Most Important Control On My Plane
Old November 28th 06, 07:22 AM posted to rec.aviation.owning
Charles Talleyrand
Default Most Important Control On My Plane
Jay Honeck wrote:
Most important control
Radio transmit
Hey, I'm a "Use the radio, dammit!" guy from way back -- but even I
wouldn't rate the transmit button as my "most important control"...
Maybe number three or so...
I was not thinking of the yoke or pedals as controls. I was thinking
more buttons and knobs. If they count ... then it's the elevator.
-The original poster
Old November 28th 06, 04:25 PM posted to rec.aviation.owning
Don Tuite
On 27 Nov 2006 23:22:45 -0800, "Charles Talleyrand"
Radio transmit
The little knob on the altimeter gets my vote.
Don
Old November 28th 06, 11:12 PM posted to rec.aviation.owning
Jerry
Start switch
Jerry
"Charles Talleyrand" wrote in message
Type of plane
I have a VFR Cessna 150.
Radio transmit
Old November 29th 06, 12:44 AM posted to rec.aviation.owning
Charles Talleyrand
Robert M. Gary wrote:
Charles Talleyrand wrote:
Type of plane
M20
Radio transmit
Yoke
Least important control
Pitot heat (if you need it, you shouldn't be flying)
Why shouldn't you be flying if you need pitot heat?
Because I fly a VFR Cessna 150. When would I need pitot heat assuming
the weather was good enough to fly in the first place. In other words,
if I need pitot heat, what I really needed was better decision making
before takeoff.
Old November 29th 06, 01:36 AM posted to rec.aviation.owning
Jim Carter[_1_]
-----Original Message-----
Posted At: Tuesday, November 28, 2006 6:45 PM
Posted To: rec.aviation.owning
Conversation: Most Important Control On My Plane
Subject: Most Important Control On My Plane
words,
before takeoff.
To each, his or her own limits. However, pitot heat isn't only useful in
below freezing conditions. It used to be a practice to have the pitot
heat on before flight into visible moisture. I realize you mentioned VFR
only Charles, but it seems to me that this thread was tending to suggest
that pitot heat was for use during below freezing conditions, and that's
just not always the case.
Old November 29th 06, 03:42 AM posted to rec.aviation.owning
Roger[_4_]
Radio transmit
Nah. You should be able to fly using ailerons and trim without the
elevator. I had one instructor have me land doing just that. The AOPA
even put out a video on doing it.
I believe certification requires that the elevator not be a single
failure point. Home builts OTOH may not necessarily have that
advantage.
www.rogerhalstead.com
Old November 29th 06, 03:46 AM posted to rec.aviation.owning
Robert M. Gary
Start switch
Or stop switch. When I had the Chief I once had a bad mag ground that
prevented the mags from shutting off. Since the Chief has no idle cut
off mixture all I could do was to shut the fuel valve off and sit and
wait, and wait, and wait.
-Robert
Old November 29th 06, 03:59 AM posted to rec.aviation.owning
Drew Dalgleish
When I was getting my float rating the instructor had me take off
using just trim and rudder
Old November 29th 06, 12:53 PM posted to rec.aviation.owning
Steve Foley
Gas Cap
"Jerry" wrote in message
m...
Start switch
Jerry
Type of plane
Radio transmit
Old November 29th 06, 01:59 PM posted to rec.aviation.owning
Matt Barrow
Relief tube!
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO (MTJ)
Best place for CG along roll axis Mxsmanic Piloting 42 September 28th 06 04:40 AM
VQ-1's P4M-1Q crash off China - 1956 Mike Naval Aviation 0 May 6th 06 11:13 PM
My first aerobatic lesson Marco Rispoli Piloting 6 April 13th 05 02:21 PM
