90 degrees to the side and the pilot looked like, well, he'd
just narrowly survived a crash with his grandson on board.
Bigger news, though, that fits the Dirty Laundry bill was a woman who fell
asleep at the wheel of her RV and rolled it on I-84 and another where a guy
was crushed by a rolling car which was in Park and had its emergency brake
on. (?!)
-c
Old October 24th 06, 11:45 PM posted to rec.aviation.piloting
.Blueskies.
"gatt" wrote in message ...
:: Don't know. Ironically, I can't find the story in any of the local news
: sources. They showed it on the 11 o'clock news last night, but that's the
: last I've heard of it. Everything forward of the firewall looked crushed
: and knocked 90 degrees to the side and the pilot looked like, well, he'd
: just narrowly survived a crash with his grandson on board.
not on the news cuz nobody died, doesn't fit the airplanes are not safe profile...
Old October 24th 06, 12:24 AM posted to rec.aviation.piloting
Roger (K8RI)
On Mon, 23 Oct 2006 11:47:24 -0700, "Peter Duniho"
23.729:
I'm not sure about this wording or if I'm missing something, but on a
Bonanza you only have two choices. The normal electric method and
manually. If the electric fails you must extend the gear manually
and if you are on take off when this happens forget even trying. It
takes 51 turns of a little gear handle and about two minutes to
manually extend the gear on a Bo. Oh..and to do so the pilot must
lean over and back between the seats to turn that little crank. That
means your head is below the bottom of the instrument panel. You best
know how to fly instruments or you will get a lot of exercise by
leaning over, make a turn (once the gear door is open you can only do
a half turn at a time although if you are fast you can get in two half
turns) and then straighten back up to look outside. That is a *LOT*
of sideways sit ups! Also it behooves the pilot to keep the speed
well below the maximum for gear extension but high enough to be safe.
Near the maximum that little handle is nigh onto impossible to turn.
If the gear won't come down and you are coming into a controlled
airport you might just as well tell them the problem and then fly out
where you have time and room to crank the gear down and stay out of
every one else's way.
operation system
Which means lowering the gear manually, but that is referred to in the
first sentence.
system.
The Twin Comanche had the simplest emergency gear operation. Pull the
handle the gravity pulls the gear down.
Pete
www.rogerhalstead.com
Old October 25th 06, 08:23 PM posted to rec.aviation.piloting
Kingfish
Not unlike any other retractable gear Piper built since the 60's IIRC...
Old October 26th 06, 02:27 AM posted to rec.aviation.piloting
On Mon, 23 Oct 2006 08:35:48 -0700, "gatt"
The following, posted on a local aviation forum by a friend of the pilot, may
help:
"During the flight, he experienced total electrical failure. An emergency, yes,
but not something that would cause the airplane to fall out of the sky. He
headed back to Scappoose, where he entered the downwind. He turned base then
final, visually clearing each leg, as his radio was not working. He DID extend
the gear by using the emergency extension, which on that airplane is simply a
lever that allows the gear to free-fall. Upon VERY short final, he noticed an
airplane on the runway. He quickly side-stepped the runway to land on the grass.
At the same moment, he added full power to initiate a go-around. The immediate
torque of the engine caused a left bank and descent. The airplane hit the ground
in a left wing low attitude. It cartwheeled on the left wingtip, smashing the
nose into the ground. At that point, the airplane came to rest on its belly. The
gear was down, but got torn off by the impact....Everyone is fine, but the plane
is totaled."
Old October 26th 06, 12:16 PM posted to rec.aviation.piloting
Neil Gould
Recently, Ron Wanttaja posted:
pilot, may help:
Any word on who the pilot is?
Neil
Old October 26th 06, 03:34 PM posted to rec.aviation.piloting
pilot, may help:
Don't know, but the aircraft (N1382Y) is registered to a Manfred Alexander of
Camas, WA.
VQ-1's P4M-1Q crash off China - 1956 Mike Naval Aviation 0 May 6th 06 11:13 PM
Pilot claims no blame in July crash Mortimer Schnerd, RN Piloting 48 March 15th 06 09:00 PM
Doubts raised in jet crash Dave Butler Piloting 8 July 26th 05 01:25 AM
Yet another A36 crash H.P. Piloting 10 April 23rd 05 05:58 PM
