Removing oil galley plug
Old November 6th 06, 06:44 PM posted to rec.aviation.owning
Jim Burns[_1_]
Default Removing oil galley plug
Thanks. If nothing else, we'll create an archive of what doesn't work!
"nrp" wrote in message
If you end up having to drill it out (ugh!), pressurize the galley from
somewhere else with shop air so that any chips get blown back to you.
I'm not a fan of EZ-outs for something that is extra tight, as you may
end up distorting the threads in the case.
Penetratiung lubes etc won't penetrate the threads if there is pipe
dope in them. Instead the lube will probably get on the wrenching
surfaces & make a stripout that much more likely.
My read at least...... Still - good luck!
nrp
Old November 7th 06, 01:58 AM posted to rec.aviation.owning
David Lesher
"nrp" writes:
Nor am I; an EXZout is for when the head is stripped.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old November 7th 06, 04:17 AM posted to rec.aviation.owning
David Lesher
Nor am I; an EZout is for when the head is stripped.
Boy was this unclear....
You use an EZout when the head of the screw/bolt is damaged.
Classic -- phillips head screws.
It's of little use if the screw/bolt is really stuck. You can drill
such out but it's a PITA.
Old November 6th 06, 09:53 PM posted to rec.aviation.owning
Robert M. Gary
Jim Burns wrote:
For those who have installed oil temp probes in the forward oil galley of
their Lycoming engines, how did you or your A&P remove the 1/8" NTP plug?
I've got one that is stuck tight and I don't want to booger anything up
trying to get it out. I've heard horror stories of people having to drill
them out because they are stuck but I'm wondering if an impact driver could
be used without causing any damage to the case.
Any experience or thoughts would be appreciated.
I have one in my IO-360. It was a real &*($% to get out!!!! We finally
got it out with an "EZOut". Kind of like a nasty drill bit that grabs
it. It did not come out easily. As I recall though the plug has some
depth to it so you won't drill though it too quickly.
I initially thought I'd just try somewhere else after seeing how hard
it is. However, Lycoming said that was really where you want it
because...
1) Its very close to the factory probe temp so you don't need to come
up with a new yellow/red line
2) Its a low pressure area so a leak wouldn't be as nasty as some of
the other plugs.
-Robert, M20F
Old November 6th 06, 10:00 PM posted to rec.aviation.owning
Jim Burns[_1_]
Hmm... thanks Robert. At least some of the rumors I've heard can be
confirmed.
Honestly, thanks, because instead of fighting with it, I'll leave it until
the end and move forward with the rest of the install.
of
plug?
drill
could
because...
the other plugs.
-Robert, M20F
Old November 6th 06, 09:55 PM posted to rec.aviation.owning
Robert M. Gary
BTW: I can't remember if you're one of us from Sacramento or not. After
our initial failed attempt to remove the plug we took it to a guy who
teaches and lives next to Sacramento Community College Aviation (at
Exec Airport). He used the EZ-out from his fly-in driveway.
Email me if you want his info.
-Robert
Old November 6th 06, 10:08 PM posted to rec.aviation.owning
Jim Burns[_1_]
Thanks for the offer, but I'm in Wisconsin. Getting anything "straight on"
to the plug is going to require pulling the front engine baffle, and even
then the ring gear may be in the way, so for now, it's going to wait while I
finish the rest of the install and collect more insight on the problem.
-Robert
of
plug?
drill
could
Old November 6th 06, 10:32 PM posted to rec.aviation.owning
Robert M. Gary
Yes, the plug is behind the starter gear for me. However, our A&P used
a 90 degree drill and had another guy put direct pressure on it, while
he ran the drill. I think the reason we failed the first time was that
we didn't put enough pressure on it. Not using enough pressure will
strip it quick.
-Robert
Old November 6th 06, 11:35 PM posted to rec.aviation.owning
Drew Dalgleish
Kroil probably won't work if it has never seize on the threads but it
can't hurt to try. If it's really stuck it's probably faster to pull
the prop and ring gear than to mess things up trying to work around
it. Flying long enough to get the case fully warmed up may help too.
-Robert
of
plug?
drill
could
Fouled plug IO 470 [email protected] General Aviation 7 January 29th 06 06:03 PM
Plug fouled Denny Owning 9 September 2nd 05 05:58 AM
Plug replacements for O-360-A3A [email protected] Owning 3 August 20th 05 10:39 PM
ICOM Headset Adaptor Plug Ron Wanttaja Home Built 3 June 2nd 05 07:54 AM
Helicopter headset plug - help needed NewsGroups Home Built 4 September 8th 04 05:21 PM
