#11
![]() Roy Smith wrote: "Andrew Sarangan" wrote: This is described in AIM chapter 3. The rules for the more restrictive airspace will apply when there is an overlap. That's an odd way to say it. Consider VFR minimums in overlapping Class D & B airspace (a pretty common occurance for satellite towered airports under the shelf of a Class B). The Class D rules say "1000 feet above, 500 feet below, 2000 feet laterally" for cloud clearance. The Class B rules say "clear of clouds". The D rule is more restrictive, but the B rule is what's in effect. You can only be in one airspace at a time. At TTD notice the class D circle isn't a full cirlce. It gets cut off where the class C goes to the ground. You can really see this at the airport just northwest of PDX. In the areas depicted that airspace is class D up to the altitude given, not a mix of class C and D. You don't get to pick a set of cloud clearance rules to suit your needs. |
"a. When overlapping airspace designations apply to the same airspace,
the operating rules associated with the more restrictive airspace designation apply. " This is not the same as "the most restrictive rules apply". But you did state it correctly to start out with. Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
![]() "Dennis" wrote in message . .. I don't know if anyone else caught that, but it was very funny. Thanks! I second that chuckle! :-) -- Jim in NC |
Andrew Sarangan writes:
An obvious example of this is restricted airspaces. The majority of R-airspaces overlap with G or E airspaces, but in those instances we don't question which rules apply. They aren't airspace classes though. Class B and Class C are both airspace classes; logically they cannot occupy the same space at the same time. Restricted and other special airspace is an additional qualifier that supplements the existing airspace class, so they can coexist. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Roy Smith writes:
That's an odd way to say it. Consider VFR minimums in overlapping Class D & B airspace (a pretty common occurance for satellite towered airports under the shelf of a Class B). The Class D rules say "1000 feet above, 500 feet below, 2000 feet laterally" for cloud clearance. The Class B rules say "clear of clouds". The D rule is more restrictive, but the B rule is what's in effect. Zero clouds is less restrictive than clouds a few thousand feet away? -- Transpose mxsmanic and gmail to reach me by e-mail. |
"There are two categories of airspace or airspace areas: 1. Regulatory (Class A, B, C, D and E airspace areas, restricted and prohibited areas); and 2. Nonregulatory (military operations areas (MOAs), warning areas, alert areas, and controlled firing areas)." The two categories can occupy the same space at the same time, but different classes in the same category cannot. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Newps writes:
You can only be in one airspace at a time. At TTD notice the class D circle isn't a full cirlce. It gets cut off where the class C goes to the ground. Yeah, but look at the altitudes. The top of the Class D appears to be _above_ the floor of the Class C that it overlaps. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Mxsmanic wrote: Roy Smith writes: That's an odd way to say it. Consider VFR minimums in overlapping Class D & B airspace (a pretty common occurance for satellite towered airports under the shelf of a Class B). The Class D rules say "1000 feet above, 500 feet below, 2000 feet laterally" for cloud clearance. The Class B rules say "clear of clouds". The D rule is more restrictive, but the B rule is what's in effect. Zero clouds is less restrictive than clouds a few thousand feet away? Not "zero clouds", but "clear of clouds". Having to stay away from a cloud by only an inch is much less restrictive than having to stay hundreds of feet away. Kev |
Kev writes:
Not "zero clouds", but "clear of clouds". Having to stay away from a cloud by only an inch is much less restrictive than having to stay hundreds of feet away. Ah ... I thought "clear of clouds" meant "[sky] clear of clouds," rather than "[aircraft] clear of clouds." -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Mxsmanic wrote: Newps writes: You can only be in one airspace at a time. At TTD notice the class D circle isn't a full cirlce. It gets cut off where the class C goes to the ground. Yeah, but look at the altitudes. The top of the Class D appears to be _above_ the floor of the Class C that it overlaps. The class C does not exist where the class D does. |
SPORTS CLASS/CLUB CLASS | 5 ugly | Soaring | 0 | July 2nd 06 11:14 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Carrying flight gear on the airlines | Peter MacPherson | Piloting | 20 | November 25th 04 12:29 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
