Robert M. Gary writes:
The sectional chart is used with a plotter. The plotter measures distance and can figure direction. I googled for this and found only software. I presume you mean the mechanical arm-like device that I've seen being using with flat charts on tables in movies? Certainly that might be useful, but what about during flight? Chart tables would be awkward in the cockpit (although large aircraft with navigators might have them). -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Mxsmanic wrote: Robert M. Gary writes: The sectional chart is used with a plotter. The plotter measures distance and can figure direction. I googled for this and found only software. I presume you mean the mechanical arm-like device that I've seen being using with flat charts on tables in movies? Certainly that might be useful, but what about during flight? Chart tables would be awkward in the cockpit (although large aircraft with navigators might have them). Two answers. First, when I'm flying my Mooney around at near the speed of sound I just have a rough idea of where the airspace is and use ATC and the GPS to avoid it. However, when I fly the J-3 (and when I first started flying) I carried a small plotter. You can use it in flight. In fact I'm required to make sure my students can use it in flight for navigation and diversion. You can use it in flight. I still carry a small plotter in the pocket of my seat. I have multiple scales on it so I can use it for IFR charts too but it also works for sectionals. I have one that has a Wizwheel built in and I use it regularly. Its easier for me to figure TAS using the wizwheel then puching numbers into the GPS to computer it. The Wizwheel is still a close friend of mine. When I flew the GPS, the Wizwheel, my watch, and my plotter were the *only* navigation tools I had. -Robert, CFII |
On Thu, 02 Nov 2006 10:47:38 +0100, Mxsmanic wrote:
Robert M. Gary writes: The sectional chart is used with a plotter. The plotter measures distance and can figure direction. I googled for this and found only software. I presume you mean the mechanical arm-like device that I've seen being using with flat charts on tables in movies? No, the plotter he's talking about is a combined protractor and ruler made of transparent plastic. The ruler's scales are calibrated to match distances on aeronautical charts. You can see what they look like at: http://www.sportys.com/acb/webpage.cfm?&DID=19&WebPage_ID=68 Certainly that might be useful, but what about during flight? Chart tables would be awkward in the cockpit (although large aircraft with navigators might have them). It's possible to whip out a plotter and measure distances and headings on a folded-up sectional chart in your lap in a typical light aircraft cockpit, but it's not very convenient. Typically you'd use a plotter for flight planning on the ground. Use the ruler to draw a line on the chart along your intended course, use the protractor to measure the angle between your course and a north-south line on the chart, and use the scale on the ruler to find distances. To answer your original question, in the pre-GPS era most people would plot course legs that would keep them well clear of restricted airspace. Make sure you stay near your planned course using a combination of pilotage and dead reckoning, and you don't have to worry about exactly where the boundary of the restricted airspace is. Seriously, if you want to learn this stuff, you might want to buy a private pilot ground school textbook of some sort, a plotter, and a sectional chart or two. Use the textbook to find out how to plan a flight using a plotter and charts, and then fly it in your simulator. ljd |
Recently, Mxsmanic posted:
I see tons of restricted areas, MOAs, Class B, C, D, E airspace, and the like on charts, but no clear indication of how to locate the boundaries of these areas other than by pure guesstimate based on looking at the chart. Reading a chart, like many other things, is a process that requires knowledge. One gains this knowledge by studying. Once you have studied and gained the necessaryt knowledge, you will know that there is no "guesstimate" involved in knowing the boundaries of areas on a chart. You have been given ample resources by many posters that would enable the average person to research and answer this question on their own. Why not give that a try? Neil |
![]() Neil Gould wrote: You have been given ample resources by many posters that would enable the average person to research and answer this question on their own. Why not give that a try? I had a funny though,t that a person could write a learn to fly a simulator book; comprised of cut and pasted poster's answers to all these various questions. ??? Every aspect it seems if being covered. |
The Visitor writes:
I had a funny though,t that a person could write a learn to fly a simulator book; comprised of cut and pasted poster's answers to all these various questions. ??? Every aspect it seems if being covered. The ideal simulator can be flown by a real pilot with no special instruction at all. That's why it's called a simulator. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Dave Doe writes:
You might like to note the differences between IFR charts and plates vs VFR charts (which, if you look, are really maps - topo maps). I've been able to find sectional charts and terminal charts at SkyVector, but where can I find IFR charts? -- Transpose mxsmanic and gmail to reach me by e-mail. |
says... Dave Doe writes: You might like to note the differences between IFR charts and plates vs VFR charts (which, if you look, are really maps - topo maps). I've been able to find sectional charts and terminal charts at SkyVector, but where can I find IFR charts? You could check out some arrival and departure plates here... http://www.aip.net.nz/NavWalk.aspx?s...e=Christchurch -- Duncan |
Dave Doe writes:
You could check out some arrival and departure plates here... http://www.aip.net.nz/NavWalk.aspx?s...e=Christchurch AirNav has those. But it sounds like there are other en-route charts for IFR, which I haven't seen. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
chart heads-up | Jose | Instrument Flight Rules | 2 | September 29th 06 07:25 PM |
Sectional Chart Question | Teranews | Piloting | 27 | June 23rd 05 12:14 AM |
WAC Chart Images on line? | Rich | Owning | 5 | March 22nd 04 11:17 PM |
