are "counter-rotating" and "contra-rotating" interchangeable terms?
Old November 11th 06, 02:36 AM posted to rec.aviation.piloting
buttman
Default are "counter-rotating" and "contra-rotating" interchangeable terms?
I'm doing some research, trying to find information on airplanes with
counter-rotating props, but I'm getting a lot of junk hits from
articles that use "counter-rotating" when they should mean
"contra-rotating".
I was always taught that "contra-rotating" was when you had two sets of
blades spinning from the same hub, as in this: http://tinyurl.com/vxu9a
and "counter-rotating" meant two different engines on a twin, each
spinning in opposite directions, ala the Seneca and Twin Comanche.
But according to google, more than half of the instances of
"counter-rotating" are used to describe "contra-rotating". Are all
those people wrong, or is the term interchangeable?
(by the way, I'm trying to compile a list of counter-rotating twins, if
anyone knows of any that are not listed he
http://en.wikipedia.org/wiki/Counter...ing_propellers please post)
Old November 11th 06, 02:48 AM posted to rec.aviation.piloting
karl gruber[_1_]
Yea,
The Wright Flyer.
Karl
"Curator" N185KG
"buttman" wrote in message
"contra-rotating".
Old November 11th 06, 03:04 AM posted to rec.aviation.piloting
john smith
Counter-rotating: prop tips rotate inboard
Contra-rotating: prop tips rotate outboard
Old November 11th 06, 03:05 AM posted to rec.aviation.piloting
Jose[_1_]
Default are "counter-rotating" and "contra-rotating" interchangeableterms?
Counter-rotating: you have to run to keep up with the cash register.
Contra-rotating: you have to run to keep up with the sales people.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old November 11th 06, 05:21 AM posted to rec.aviation.piloting
Jim Macklin
Counter rotating props are on two engine and shafts, they
rotate both clock and counter clockwise. On the P38 the
blades rotated away from the fuselage. Modern practice is
to have the blades rotate toward the fuselage and thus have
the lowest Vmc.
Contra-rotating is having two propellers on the same shaft
rotating in opposite directions to cancel torque effect and
gyroscopic forces.
"john smith" wrote in message
Old November 11th 06, 09:59 AM posted to rec.aviation.piloting
Grumman-581[_1_]
On Fri, 10 Nov 2006 23:21:53 -0600, Jim Macklin wrote:
On the P38 the blades rotated away from the fuselage.
Modern practice is to have the blades rotate toward
the fuselage and thus have the lowest Vmc.
Kind of depends upon your point of reference, doesn't it? No matter what,
the props are going to rotate towards the fuselage... It just depends upon
whether your point of reference is the top or the bottom of the fuselage...
Old November 11th 06, 10:02 AM posted to rec.aviation.piloting
Jim Macklin
P-factor and rotation is always, by convention, based on the
top blade moving downward.
"Grumman-581" wrote
in message
No matter what,
just depends upon
of the fuselage...
Old November 11th 06, 12:31 PM posted to rec.aviation.piloting
Kyle Boatright
"Jim Macklin" wrote in message
I can't think of a situation where the top blade would move any direction
but down. ;-)
The most common rotation pattern in modern twins is for the top blade(s) to
KB
