The fuel shop fixed my fuel servo by replacing the spring that holds
the fuel regulating diaphragm. The tech said the previous spring was very stiff and he replaced it with one that was softer. Does that indicate that the previous spring was broken (i.e. stiffer than it should have been) or does Lycoming (Airmotive really) have a variety of springs for adjustment purposes?? Did they fix the problem or just adjust the fuel servo to work "post-problem". -Robert, IO-360-A3B6 |
I've had two fuel servos repaired on two different engines- My impression is
that the parts are adjusted to insure adequate fuel flow, which is the desired end result. I can not imagine how a spring would get stiffer with time- perhaps the diaphragm became more compliant. Why not ask your mechanic or the fuel shop? |
Viperdoc wrote: I've had two fuel servos repaired on two different engines- My impression is that the parts are adjusted to insure adequate fuel flow, which is the desired end result. I can not imagine how a spring would get stiffer with time- perhaps the diaphragm became more compliant. Why not ask your mechanic or the fuel shop? Mechanic doesn't understand fuel servos (in fact, I've yet to ever find an A&P who understands them from other than a theory point (since they're aren't allowed to work on them anyway)). I got an anonymous call from the fuel shop, I don't actually know who worked on it. My real question is "is replacing the spring considered a repair issue or an adjustment issue"? -Robert |
On 19 Nov 2006 08:11:59 -0800, "Robert M. Gary"
wrote: Viperdoc wrote: I've had two fuel servos repaired on two different engines- My impression is that the parts are adjusted to insure adequate fuel flow, which is the desired end result. I can not imagine how a spring would get stiffer with time- perhaps the diaphragm became more compliant. Why not ask your mechanic or the fuel shop? Mechanic doesn't understand fuel servos (in fact, I've yet to ever find an A&P who understands them from other than a theory point (since they're aren't allowed to work on them anyway)). I got an anonymous call from the fuel shop, I don't actually know who worked on it. My real question is "is replacing the spring considered a repair issue or an adjustment issue"? -Robert Not sure what you are looking for here, honestly. If you cannot discuss this with the person/facility that did the repair, contact another facility. http://www.gnaircraft.com/access.htm Just one company that has been working on them for a long time. Just be sure you have a clearly defined question that you want an answer to. I.E. if you know specifically what part was replaced, your specific servo p/n and your symptoms prior to repair. http://www.precisionairmotive.com/ Dig into this site for the list of product support & warrany repair centers-I can't post a "link" to that page, but G & N is on the list. I "understand" Bendix/RSA servos just fine, but have no idea what you are asking, I've never repaired one. Maybe you need to talk to someone who repairs them every day. TC |
On 20 Nov 2006 10:52:00 -0800, "Robert M. Gary"
wrote: I guess I was hoping for smarter people here. Whenever I speak tothe fuel shops (or any A&Ps) all I get is "it was too rich, it needed to be dialed down". My concern is still "why was it running on day 1 and didn't run day 2". I don't think the thing can "unadjust itself" in one day. However, I'm not sure if changing out the spring is just a 'readjustment' or a fix for a problem. Sadly, none of the fuel shops I spoke to even know how to answer that. I guess they're just in the mode of correcting what they see wrong, not necessarily finding a root cause. In my line of work we spend weeks in classes learning how to do RCA (finding actual root causes of things, not just fixing the signs of the problem). When I mention root cause I get blank looks from the fuel techs or A&P. The best I get back is "install it and try it". However, that means I need to put a certain number of hours on it before I feel good about flying the family and the Boy Scouts. Also, each R&R is costing me about 10 hours of A&P time. -Robert Understood. Seriously. If I'm not careful, my personal "ouiji board" will steer this towards a rant, been enuff/too much of that here lately. You want to correspond further (possibly gaining more info, but also risking a rant) drop me an e-mail. TC |
10 hours? And you said OK to that? I was hoping you were a little
smarter than that ;-) We had our servo replaced at annual and were charged 2 hours for the R&R. Did you look at what's involved it the R&R? Not much. And yes the servos are adjustable. Matter of fact one of the ways you can tell it is time for a new one is when the adjutsment screw is turned all the way out and no more adjustment is left. The servos are good for about 1000 hours before they need rebuilt so if yours has around that many hours than you probably just wasted your money trying to nickel and dime the situation instead of just rebuilding yours. As far as "needing" to know the root cause of everything, does it really matter? Do you need to know why you have a headache before taking some asprin? :-) Jon Kraus '79 Mooney 201 4443H @ UMP Also, each R&R is costing me about 10 hours of A&P time. |
(followups set to r.a.owning)
In rec.aviation.owning Robert M. Gary wrote: The fuel shop fixed my fuel servo by replacing the spring that holds the fuel regulating diaphragm. The tech said the previous spring was very stiff and he replaced it with one that was softer. Does that indicate that the previous spring was broken (i.e. stiffer than it should have been) or does Lycoming (Airmotive really) have a variety of springs for adjustment purposes?? I don't know anything about fuel servos. But I have played with springs before. For compression springs made out of a piece of wire that iscoiled up, the common failure modes seem to be: 1) breaking into pieces, 2) getting less springy over time - in other words, when new, a 10 lb. force caused 0.25" deflection, but now a 10 lb. force causes 0.5" deflection, and 3) taking a set - the springiness is about the same but the free length is shorter than when new. I guess getting _more_ springy over time (10 lb = 0.25" new, 10 lb = 0.1" now) is possible but I don't think it's very common. If you look at a (car) engine manual, they often specify the out-of-squareness, free length, and deflection under load of the valve springs. Out-of-square is just putting the spring on a known flat surface and making sure it is really vertical, or vertical to within some small tolerance. Free length is the overall length with no load. Deflection under load is either given as "it should take 10 to 15 pounds to compress the spring 0.25" from its free length" or "a force of 15 pounds should compress the spring 0.2" to 0.3"." You can even get a little jig with a lever and a ruler so you can apply a certain pressure to the spring and measure the deflection. I don't _think_ this is the case in a servo, but if you have a bunch of springs, sometimes relative sameness is better than absolute conformity to a spec. For instance, if the spec says the free length should be no more than 1.25" and no less than 1.0", and you have four valve springs at 0.990", 0.985", 0.995", and 0.993", then you're out of spec, but the engine will probably still run sort of OK. But if you have four springs at 0.990", 0.985", 0.720", and 0.993", then it'll probably run like crap. If it's rebuild time, you'd replace all the springs in either case. But if you're trying to figure out why it's running poorly, in the second case you can probably blame it on the bad spring, while in the first case you might keep looking. (Don't get me wrong - once you figure out why it's running poorly you'd probably wind up replacing all the springs in either case, since they are all out of spec.) Sometimes you can get different springs to adjust a mechanism - either of different free length or different spring constant. Springs with very different free lengths are easy to tell apart by eye. If the springs are the same length but have different spring constants, they are sometimes color coded so you can tell them apart in the parts bin. On older equipment, if there's only one spring, you sometimes see service manual directions that say in so many words: "If you still can't get it adjusted, maybe you got a widget from Monday morning and a spring from Friday afternoon. Try a different spring and see if that helps." In other words, they are admitting to tolerance buildups in the manufacturing process. Going on to the fuel side of things, it seems like a couple of common problems include extra air (naturally aspirated engines) and crap in the fuel lines. "Extra" air is an intake leak that allows air to get in without going past the air measuring device (carburetor, fuel servo, mass airflow meter, whatever) and leans out the mixture. This might come and go when a hose flexes or similar. Crap in the fuel lines can be pieces of the Dorito you dropped in the tank while fueling up, but it can also be gunk deposited by the fuel when you let the engine sit for a long time. Pieces of Dorito may eventually get sucked into the engine, caught by a filter, or just fall out unnoticed when the fuel line is disconnected. Old fuel gunk tends to be a little more tenacious, but can also dissolve into the new fuel over time. In your particular case, it seems to me that the procedures and specifications ought to be written down somewhere. There should be a defined rebuild procedure. There might be a spec for the spring and there should definitely be a spec for the performance of the entire servo assembly when run under defined conditions on a test bench or a test engine. Even if you can't legally use that information to fix your own servo, I would think (ha ha) that you ought to be able to get a copy of it somewhere. If you buy a $50 rebuilt alternator for your car, it will probably come with a little tag that says "Alternator type 123 S/N 456 rebuilt by Acme Corp. put out 60.1 A at 14.05 V at 3000 RPM when tested on 7/8/2009." Sometimes there's even a cute little graph of output vs. RPM. Maybe it's all printed by a random number generator, but if Acme can give you all that for $50, your fuel servo shop ought to be able to do something similar, IMHO. Anyway, I think I agree with what I understand to be your basic premise, which is that springs don't suddenly get stiffer on Tuesday. Ruling out everything else can be a lot of work, though. Disclaimer: This is based on experience with fuel systems, engines, and general machinery in ground vehicles and in fixed installations. I don't have an A&P; I don't even have a TG&Y. Your mileage may vary. Matt Roberds |
| Thread Tools | |
| Display Modes | |
| Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 08:04 PM |
| fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 01:57 PM |
| Jet fuel A-1 specific gravity | [email protected] | Piloting | 7 | May 20th 06 05:39 PM |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| "Out of fuel, out of hope: 'Help, I'm in the water'" | [email protected] | Piloting | 145 | May 4th 05 12:21 AM |
