On 31 Oct 2006 16:18:23 -0800, "Frank Whiteley"
wrote: A friend recently got a brass tailwheel for his DG300. The specific gravity of brass is about 8.5, stainless steel 7.7, aluminum 2.64. Just might work if your PIK has a tail wheel and any voids in the aluminum wheel could be filled in a brass or stainless replacement. Frank Whiteley Jay wrote: One of our local PIK-20D pilots - who happens to own a machine shop - replaced the aluminum tail wheel with a stainless steel tail wheel that he manufactured himself. Perfectly balanced and just about exactly the weight you are looking for. If you care to contact me directly, I will put you in touch. wrote: Over the years ,my PIK20D ,not to mention my self ,has gained some weight. The cg with me aboard is now located forward of the mid range although still within limits. I would like to add about 6 pounds of lead to the tail to shift the cg to the rear half of the allowable range. Anyone know the best way to attach the lead tail ballast? ------------ pik20_d9 I purchased a BRASS tailwheel from DG, out of Calistoga CA. Cost me ~$90, but was plug and Play for my DG200's tailwheel. The entire weight of the wheel, tube and tire came to 6.9 lbs, with the wheel itself weighing in at 6 lbs even. |
Ron (RW) wrote:
I purchased a BRASS tailwheel from DG, out of Calistoga CA. Cost me ~$90, but was plug and Play for my DG200's tailwheel. The entire weight of the wheel, tube and tire came to 6.9 lbs, with the wheel itself weighing in at 6 lbs even. That must have been long ago, or Oliver is clearing them out of his shop, as they cost something like 350 euros new from the factory. I had a local machine shop turn one for me a few years back for $120 (most of the cost was the brass), they took some measurements off the plastic wheel, and had it for me the next day... Marc |
Hi,
A few years back I wanted to add weight to the tail of the Ventus B I was part owner in at the time. The US Schempp-Hirth dealer at the time (Knauff and Grove) sold me a lead weight that fit between the top of the fin and the bottom of the horizontal stabilizer. It was very easy to install and remove quickly. It worked great. It made it possible for me to fly the glider in a much better CG location. One of my partners in the glider was much lighter than me so he flew without the weight installed. However, I must admit that as a mechanical engineer I was concerned about putting so much weight (5 to 10 lbs? - I don't recall) up high on the fin. In a ground loop or hard off-airport landing it would put a lot of twisting force onto the tailboom. But it was never a problem. Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Marc Ramsey" wrote in message ... Ron (RW) wrote: I purchased a BRASS tailwheel from DG, out of Calistoga CA. Cost me ~$90, but was plug and Play for my DG200's tailwheel. The entire weight of the wheel, tube and tire came to 6.9 lbs, with the wheel itself weighing in at 6 lbs even. That must have been long ago, or Oliver is clearing them out of his shop, as they cost something like 350 euros new from the factory. I had a local machine shop turn one for me a few years back for $120 (most of the cost was the brass), they took some measurements off the plastic wheel, and had it for me the next day... Marc |
" Ron (RW) wrote:
I purchased a BRASS tailwheel from DG, out of Calistoga CA. Cost me ~$90, but was plug and Play for my DG200's tailwheel. The entire weight of the wheel, tube and tire came to 6.9 lbs, with the wheel itself weighing in at 6 lbs even. I would be concious of the polar moments of the weight. It is possible to be in the cg range and at the same time exceeed the ability of the aircraft to make a spin recovery. My first choice would be sliding the pilot back a bit by making the chute and seat pan mode to get there. If when you run out of rudder pedal adjustment, there is always the use of "pads" on the pedals. Have a great day Scott |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
