pilots only, please - gps or altimeter?
Old November 12th 06, 07:52 PM posted to rec.aviation.piloting
kontiki
Default pilots only, please - gps or altimeter?
houstondan wrote:
gps(not waas) says nearest airport of any kind is 30 minutes away and
gas-totalizer says the fan stops in 10 minutes.
not mountainous but you ain't in kansas either todo...whatcha gunna
do??
The totalizer is reporting run-time at cruise power. I would throttle
back, lean agressively and fly at best glide + maybe 10 knots (or whatever
would give me best endurance) and contact somebody for help.
Old November 12th 06, 08:52 PM posted to rec.aviation.piloting
birdog
"houstondan" wrote in message
rather than hijack a perfectly good arcane science thread; i'll start a
new one 'cause the core question is a darn good one.
hypothetical situation: you're a blue sky vfr flyer and somehow you
wind up in the soup - after having gone 2 hours and 200 miles from your
take-off point , you wake up from a nice little nap and discover you're
inside the milk bottle.
do??
really.
dan
Ten minutes worth of fuel??? Solution: Land an hour ago and refuel.
Not an option? Stand up on the seat and kiss your ass goodbye. After the
cremation, all the other pilots that have to share the sky with you can
breathe a sigh of relief.
Old November 12th 06, 09:02 PM posted to rec.aviation.piloting
Huck
Thank you birdog!!!
There is no reason whatsoever a real pilot would/should get into a
situation where there is only 10 mins left worth of fuel. NO matter
what. That is why this is a silly question. But if this was to happen
The declaration of an emergency is required. Have some others help....
period then do as birdog says bendover and kiss your ass goodbye
matt
do??
really.
dan
Old November 12th 06, 09:18 PM posted to rec.aviation.piloting
karl gruber[_1_]
You'd do better by listening to MX on the subect of GPS. He has shown a
greater understanding of GPS than most of the pilots here.
Karl
what part of "pilots only" do you not understand? you have your thread
and your opinion has been heard. now go away. many real pilots will not
participate if you're in the thread and i'm really trying to talk to
them.
dan
Mxsmanic wrote:
houstondan writes:
GPS is reliable for this type of issue, even without WAAS. Just don't
rely on it to determine your altitude.
Old November 12th 06, 09:20 PM posted to rec.aviation.piloting
john smith
I am trying to understand why Andrew and kontiki are the only two with
the correct answer.
Old November 12th 06, 09:57 PM posted to rec.aviation.piloting
Ron Lee
Frankly this would qualify the pilot for the Darwin Award for being
inept. Then look at the GPS moving map/charts for a little used road.
You have no right to jeopardize others on the ground so whatever
landing surface is available that reduces the risk to you and
eliminates risk to others on the ground is what you have to deal with.
Of course other factors play into this.
Ron Lee
Old November 12th 06, 10:27 PM posted to rec.aviation.piloting
houstondan
....no, karl, that simply is not true and that's why i framed it the way
i have. it really relates to the totality of the systems and conditions
and not just the simple math. look at the responses that pilots are
giving.
can't you see the difference?
ever hear about how, if a pilot makes an air-traffic mistake the pilot
can die but that if an air traffic controller makes an air traffic
mistake...the pilot can die.
there is a qualitative difference between the thoughts of someone
reading a book and someone living it.
once you've heard the tape of a vfr into i.m.c. situation you'll know
what i'm talking about.
dan
dan
Karl
them.
dan
Mxsmanic wrote:
houstondan writes:
Old November 12th 06, 10:41 PM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
do??
really.
dan
Die.
Really.
Geoff
Morgans[_2_]
Head in the direction of the airport, lean as much as possible, start a best
climb speed to gain as much time in the air after the fan stops, then
communicate.
Hope that your altitude is enough to glide to the airport, glide at best glide
speed until close to the ground, then set up for stall plus 5 and wait to come
out of the clouds, or to hit the ground, which ever comes first.
Old November 12th 06, 10:47 PM posted to rec.aviation.piloting
"Andrew Sarangan" wrote in message
do??
really.
dan
Reduce power to best endurance, call ATC, explain your predicament,
You are a "blue sky vfr pilot". Playing with the radios is only going to
increase the (already overwelming) odds that you will become disorented and
die.
Geoff
FAA Mandatory Pilot Retirement Rule Challenged Larry Dighera Piloting 0 March 20th 05 08:56 PM
The allure of the skies beckons wannabe pilots. N9NWO Piloting 0 March 8th 05 08:58 PM
Older Pilots and Safety Bob Johnson Soaring 5 May 21st 04 01:08 AM
