I found one of them. Let me describe the rear of the instrument to you and
see if it matches what you took out of your aircraft. There are two adjustment controls on the rear. The top center one is labeled LOC and the bottom right one is labeled VOR. In the lower left corner there is what we call a "cannon" plug, about 1.25" diameter and with 14 male pins inside the plug housing. That what you've got? Now, as I said, this one was working 20 years ago when I took it out to replace it with the RST navcom(s). If it is DOA when you get it, start thinking that perhaps it is the radio that drives the heads rather than the heads themselves. What radio is driving the head? If the radio is good, and this one doesn't work, I'll look around for the other head. Jim "RST Engineering" wrote in message ... I've got two old VOA-4 heads sitting SOMEWHERE |
RST Engineering wrote:
There are two adjustment controls on the rear. The top center one is labeled LOC and the bottom right one is labeled VOR. In the lower left corner there is what we call a "cannon" plug, about 1.25" diameter and with 14 male pins inside the plug housing. That what you've got? Yup. Now, as I said, this one was working 20 years ago when I took it out to replace it with the RST navcom(s). If it is DOA when you get it, start thinking that perhaps it is the radio that drives the heads rather than the heads themselves. What radio is driving the head? The TKM is driving the VOR head. And your diagnosis is right on the mark. I'll be out at the airport tomorrow to check on the radio nav itself. It may be bad connections/wiring. The instrument shop (yes, I broke down and took the VOR head over there today) claims that the narcos are practically bullet proof, and the odds are 90% in my favor that if the radio works, there's probably bad wiring or connectors. If the radio is good, and this one doesn't work, I'll look around for the other head. Wait until I see what's happening with the one I've got here. tanks! |
Thrust Needed For Self Launching... | tinman2006 | Soaring | 9 | March 14th 06 12:38 AM |
Thrust Needed For Self Launching... | tinman2006 | Soaring | 0 | March 12th 06 10:08 PM |
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy | Mike | Naval Aviation | 0 | December 27th 05 06:23 PM |
NY Go Kart Endurance Racing - Arrive & Drive - No Experience Needed | OVRPNY | Owning | 1 | May 19th 05 04:56 PM |
builder assistance needed | AINut | Home Built | 0 | April 8th 05 07:05 AM |
