Where does "mountain flying" begin?
Old November 16th 06, 01:38 PM posted to rec.aviation.student,rec.aviation.piloting
Matt Barrow
Default Where does "mountain flying" begin?
Mxsmanic wrote:
If you don't have mountain flying skills, and your departure and
destination are on opposite sides of a mountain range that is too long
to practically go around, what's the plan?
Go under!
(Appropriate answer for the cementhead)
Old November 16th 06, 06:08 PM posted to rec.aviation.student,rec.aviation.piloting
Jim Logajan
Go under!
Hey - that worked for Buckaroo Bonzai! ;-)
Old November 16th 06, 07:50 PM posted to rec.aviation.student,rec.aviation.piloting
Newps
Flying over a mountain range is not mountain flying. Mountain flying is
flying in the mountains, below the peaks, relatively close to the ground
in the valleys and passes.
Old November 17th 06, 12:24 AM posted to rec.aviation.student,rec.aviation.piloting
Morgans[_2_]
flying in the mountains, below the peaks, relatively close to the ground in
Are you sure you want to subscribe to that strict definition?
It seems to me that dealing with mountain waves, rotors, updrafts and
downdrafts, precipitation formed from air rising over the mountains, and some
other thing (no doubt) would still fall under the classification of mountain
flying.
No?
Old November 17th 06, 01:10 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Newps writes:
So is it relatively safe to fly over mountains if you clear them by
some reasonable altitude (1000 feet? 5000 feet?)?
Granted, that might be difficult in the Rockies with a small aircraft.
What about flying through relatively large valleys between mountains,
in order to avoid the mountains themselves? I mean, you have to get
from California to Colorado somehow.
Old November 17th 06, 01:31 AM posted to rec.aviation.student,rec.aviation.piloting
Stefan
You can always take the train.
Stefan
Old November 17th 06, 02:38 AM posted to rec.aviation.student,rec.aviation.piloting
Doug[_1_]
There really is no way to avoid mountains flying from Colorado to
California. There is a route that has the lowest altitude possible, but
still, you are going to have mountains.
Old November 17th 06, 03:13 AM posted to rec.aviation.student,rec.aviation.piloting
Newps
Mxsmanic wrote:
Newps writes:
As long as you clear them it doesn't matter how high. Safety depends on
the weather. I have skimmed over and thru the mountains at 50-100 agl
on nice calm days.
Not difficult at all, that's where I fly.
You have lots of options. Fly right over the tops direct if you have
the performance, fly over the lower passes if you don't or the
wind/weather precludes it or if you simply prefer it.
Old November 17th 06, 03:42 AM posted to rec.aviation.student,rec.aviation.piloting
Grumman-581[_1_]
Fly south to the Panama canal and follow it? Not sure about the terrain
that they had to blast through to make it, but it's probably not *that*
bad... grin
The further south you go, the better the route gets... When I flew from
Houston to SoCal a few years ago, I noticed that the southern route
through El Paso that I took on the way back was quite a bit better than
the route past the Grand Canyon that I had taken on the way over there...
Old November 17th 06, 03:48 AM posted to rec.aviation.student,rec.aviation.piloting
Grumman-581[_1_]
on nice calm days.
I prefer a bit more air underneath me than that considering the anemic
climb rate of my aircraft at altitude... When I flew to the Grand Canyon a
few years back, I encountered 2000 fpm updrafts... That was *great*... I
talked with some of the charter pilots around there about it and soon
learned that you can also encounter 2000 fpm downdrafts... That would
*not* be great...
"Is it possible for the voices in my head to use email from now on?"
When does IFR begin in VFR? Wizard of Draws Instrument Flight Rules 62 February 13th 05 11:19 PM
When will the war against terrorism begin? ArtKramr Military Aviation 8 September 14th 04 08:57 AM
=> PayBack's A BITCH! -- Let the REAL torture of prisoners begin MLenoch Military Aviation 1 May 12th 04 04:02 PM
Titan 4 launch prep comms begin at Canaveral AllanStern Military Aviation 0 February 14th 04 04:45 PM
