Contra-rotating engine revisited
Old December 5th 06, 08:18 PM posted to rec.aviation.piloting
Steve Foley
Default Contra-rotating engine revisited
"Kingfish" wrote in message
Steve Foley wrote:
How about an engine with the crankshaft running out the front and back,
so
you could mount a prop on the either end? That way you could have
counter-rotating props using the same engine.
Two props mounted on a common crank would turn in the same direction,
so they wouldn't be contra-rotating (I assume that is what you meant)
but might be counter-rotating if they turn in the opposite direction of
the other engine's props.
What I meant was putting a clockwise spinning prop on one wing, and turning
the other engine around, so it would be a counter-clockwise spinning prop on
the other wing.
Old December 1st 06, 08:00 PM posted to rec.aviation.piloting
tom418
Vacuum pumps are different (although these are accesories)
"Chris W" wrote in message
The previous post on this topic got me wondering. Just how different
would the two engines need to be? I'm no expert, but it seems to me
cam shaft(s), magnetos, and prop are the parts that would be different
from one side to the other. I almost forgot, reverse the polarity on
the starter motor. What am I missing?
Chris W
KE5GIX
"Protect your digital freedom and privacy, eliminate DRM,
learn more at http://www.defectivebydesign.org/what_is_drm"
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
One stop wish list for any gift,
from anywhere, for any occasion!
http://thewishzone.com
Old December 1st 06, 09:34 PM posted to rec.aviation.piloting
Mxsmanic
tom418 writes:
What is the logic behind using vacuum to power instruments? Why not
just use an electric motor, or compressed air?
Old December 1st 06, 10:22 PM posted to rec.aviation.piloting
TxSrv
Why don't you just think about what FAA's answer to that one is.
So obvious a Caveman can figure it out. Plus, compressed air
can be and is used. But not electricity, unless....
F--
Old December 2nd 06, 12:14 AM posted to rec.aviation.piloting
Steve Foley[_2_]
Default MXX Contra-rotating engine revisited
"TxSrv" wrote in message
Too many Geico ads?
buttman
This is annoying. "COUNTER-rotating" is the term you want.
"CONTRA-rotating" is when you have two different blades on the same
shaft spinning in different directions. About 50% of the time one of
these terms gets used, they get them mixed up.
http://en.wikipedia.org/wiki/Contra-rotating_propellers
http://en.wikipedia.org/wiki/Counter...ing_propellers
Old December 1st 06, 09:51 PM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
would the two engines need to be? I'm no expert, but it seems to me cam
shaft(s), magnetos, and prop are the parts that would be different from
one side to the other. I almost forgot, reverse the polarity on the
Chris W
KE5GIX
Camshaft as you said.
Crank - they drill the holes for the oil to the rod bearings in a different
spot.
Magneto - the impulse has to work in the other direction. I don't know if
there are changes to the points for avaition applications.
Oil pump - has to pump in the other direction
Starter - the bendix is different, the brushes are re-located
Alternator - it may have a different cooling fan
vacuum pump
Prop as you said
Mechanical Tach, or the drive (I assume)
Geoff
Old December 1st 06, 11:23 PM posted to rec.aviation.piloting
Bucky
If propeller direction is all that you need to change, could you just
add a reverser gear?
Old December 2nd 06, 12:16 AM posted to rec.aviation.piloting
Steve Foley[_2_]
"Bucky" wrote in message
How about one engine in the middle, with chain driven gears turning the
props on the wings.
Oh, wait. I think that's already been done.
Old December 2nd 06, 05:22 PM posted to rec.aviation.piloting
Morgans[_2_]
Before you come in here and play with big boys, you better put on your galoshes,
bucky.
And stop following that MX, from the sim group, where ever he goes. He and you
are going to get your fingers stepped on.
Maybe get a clue, too.
Oooh, that was mean. I take it back.
Gyrocopter Speed Mark Rotorcraft 36 August 16th 05 11:28 PM
Towing Roger Fowler Soaring 6 August 11th 05 04:25 AM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
