Attn Spam Can drivers: Need MS FlightSim reality check...
Old October 25th 06, 04:03 PM posted to rec.aviation.homebuilt
Peter Dohm
Default Attn Spam Can drivers: Need MS FlightSim reality check...
I was taught to fly with "control altitude with the throtle, and
airspeed with the elevator." It made sense to me as my instructor
showed me how to do slow flight. We would get to a slow speed by
pulling back on the yoke until we got our desired speed and then would
set the throttle to whatever RPM was necessary to maintain our given
altitude. Setting up for a landing is basically the same
thing...throttle back (and if trim setting is not changed, altitude
decreases at some rate), back on the yoke (or stick) to get desired
airspeed and then adjust throttle for desired rate of descent (500 FPM
seems pretty standard)...
Scott
Corben Junior Ace
Well.... Perhaps some of the CFIs care to speak out...
IIRC, the FAA was concerned with departure stall/spin accidents and also
with approach and landing accidents. The reasoning went that both classes
of accident would be drastically reduced if pilots remembered to stabilize
their aircraft the recommended climb speed on departure and at the
recommended approach speed for the final aproach. Of course, that also made
powered approaches and BIG patterns popular.
Peter
Old October 25th 06, 11:01 PM posted to rec.aviation.homebuilt
Scott[_1_]
Point taken I was thinking piston type engine since the original
post mentioned "throttle"...now in my years of glider flying, I don't
remember seeing a knob labeled throttle
Scott
T o d d P a t t i s t wrote:
Scott wrote:
If you don't bieleve it try to climb without power sometime. CFI is correct
Gliders do it all the time!
No we don't, we use power to climb, just like airplanes, we
just don't use an internal combustion engine to produce the
power, we use a thermonuclear fusion generator.
Old October 25th 06, 11:04 PM posted to rec.aviation.homebuilt
Scott[_1_]
Well, I'm guilty of making postage size patterns I was taught to
keep 'er in close in case a piston decides to try and convert the engine
into an EXTERNAL combustion engine! I've been asked by towers where I
am when I call on downwind and I have to tell them I'm over the taxiway
'cause they're looking 3 miles out :O
Scott
Scott
Corben Junior Ace
Peter
Old October 27th 06, 07:39 AM posted to rec.aviation.homebuilt
karl gruber[_1_]
"T o d d P a t t i s t" wrote in message
"wright1902glider" wrote:
If you hold a constant speed and pitch attitude, changing
the throttle changes altitude. More specifically, changing
throttle changes your rate of climb/sink, and there's a
single throttle position where the engine is adding as much
energy to the aircraft as it is losing from drag. If you
open the throttle, the engine will produce more power and
you'll gain altitude. If you close it, you will descend.
Throttle controls thrust.
Elevator controls pitch.
Keep it simple................Karl
"Curator" N185KG
Old November 16th 06, 04:07 PM posted to rec.aviation.homebuilt
"Curator" N185KG
Attitude + Power = Performance. You can't say that one
control does only one thing. There's too much reductionism in flight
training and it creates inept pilots.
Dan
Old November 17th 06, 02:48 PM posted to rec.aviation.homebuilt
Ron Webb
Awww for crying out loud! The guy asks a simple question, and you either
confuse him with excess detail, or act like it's a stupid question, just
because YOU know the answer! Not very friendly!
Just to answer the question directly:
Your instructor is correct. Control altitude with throttle, and airspeed
with pitch. It sounds backwards, but that's what they teach. If you were to
take a Private Pilot ground school class tomorrow, they would have said that
in so many words before the end of the first week.
Of course, nothing is ever that easy in the real world, but you have to
start somewhere.
wright1902glider spewed this unto the Network:
If anyone out there will admit to driving a C-172, I have a question.
In MS FlightSim 2003, Rod the VR flight instructor tells me that I
should be controlling my altitude with the throtle, and my airspeed
with the elevator? Does that make sense?
Others have already answered this question.
In Microsoftland, I've got to constantly play with the throtle to hold
a consistant altitude. I don't recall ever seeing a pilot do that in
any plane I've ever flown in, but I could be wrong. Opinions?
Real pilots of aircraft that have elevator trim (such as the C-172)
tend to use it. In fact, if Rod's VR instruction was anything like
real flight instruction, he'd scold you for not "trimming out" the
aircraft. You should be able to completely let go of the controls
and have the aircraft stay at the same altitude. You should assign
two buttons on your joystick to operate the elevator trim.
In a real aircraft, the yoke will actually stay in the same position
when the aircraft is "trimmed out" (hence the references you'll hear to
"trimming away the pressure"), but in the simulator you'll have to
settle for the nose staying where you want it when the joystick is
centered.
Old November 17th 06, 06:18 PM posted to rec.aviation.homebuilt
Ah. So if I want to cruise faster, I leave the throttle alone and
pitch downward.
Dan
Old November 18th 06, 03:55 AM posted to rec.aviation.homebuilt
Roger (K8RI)
On Fri, 17 Nov 2006 04:48:32 -0900, "Ron Webb"
At a pilot proficency course the instructor showd me that either way
can work just as well. However even though it seems backwards the
pitch for airspeed, power for altitude apparently makes teaching
landings easier to start.
start somewhere.
www.rogerhalstead.com
alexis park inn and aviation videos Peter Duniho Piloting 49 March 30th 06 11:34 PM
$1295.00 Guaranteed Multi Ratings A+++++++++++ Service NW_PILOT Piloting 22 March 11th 06 02:07 AM
House OKs ban on flag burning, Do Something. [email protected] Naval Aviation 4 June 24th 05 01:08 AM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 10:25 AM
