Greg Esres wrote: In fact, the VOR-A is almost perfectly lined up with runway 32; In addition to the runway alignment issue, there are two other criteria used for issuing straight in minimums: descent gradients cannot exceed 400 ft/nm and the course must intersect the runway center line within a certain distance of the of the runway threshold, 3000-5200 ft in this instance. The descent gradients seem OK here, so my guess would be the point of course intersection was out of tolerance. The FAC is based on a VOR radial; by picking a radial up or down a couple of degrees, they can make the FAC intersect the extended centerline anywhere they want. The approach is over water and the VOR is on the field, so neither terrain or signal quality should be an issue for which radial they use. |
they want. In theory, yes. However, I have called Flight Procedures to ask about approaches similar to this, and the reason was the one I gave. There are sometimes obstacles that can be avoided by aiming the FAC towards the center of the airport, rather than the runway itself, and the placement of the intersection becomes limited. Unsatisfying, I know, because of its vagueness. |
There are three requirements that must be met to establish straight-in
minimums: 1. Final approach course alignment with runway. 2. Descent gradient 3. Limits on where final approach course crosses or parallels the runway centerline, extended. Number 3 is impossible to assess without the source data. Finally, flight inspection can nix the straight-in minimums if they don't like the way the approach flies. Roy Smith wrote: The VOR-A at New Haven (http://www.myairplane.com/databases/...s/00671VG2.PDF) has an MDA of 720, which is about 300 feet higher than the towers in the area. The VOR-2 (http://www.myairplane.com/databases/...s/00671VG2.PDF) gets you down to 380, and has to deal with the same towers. Why does it get to have an MDA 340 feet lower than the VOR-A? In fact, the VOR-A is almost perfectly lined up with runway 32; I don't see why it couldn't have been the VOR-32 with an MDA about 300 feet lower. Any of you TERPs-heads out there understand what's going on here? |
High Price of Flying Wires? | PWK | Home Built | 34 | October 8th 17 08:24 PM |
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 07:28 PM |
high impedance, low impedance? | JFLEISC | Home Built | 5 | April 11th 04 06:53 AM |
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS | MT. DIABLO HIGH SCHOOL PHOTOS | Home Built | 1 | October 13th 03 03:35 AM |
High performance homebuilt in the UK | NigelPocock | Home Built | 0 | August 18th 03 08:35 PM |
