Is it possible to switch from VFR to IFR and back?
Old November 24th 06, 04:13 PM posted to rec.aviation.piloting,rec.aviation.student
Morgans[_2_]
Default Is it possible to switch from VFR to IFR and back?
No, you get the command prompt, and then type in "format C"
That won't work.
You need to use FDISK to remove the partition virus.
OK. I have only had to format one NT based machines, unlike the older stuff.
Old November 24th 06, 05:05 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Roger (K8RI) writes:
I'm surprised this was not covered in the instrument training.
I haven't had instrument training. The FAA book I found on IFR seems
to be more of a promotional book explaining how wonderfully the FAA
has organized air traffic control, and at least the parts I've read
thus far don't really explain IFR flight.
Old November 24th 06, 06:49 PM posted to rec.aviation.piloting,rec.aviation.student
Christopher Brian Colohan
Mxsmanic writes:
That is probably because the book is designed as supplement to IFR
training, and not as a substitute for it.
Chris
Old November 24th 06, 06:56 PM posted to rec.aviation.piloting
Greg Farris
says...
Mxsmanic,
s there a way to
switch to IFR in flight,
Yes. Press CTRL+ALT+SHIFT+I for that.
That requires too many fingers!
I cannot let go of the yolk that long!!
Old November 24th 06, 07:20 PM posted to rec.aviation.piloting,rec.aviation.student
Newps
Roger (K8RI) wrote:
On Fri, 24 Nov 2006 08:14:35 +0100, Greg Farris
says...
If I am instrument rated and my aircraft is fully equipped for
instrument flight, and I start out a flight with a VFR flight plan,
and it gets foggy enough that I'm below minimums, is there a way to
switch to IFR in flight, or do I have to have filed IFR from the
beginning? If it's possible in flight, how does it work? Is it
possible to later switch back again?
Now that's funny.
Old November 24th 06, 08:26 PM posted to rec.aviation.piloting,rec.aviation.student
Blanche
IMC - instrument meteorological conditions
IFR - instrument flight rules
IR - instrument rating
Weather is IMC
A pilot is Instrument Rated (IR)
FAA rules of flight are either IFR or VFR
Old November 24th 06, 08:28 PM posted to rec.aviation.piloting
Blanche
Greg Farris wrote:
says...
Mxsmanic,
s there a way to
try /dev/null
Old November 24th 06, 08:31 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
You be and are subject to both IFR and VFR when flying in
VMC [not Vmc] and you are expected to do both at the same
time in many cases.
"Blanche" wrote in message
| Weather is IMC
Old November 24th 06, 08:53 PM posted to rec.aviation.piloting
Thomas Borchert
Greg,
Ah, the yolk. And then there'S the egg white to take care of, too. ;-)
Thomas Borchert (EDDH)
