#11
![]() "Jim Macklin" wrote in message ... GPS, even a $100 hikers model will solve the problem. But I just say, look at the ground, you can judge 1,000 feet pretty well and you only need to apply the hemisphere rule above 3,000 AGL. On the other hand, we always tell airport noise complainers that it is very hard to accurately judge aircraft distances, such as whether the plane is 500 feet or 1000 feet high. ![]() |
"Jim Macklin" writes:
GPS, even a $100 hikers model will solve the problem. But I just say, look at the ground, you can judge 1,000 feet pretty well and you only need to apply the hemisphere rule above 3,000 AGL. GPS is far less accurate than an altimeter, and I don't think the regulations say "if you have no radio, use GPS." -- Transpose mxsmanic and gmail to reach me by e-mail. |
TxSrv writes:
For VFR, an adjustable altimeter is not required. Therefore, such a 100 mile rule doesn't exist. OK. But in that case how do VFR flights maintain specific altitudes? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Jim Logajan writes:
You can find the answer in FAR 91.121(a)(iii). Found it, thanks. I'm surprised that just setting it at the airport would suffice--one could conceivably fly for hundreds of miles VFR, and the altimeter could change significantly along the way. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Recently, Mxsmanic posted:
"Jim Macklin" writes: GPS, even a $100 hikers model will solve the problem. But I just say, look at the ground, you can judge 1,000 feet pretty well and you only need to apply the hemisphere rule above 3,000 AGL. GPS is far less accurate than an altimeter, and I don't think the regulations say "if you have no radio, use GPS." I'm not sure why you think that "GPS is far less accurate than an altimiter...", as an altimeter only need be accurate to 75' to be legal. GPS can do much better than that, and are unaffected by barometric pressure; the result is a potential source of problems that require pilots to fly by the altimeter, not the GPS. None of this has anything to do with regulations, of course. To answer your original question, the prudent pilot will take the barometric pressure of their destination into consideration during preflight planning, and adjust the altimeter accordingly. Most of the time, the pressure won't change all that drastically at the destination in the time it takes to fly 100 miles, and non-radio VFR pilots aren't likely to fly in weather where the pressure is changing too rapidly. Neil |
Jim Logajan writes: You can find the answer in FAR 91.121(a)(iii). Found it, thanks. I'm surprised that just setting it at the airport would suffice--one could conceivably fly for hundreds of miles VFR, and the altimeter could change significantly along the way. That really isn't as likely as you think, as the flights you're referring to only takes a couple of hours. If the pressure is changing significantly faster than that, it's likely to look pretty ugly outside either before you leave or en-route. Neil |
I think we can judge 1000' from the air better than somebody on the ground
because we spend a lot of time in the pattern at 1000' agl. We gt used to the perspective and can verify it with our altimeters. mike "Super Dave" wrote in message ink.net... "Jim Macklin" wrote in message ... GPS, even a $100 hikers model will solve the problem. But I just say, look at the ground, you can judge 1,000 feet pretty well and you only need to apply the hemisphere rule above 3,000 AGL. On the other hand, we always tell airport noise complainers that it is very hard to accurately judge aircraft distances, such as whether the plane is 500 feet or 1000 feet high. ![]() |
they give altitude, accurate to within a few feet. just set
the altimeter to read the same. then you know adjusted pressure. considering the legal requirements, it is perfectly adequate. see http://mtp.jpl.nasa.gov/notes/altitude/altitude.html "Peter Duniho" wrote in message ... | "Jim Macklin" wrote in message | ... | GPS, even a $100 hikers model will solve the problem. | | No, it won't. | | |
Looking down you're eye sees details of known sizes, roads,
cars and houses. It is also able to see angles and relations on the surface. Judging altitude from the air is fairly easy. I always require my pre-solo students to fly the traffic pattern [dual] with all the instruments covered. I have them tell me their altitude and speed and then uncover the instruments. They are always within 100 feet of the correct altitude. On the other hand, looking up, there are no references to judge height. Is it a full size B52 or a model, is it 2 miles away or 25, the human eye /brain needs reference points. But a trained observer is taught how to get those references, such as the size of the airplane, the relation of their thumb at arms length and the object, etc. "Super Dave" wrote in message ink.net... | | "Jim Macklin" wrote in message | ... | GPS, even a $100 hikers model will solve the problem. But I | just say, look at the ground, you can judge 1,000 feet | pretty well and you only need to apply the hemisphere rule | above 3,000 AGL. | | | On the other hand, we always tell airport noise complainers that it is very | hard to accurately judge aircraft distances, such as whether the plane is | 500 feet or 1000 feet high. ![]() | | |
right
"mike regish" wrote in message news ![]() somebody on the ground | because we spend a lot of time in the pattern at 1000' agl. We gt used to | the perspective and can verify it with our altimeters. | | mike | | "Super Dave" wrote in message | ink.net... | | "Jim Macklin" wrote in message | ... | GPS, even a $100 hikers model will solve the problem. But I | just say, look at the ground, you can judge 1,000 feet | pretty well and you only need to apply the hemisphere rule | above 3,000 AGL. | | | On the other hand, we always tell airport noise complainers that it is | very | hard to accurately judge aircraft distances, such as whether the plane is | 500 feet or 1000 feet high. ![]() | | | | |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
(sorta OT) Free Ham Radio Course | RST Engineering | Piloting | 43 | January 24th 05 08:05 PM |
1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 10:57 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
