Tow Hitch Ball - 50mm or 2"?
Old October 28th 06, 06:39 AM posted to rec.aviation.soaring
Frank Whiteley
Default Tow Hitch Ball - 50mm or 2"?
Frank Whiteley wrote:
ContestID67 wrote:
Mudhead,
Thanks for all the helpful hints. Did you learn all this at Moore
Science High?
Say hello to Bottles. See you at the convention.
- Porgie
PS Anyone else in RAS get the odd references that Burt and I am
bandying about?
of course, left coast, more specifically SF to SEA
bozo
Old October 28th 06, 01:43 PM posted to rec.aviation.soaring
Tony Verhulst
bandying about?
Not really. well, I'm off to my bridge club.
Tony V. :-)
Old October 28th 06, 05:53 PM posted to rec.aviation.soaring
01-- Zero One
"Burt Compton - Marfa" wrote in message
ups.com:
Howdy John (aka Mr. Tyrebiter),
Mudhead in Marfa here. As you might recall, I towed my Blanik (L-23)
trailer back and forth from Miami to Marfa several roundtrips until I
settled here. I used a 1 /7/8 ball and the trailer stayed on. I also
drive relatively slowly (55-60 mph), even on a long 2,000 mile journey.
I get there when I get there, and without the fatique of a stressful
fast pace. Sometimes it's best to avoid the Interstate routes with
those 75 mph big trucks blowing you around.
In any case, you should stick with the 1 7/8, or buy a 50mm ball from
www.HitchCorner.com They have a terrifc website about hitches,
grease, etc. They are located in Littleton (near Denver) Colorado,
USA.
I can also tell you that a 2 inch glider trailer hitch WILL jump off a
1 7/8 ball going over railroad tracks. Chains did their job - no
damage - no breakaway.
There is a big nut on the bottom of the ball that allows you to easily
change it. Just get the correct size and put it on! Simple as that.
No need for discussion about whether the trailer will come loose with
??? incorrect size or not.
And as far as how fast to travel to and from the venue, remember
Crosina's law.
My $0.02
Larry
"01" USA
Coordinated turns and the little ball Mxsmanic Piloting 51 October 11th 06 10:17 PM
Wanted - Ball Vario parts [email protected] Soaring 0 September 22nd 06 05:56 AM
Why don't wings have dimples? Dancing Fingers Home Built 56 June 17th 06 11:54 PM
wanted L'Hotellier ball fitting assembly Udo Rumpf Soaring 3 January 7th 05 03:05 AM
Trailer hitch inadvertant disconnect Bill Daniels Soaring 5 July 16th 04 03:17 AM
