When trailers go bad OR How not to tow your Wright Brothers machine
Old November 8th 06, 06:12 AM posted to rec.aviation.homebuilt
wright1902glider
Default When trailers go bad OR How not to tow your Wright Brothers machine
Jim,
Skeerd yet? That thing's got over 7,000 miles on it!
I think you may have a point about the fore/aft balance. Truth is, I
havn't checked the balance with a set of scales since I first built it.
I've only weighed the tongue. That's going to be step one of the
rebuild... to get the balance right. Even so, the last balast test
involved loading 480 lbs. of sandbags in the aft end. There was a
definite improvement, but it was still unstable.
I've had another idea that the 2x4 wood framing in the deck could be
replaced by steel angle if I can find it cheap enough. I might also be
able to use a set of plastic "sprayer tanks" for the balast system.
And yet another thought. That I should ditch that Chineese frame and
just weld my own. HA! A bona fide excuse to buy a welding torch.
Harry
Old November 3rd 06, 03:36 AM posted to rec.aviation.homebuilt
Ernest Christley
Default When trailers go bad OR How not to tow your Wright Brothersmachine
wright1902glider wrote:
I'm currently working on various methods of accomplishing the new goal
without spending too much cash. I think most of the steel framing and
sheet metal can be used again. But I'll have to work out a new decking
system, etc.
Could you make the box a triangle?
Have the side hinged at the bottom. Fold them down, attach a wing to
each side, fold it closed and pin them together at the top.
The sloped side should be much more wind friendly.
Old November 3rd 06, 05:59 PM posted to rec.aviation.homebuilt
wright1902glider
Thanks for all of the unique thinking folks. Lots of good ideas.
Here's a link to my website that has a photo of the "rolling hawg
shed".
hometown.aol.com/wright1902glider/airshow8.html
I've been thinking about this a lot in the past few days, and I keep
coming back to the conclusion that I've got more of a height-to-track
ratio problem or a CG problem than a sway issue. From my rear-view
mirror observations, the trailer doesn't sway so much as it just rocks
up on one wheel. I can push on the side of the trailer near the tail
end and in 3-5 pushes, rock it up and nearly over.
I'd like to stay with a box-trailer with as few openings as possible.
The reason for this is that Wright machines are covered in raw cotton
muslin, and the fabric braces the wings. If they get wet, they're
toast. I think a glider-trailer setup with internal guides and dollies
is the way I want to go.
Jim, I had been thinking about the ballast system. The local glider FBO
in Boulder, who is also an RAH'er suggested something like this. But
the idea for the pump is the missing link. I can see it helping
considerably on the Interstates. Maybe something like a 12v bilge pump
plumbed between two tanks made from large diameter PVC. Sling 'em low
and to the sides like the external fuel tanks on a CH-53 Sea Stallion.
I've also thought about just adding a concrete-filled steel pipe under
the chassis center to act like the keel of a sailboat. All of this will
require testing of course.
Anyone have any thoughts on how much wider I could make the axle? Keep
in mind, the chassis is on 48" spring centers, using 2-leaf
slipper-springs, and currently has a hubface-to-hubface measurement of
60". I've seen heavy air-compressors, like those you see powering
jackhammers, rolling on 3-4' spring centers with about a 6' axle. But
all of the suspension components looked very heavy. My chasis is so
light that I'm concerned about adding too much axle and overloading the
frame attachment points, shackles, etc. with dynamic loads.
I'm also considering much wider tires. I've seen snowmobile and pontoon
boat trailers running 8"x8" tires or larger. I don't want to go too big
though. Again, overloading things with dynamic forces.
Harry
Old November 3rd 06, 07:50 PM posted to rec.aviation.homebuilt
Ed Sullivan
On 3 Nov 2006 09:59:26 -0800, "wright1902glider"
shed".
Harry
Have you considered the toe out or in on the wheels. I believe this
has an affect on the stability although I can't recall which is which.
Ed Sullivan
Old November 4th 06, 12:08 AM posted to rec.aviation.homebuilt
Morgans[_2_]
"Ed Sullivan" wrote in message
shed".
Harry
Here we go again! At least it is not toe in or out on airplanes!
Toe in for trailers, is correct. That way, if the trailer moves to the left,
the left wheel now is making the toe even worse, creating more drag, to force it
back in line with the tow vehicle.
I don't think that stability of this type is the OP's problem, though.
Old November 4th 06, 12:04 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Good golly , yes, on the CG problem. That thing is a lot taller than I had
imagined.
I have another insight into your problem.
I think the axle being so far towards the rear is a major part of the tipover.
You have a magjority of your weight on the ball. That is like having a bunch of
weight sitting on a knife edge, just waiting to tip over.
You seriously need to figure out how far forward you can move the axle. It
needs to be forward just to the point of swaying. If the load is even from
front to back, it should place the axle at 60/40. You look to have the axle
like 80/20.
Look at it this way. If the axle is 6 feet from the back, then the weight that
is on the back 6 feet, and 6 feet in front of the axle is using the axle to keep
it stable from side to side. All of the weight in front of that is sitting on a
ball, wanting to flip either left or right. More weight needs to be on the
axle! From your description of pusing it, the springs need to be more stiff,
or have shocks on it. Wider would be better, also, as you say.
I would thing bigger than pipe would be needed. How about plastic chemical
drums? If you used pipe, you would need to have a low point for the water to
collect for the bilge pump, or any pump to work.
A bilge pump would work very well. They usually have automatic shutoffs, when
they pump dry. All you have to do is pick which tank you want to be empty, and
turn that power supply on and leave it on. If a check valve is not incuded in
the pump, you would want to put one in, to keep the pump off after it transfers.
One pump per tank (or side), two wires going to the cab, a three position
switch, and you have it licked! For equal weight on each side, you would have
to time how long it takes to go from empty to equal, then use that figure to run
a pump and then swtch it off.
If you are concerned about point attachment loads, you could put a heavier angle
iron, or U channel over the existing frme, as a doubler. Make it long enough to
go about 3 feet past the attach points, and that should spread the load well
enough. If you are going to go to a wider axle, it would help to go as wide as
is reasonable, say a shade under 8 feet. Changing the spring fittings on the
axle to match your frame should not be a big deal, with a little welding. While
you are at it, move that darn axle forward, too!
Article: America Has Grounded the Wright Brothers Tom Sixkiller Owning 66 January 3rd 04 05:55 PM
Article: America Has Grounded the Wright Brothers Tom Sixkiller Piloting 71 January 3rd 04 05:55 PM
NEXT ON NOVA: "Wright Brothers' Flying Machine" Larry Dighera Piloting 0 December 13th 03 02:32 AM
