Cleared for an approach, then given a different altitude assignment
Old December 6th 04, 04:35 PM
Peter R.
) wrote:
When they say "Maintain XXXXX altitude" after having received an approach
clearance you have to maintain the altitude. Obviously, you can't continue
the approach and maintain 3,000. So, you comply with the latest clearance.
Which I did. Having heard "Aircraft XXX, cancel previous approach
clearance, maintain current heading" or some such instruction to other
aircraft many times now, I mistakenly assumed that the controller was
required to cancel the approach clearance first. That history is what
prompted my confusion.
No doubt that it is a squeeze play, but the controller apparently had a good
reason. Once he deletes the restriction and, if at the point you are too
high to continue the approach, then you so advise him.
This scenerio will (or should) only happen in a radar environment.
Thank you for your concise explanation.
Peter
Old December 6th 04, 05:51 PM
KP
"Peter R." wrote in message
Today I was practicing a GPS approach and had been cleared for the
approach with the normal, "Cessna XXX, cross ELESE at 3,000, cleared
GPS 15 approach."
A minute or so later the controllers switched positions and another one
took over that slice of airspace.
The new one came on frequency and called my aircraft with, "Cessna XXX,
traffic one o'clock, 2,500 and two miles, southbound" (the traffic was
was crossing my path right to left underneath me).
I replied, "Negative traffic" to which he responded, "Maintain 3,000."
Being momentarily confused, I called to clarify the altitude
restriction. The controller responded rather tersely that he wanted me
at 3,000 for traffic avoidance.
Should the controller have canceled my approach clearance first, then
issued the altitude restriction?
I was initially confused because I still had 5 miles at 3,000 feet
before stepping down to the next altitude as part of the approach, and
it seemed that his first call was simply reinforcing the altitude
minimums on the approach (that is, until he responded in a terse manner
that he wanted to keep me there without ever rescinding my approach
clearance).
Peter
What class of airspace were you in?
If Class B or C the answer is probably "Yes, he should have cancelled
approach clearance to be 'book correct." But maybe he decided ensuring
separation was a higher priority task. Or has the view that if he told you
to maintain 3000 it should be obvious to you you're no longer authorized
descend on the approach (not saying it is; saying he thinks it should be
If Class D or E if either aircraft was VFR, he had no business issuing the
restriction in the first place. Traffic? Yes, altitude restrictions? No
Or there is also the possibility there was a genuine "deal" where standard
separation of 1000ft or 3NM was already lost, and the 500ft/2NM was better
than nothing. That might also explain the controller's "Do something now!
Worry about being "book correct" later" instruction as well as what seemed
to you a terse attitude.
Old December 6th 04, 05:52 PM
KP
"A Lieberman" wrote in message
On Sun, 05 Dec 2004 18:43:20 GMT, Mike Adams wrote:
Yes, this is an interesting point. Did they say "practice approach
approved, maintain VFR", or did they
say "cleared for the approach"? If it's a practice approach in a VFR
environment, it's not all that
unusual to get altitude restrictions, especially to keep you above the
VFR traffic pattern, if they can't
work you in.
Hmmm, never got a practice approach approved.....
I have always received cleared for the "type of approach" approach when I
am doing approaches under VMC.
Maybe practice approach is a regional thing?
Allen
Yes it can be a "regional thing" or more correctly an "airspace" or
"workload" thing.
VFR aircraft making practice approaches are supposed to be provided standard
IFR separation from the time clearance is issued until the MAP. The
phraseology for that is one of the normal approach clearances. See FAAO
7110.65 4-8-11a(2)
However, sometimes full IFR separation not worth the effort so there are
provisions to let VFR aircraft do the approaches pure VFR with no separation
provided. The phraseology for that is "Practice approach approved..." See
FAAO 7110.65 4-8-11a(3)
Old December 6th 04, 06:26 PM
Peter R.
Class E airspace making a GPS approach while VFR into a class C airport
(we were still several miles outside the class C ring).
The other issue that prompted my confusion was the controller change.
One controller cleared me, the next issued an altitude restriction. Was
the second's altitude restriction due in part to the fact that he was
not familiar with the GPS approach?
http://www.myairplane.com/databases/.../00411RY15.PDF
On the chart above, we were still outside of PAGER, approaching from the
east, when this occurred.
The approach required at least another 5 miles west at 3,000, then 12
more southwest-bound at 3,000 before descending - with strong headwinds
that day I had at least another thirteen minutes at 3,000 without the
altitude restriction. The other VFR aircraft was 500 feet below us
crossing our path at a 90 degree right to left direction and was well
south of us a minute or so after the restriction.
Peter
Old December 6th 04, 09:03 PM
Newps
Except we only need 500 feet vertical.
Old December 7th 04, 01:49 PM
Brien K. Meehan
Peter R. wrote:
It must be hard for you to walk the earth with us mere mortal pilots.
There are good days and bad days.
If this forum is only for expert IFR pilots like you, let me know and
I
will be sure to filter my future questions appropriately. 'kay?
Okay, but I'd really like you to take this much away from this
discussion:
You were advised of traffic. You didn't report it in sight, so you
were given an altitude assignment.
If you found that so confusing that you actually found it necessary to
call the controller back for clarification, you're head is really in
the wrong place while you're flying.
Old December 7th 04, 02:13 PM
Peter R.
LOL! Usenet clairvoyance at its finest.
With nothing more than a few sentences in this forum, you somehow were
able to correctly deduce that my head was not in the right place,
although personally I don't consider my wife's lap the "wrong place."
That's too biblical.
Peter
Old December 7th 04, 03:44 PM
PaulaJay1
In article , Peter R.
writes:
If this forum is only for expert IFR pilots like you, let me know and I
Peter
Peter,
In this (or any) form you get a varity of answers, some good and some from
"smart asses". It's up to you to separate them and ignore the latter.
Chuck
Old December 7th 04, 08:49 PM
Everett M. Greene
Peter R. writes:
Am I missing something?
You were assigned an altitude that you were going to
maintain without the assignment?
It would seem that letting the assignment pass without
comment and simply waiting for the controller to remove
the altitude restriction, probably with the words "cleared
for the approach", would have worked. If the restriction
weren't removed before needing to start the descent, a
verification of the approached clearance would then be
in order.
Old December 7th 04, 10:29 PM
Peter R.
Just a low-time pilot who apparently over-analyzed the situation.
Nothing else to see here... please move along.
Peter
Approach Question- Published Missed Can't be flown? Brad Z Instrument Flight Rules 8 May 6th 04 04:19 AM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 03:27 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 11:13 AM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
