Mxsmanic,
It's just hard to figure out whether I'm inside or outside the boundaries without a radius and center point. You're going at this the wrong way. In flight, what you do is simply look at the chart, find some ground features close to the border line of the airspace, look out the window, find the same ground features - and presto, you know where you are in relation to the airspace. For IFR flight, airspace doesn't matter much, since the controller will do everything necessary for you. Also, many circular airspaces are centered around a VOR-DME, so there's another help. Figuring the radius (which is normally standardized for certain types of airspace) is pretty easy, since the scale of a sectional is the same every time and you have a ruler. The logic for class E lower limits is in IFR traffic being in it. Class E means higher visibility requirements for VFR, so they can separate themselves from IFR traffic. You may recall the thread in which we tried VERY HARD to make you understand that concept. If you still haven't grasped it, it's no surprise you don't understand the logic of Class E lower limits. What comes round... -- Thomas Borchert (EDDH) |
Thomas Borchert writes:
You're going at this the wrong way. In flight, what you do is simply look at the chart, find some ground features close to the border line of the airspace, look out the window, find the same ground features - and presto, you know where you are in relation to the airspace. But that's just it: There are few ground features shown on the chart. In some cases, a charted feature is near the border of the airspace, but in many cases there is nothing along the border. Even with landmarks, the best you can do is estimate. I suppose one can argue that the differences among certain types of airspace aren't that great, and a ballpark estimate will do. But if they aren't that important, why bother to chart them? It's all a strong argument for moving-map GPS systems, but one shouldn't have to depend on those. For IFR flight, airspace doesn't matter much, since the controller will do everything necessary for you. Yes, but this is a chart intended for VFR. Also, many circular airspaces are centered around a VOR-DME, so there's another help. That does seem to be the case fairly often for Class B airspace, and as long as it's a moderately regular layer cake, you can find out where you are. I notice that some boundaries are clearly marked as being on a particular radial or at a particular distance. Others are marked as coincident with a feature such as a road, although how one is supposed to recognize one road among others is not explained (in the Phoenix TAC that I'm looking at, the entire area is crisscrossed with a grid of streets; I'm not sure how I'd distinguish Camelback Road from the other nearly identical streets to the north and south of it. Figuring the radius (which is normally standardized for certain types of airspace) is pretty easy, since the scale of a sectional is the same every time and you have a ruler. If I can take my hands off the controls and turn to my chart to measure it, that is. The logic for class E lower limits is in IFR traffic being in it. Class E means higher visibility requirements for VFR, so they can separate themselves from IFR traffic. I guess that makes sense--although it seems that essentially everything is Class E, anyway. It sounds like this was not always so. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic,
But that's just it: There are few ground features shown on the chart. In some cases, a charted feature is near the border of the airspace, but in many cases there is nothing along the border. Even with landmarks, the best you can do is estimate. You know yourself how many times you've been told this here, but in a real plane, this is a non-issue - as you would find out from one hour in the air. Orientation by ground features is a very basic piloting skill which is acquired during basic instruction. It works very well most of the time for most pilots - and should you get lost, there are strategies to find your position again. But, GPS moving maps have made it easier. The consequence of using one is that you will pass a restricted airspace much closer than you would using ground features because you will be able to determine your location more precisely. If, OTOH, you're in doubt, you'll just give the restricted airspace a wider berth. -- Thomas Borchert (EDDH) |
Mxsmanic wrote: Thomas Borchert writes: Figuring the radius (which is normally standardized for certain types of airspace) is pretty easy, since the scale of a sectional is the same every time and you have a ruler. If I can take my hands off the controls and turn to my chart to measure it, that is. Taking your hands off the controls is generally no big deal. Besides, if you know you'll be flying near controlled airspace you take care of your measuring and other planning before you get in the plane. Until you fly a real plane you just can't appreciate how simple this is. Don't make a mountain out of a mole hill. -- Scott Post |
![]() Others are marked as coincident with a feature such as a road, although how one is supposed to recognize one road among others is not explained (in the Phoenix TAC that I'm looking at, the entire area is crisscrossed with a grid of streets; I'm not sure how I'd distinguish Camelback Road from the other nearly identical streets to the north and south of it. Being a pilot in the Phoenix area I can at least help you out with that one. Camelback road can easily be identified by it's proximity to Camelback mountain, (from where it gets it's name) , and the mountain is easily identified by it's shape (take a wild guess as to what that is !). The other streets to the north and south are less easily identified, unless you are familiar with the area, however they can be identified by the locations of the high rise buildings. Most of these are clustered around central avenue, the uptown ones begin near Thomas, the downtown ones are noticeably seperated to the south. One comment I have to make here is it seems you ask these questions from a belief that pilots just take off and go buzzing around with no prior thought or preflight planning. I can assure you that in the cases of myself and the pilots I know, this is not the case. I am a helicopter pilot so making in flight measurements with a ruler/plotter is pretty much impossible(rule of thumb works for unexpected situations) but the point I am trying to make here is that most pilots don't just take off without already knowing where they are going and how they are going to get there. We can't plan for all the eventualities (oh look at that! and a sightseeing detour happens), but we must know where we are to know if said detour will be feasible or not. Most maps if you look closely enough will have a pretty clearly defined vfr waypoint on them, that you can use to identify your location on the map, (in Phoenix look for the Beeline Y or ASU or train tracks along Grand avenue or Boswell hospital on the west side. In short I guess what I'm trying to say is if you are unfamiliar with an area, it simply means that your preflight planning will, by necessity be more thorough. Wayne CPI-RTC |
Dashed cyan is actually class E surface area.
Not cyan. Rather, class E is depicted by that horrible purply color the FAA erroniously calls "magenta". What they print on the chart is not magenta by any stretch of the imagination. Magenta is beautiful; you can see magenta in the deluxe Crayola crayon box. The FAA color should be called "FAA feh". Cyan is more like a deep blue. Real cyan is also beautiful. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
Jose writes:
Not cyan. Rather, class E is depicted by that horrible purply color the FAA erroniously calls "magenta". What they print on the chart is not magenta by any stretch of the imagination. Magenta is beautiful; you can see magenta in the deluxe Crayola crayon box. The FAA color should be called "FAA feh". Cyan is more like a deep blue. Real cyan is also beautiful. Cyan is an equal blend of green and blue. It is used in process printing as one of the four base colors. Magenta is another one of those colors, and it is an equal blend of red and blue. The other two colors are yellow and black. By blending these colors in various proportions, you can produce virtually any color of the rainbow on paper. I'm not sure why the FAA chose these colors, but one possible reason is that they blend easily when they overlay other colors, which probably makes it easier to produce semitransparent borders with them. You can get away with simply overprinting cyan and magenta halftones; doing the same with primaries like red or blue (which are already screened blends) might just get you a muddy black. With modern electronic illustration and mapmaking this could probably be changed, but it looks like aviation charts are still being drawn and modified by hand--they lack the crisp look of something original prepared on a computer. It must be hugely labor-intensive. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
There are some mysteries that I've encountered while learning to read VFR charts: 1. I see airports with dashed cyan circles around them that I presume indicate Class D airspace (based on the chart legend). However, the circles are not always the same size, and I don't see any indication of their radii; how do I determine how far out the Class D circle extends (short of measuring it by hand)? Also, is there a convention for the center of the Class D circle (tower, or whatever?)? They don't seem to be centered on anything easily identifiable. The nominal diameter is 4.3 NM (5 SM). There may be extensions either as class D or class E surface area that accomodate the instrumetn approaches. They're centered on the airport reference point. 2. The legend doesn't appear to explain lines that consist of a solid cyan line with cyan dots inside. It seems to outline things like wildlife refuges or parks and stuff like that. Is this just an extra line style used for things that don't otherwise have line styles assigned, or what? Are there any restrictions or other things to know about spaces enclosed by these lines, or are they for information only? Symbols are explained more in the Aeronautical Chart User's Guide. http://www.naco.faa.gov/index.asp?xm...ine/aero_guide The blue line with the dots indicates a conservation area (wilelife refuge, national park ,etc.). Pilots are requested to stay 2000' above these (but it's not mandatory). 3. I'm confused about Class E airspace. If I understand correctly, the absence of any other indication on the chart means that Class E starts at 1200' AGL, and extends to 18,000' MSL. If the shaded purple border encloses an area, it's Class E starting at 700' AGL and still extending to 18,000' MSL. If it's a shaded cyan border, it means ... Class E starts at 1200' AGL and extends to 18,000' MSL?? (The chart says "abuts Class G," but I'm not sure what they mean.) Originally there was a lot less controlled airspace than there is now. If you're out in parts of the country which is much more desolate you'll fine the 1200' floors under airway, and the 700' floors around airports that have instrument approaches that don't have class E to the ground (transition areas). In most places now, the 1200 stuff pretty much just overlaps everything and there are magenta vignettes to take it down to 700'. Originally, the magenta vignette was abutted with a blue vignette showing the step up to 1200. Now they don't show the blue vignette when it's bumping up against 700' or surface area boundaries, only when it bumps up against uncontrolled airspace. 4. The cyan chain-link Class E border confuses me. Which side is inside the Class E? The altitude is the floor of the Class E and it still extends to 18,000' MSL, right? If there are different altitudes on each side of the chain link, what does that mean, and where do I look for the other border of the airspace? For example, just west of Buckeye on the Phoenix sectional, there are chain links and stuff all over the place, and I'm having trouble figuring out what the floors are and where. Around Western Sky airport (W 113° 40' N 33° 46' roughly), I see the shaded cyan border for Class E at 1200' AGL, but in that area I see 7000 MSL, and a chain link on the right and bottom. There are chain links next to airways, too. I don't know which altitude applies where. The zig/zag class E borders are used only in bizarre mountainous area. The side with the text is the non-standard controlled airspace floor. |
