Icing conditions
Old November 29th 06, 08:00 PM posted to rec.aviation.piloting,rec.aviation.student
B A R R Y[_2_]
Default Icing conditions
Mxsmanic wrote:
From what I understand, icing protection should be turned on if the
outside temperature is 5° C or less. However, what is the reason for
not having it on all the time?
Some ice protection equipment uses a fluid that is of limited quantity
on-board, not to mention that it costs money. Other ice protection
devices can put a drain on a smaller aircraft's power. Turbine drivers
might chime in with their reasons, I don't know them.
Ice protection isn't always needed when it's cold, you also need
moisture to create ice.
Old November 29th 06, 08:13 PM posted to rec.aviation.piloting,rec.aviation.student
Steve Foley
"B A R R Y" wrote in message
et...
He can always pause and go to the fridge for more fluids.
Other ice protection devices can put a drain on a smaller aircraft's
power.
He's running on 220VAC. Sholdn't be an issue.
Old November 29th 06, 08:12 PM posted to rec.aviation.piloting,rec.aviation.student
A Lieberma
"Steve Foley" wrote in news:BRlbh.12790
Better yet, use the hot water from his sink.
Old November 30th 06, 04:08 AM posted to rec.aviation.piloting,rec.aviation.student
Judah
A Lieberma wrote in
. 18:
Or pee.
Old November 29th 06, 08:24 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
Maybe he can rig a 200 pound CO2 bottle that can blast him,
simulating flight into a CB at the freezing level.
"Steve Foley" wrote in message
news:BRlbh.12790$d42.8443@trndny07...
| et...
turned on if the
the reason for
limited quantity
smaller aircraft's
| power.
Old November 29th 06, 08:29 PM posted to rec.aviation.piloting,rec.aviation.student
B A R R Y[_2_]
And end up looking like Dr. Evil's cat? G
Old November 29th 06, 08:23 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
True, cold and in cloud or precip.
BTW, TKS systems make the plane and floor slippery, don't
fall and break a leg.
et...
turned on if the
the reason for
limited quantity
protection
Turbine drivers
also need
Old November 29th 06, 10:05 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
B A R R Y writes:
But without a measurement of humidity on board, how do you know if
there's moisture out there (apart from the obvious case of visible
clouds or fog)?
Old November 29th 06, 11:30 PM posted to rec.aviation.piloting,rec.aviation.student
Dave[_1_]
This is where training and experience start to play a part in flight
planning...
If the temperature spread between the air temperature and the "dew"
point get close (like only 3 deg difference) the possibility of the
moisture in the air causing ice at or close to freezing temps becomes
a factor. In air pilot reports (PIREPS) are useful as well. This
information is obtained when you look at the weather forcast for your
intended route, and get a weather briefing from the weather people
before flight.
We have had several days of this here, temps +3 on the ground,- 5 at
alt, dew point -1 on the ground.
Last weekend we had this, and a PIREP from a Dash 8 reporting
moderate Rime Ice decending thriugh 6000 2 hrs earlier...
Ugh!
Dave
On Wed, 29 Nov 2006 23:05:23 +0100, Mxsmanic
B A R R Y writes:
clouds or fog)?
Old November 30th 06, 04:31 PM posted to rec.aviation.piloting,rec.aviation.student
Al G[_1_]
"Mxsmanic" wrote in message
crap snipped...
It's been my experience that any aircraft once exposed to ice, will
naturally seek out warmer air below.
Al G
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
FAR 91.157 Operating in icing conditions O. Sami Saydjari Instrument Flight Rules 98 December 11th 03 06:58 AM
