About forward slips
Old November 1st 06, 12:17 AM posted to rec.aviation.piloting,rec.aviation.student
Jay Beckman
Default About forward slips
Mxsmanic wrote:
What's the proper procedure to execute a forward slip, how should the
aircraft be expected to react when it is performed, and what are the
main uses of the forward slip? And why is it called a _forward_ slip?
http://en.wikipedia.org/wiki/Slip_(aerodynamic)
Somebody said that MSFS cannot simulate forward slips correctly. What
is missing in the simulation?
I've read it has something to do with its inability to calculate the
lift, or perhaps just the default aircraft don't handle it. However,
I believe some third party aircraft explicity address the slip issue.
What's that C172 realistic addon? Drat. I've forgotten, but it's a
far better 172 than the stock one.
Note that, by default, MSFS is configured to link the rudder to the
ailerons. All turns are forced into coordinated turns, and there's no
independent rudder control.
Not true. You can deselect "Auto Rudder" and have independant rudder
control.
I believe the add-on 172 you are trying to think of is this one from Flight
1:
http://www.flight1.com/products.asp?product=esd172
That's a major reason why simmers who don't own rudder pedals get little
of the realism that the sim can sometimes offer.
Now that's a true statement.
Jay B
Old November 1st 06, 12:45 AM posted to rec.aviation.piloting,rec.aviation.student
Jay Beckman wrote:
I believe the add-on 172 you are trying to think of is this one from Flight 1
Thanks for that, but I finally recalled the one I was thinking of: the
"RealAir 172SP". It can do slips and spins, and felt pretty realistic
compared to the stock one.
Kev
Old November 1st 06, 01:06 AM posted to rec.aviation.piloting,rec.aviation.student
Jose[_1_]
Note that, by default, MSFS is configured to ...
Not true. You can deselect "Auto Rudder"...
.... and then you are no longer in the default configuration.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old November 1st 06, 02:09 AM posted to rec.aviation.piloting,rec.aviation.student
Dudley Henriques
Flight 1
Rob Young and his team at Realair have done some wonderful work with slip
realism in MSFS.
It took some fancy programming too from what I understand.
Using pedals, the sim pilot is afforded a much closer accuracy factor toward
the aerodynamics involved in an actual slip, but there are aspects of the
equation that are extremely difficult to program into a simulation. For
example, the rate of sink due to drag in a slip will vary a great deal from
airplane to airplane at various angles of attack and amounts of applied
opposite rudder to negate the turn. Its a VERY complicated formula.
Mild slips have been possible using the default aircraft in the sim using
rudder pedals but the tendency to turn into the low wing has always been
there and becomes prevalent if the low wing is banked past a very low angle
of bank. In other words, using defaults, the bank angle overcomes the
adverse rudder required to create the slip by negating the offset lift
vector.
Realair, with some absolutely magnificent programming, managed to improve
the aerodynamics required for slips in their add on aircraft. I can attest
to the fact that their Spitfire for one, handles in a slip in the sim
exactly like its real counterpart, as does the 260. I haven't tested the
172, but I'm willing to bet the house its as accurate as the others.
Dudley Henriques
MVP/Flight Simulator
Old November 1st 06, 02:10 AM posted to rec.aviation.piloting,rec.aviation.student
Viperdoc[_1_]
The other thing to remember is that the cross controlled condition in a
forward slip is a perfect setup for entry into an inverted spin or an
outside snap roll, which can be particularly impressive on short final in a
Cherokee.
Old November 1st 06, 02:40 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
A Lieberma writes:
He won't read it :-(
Wrong tense. He had already read it. But he hoped that someone here
might have something useful to contribute. Perhaps that optimism was
without justification.
The smell of a decomposing mouse somewhere forward of the firewall Peter R. Owning 23 February 1st 06 03:52 AM
What is a "Forward Skip"? Gary G Piloting 57 January 7th 05 10:09 PM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 09:36 PM
B-17 forward guin positions zxcv Military Aviation 13 March 16th 04 12:04 AM
Forward Swept Wings Canuck Bob Home Built 16 October 3rd 03 05:50 PM
