Pic of the Airgizmo installation
Old December 2nd 06, 03:54 PM posted to rec.aviation.owning
Jim Burns[_1_]
Default Pic of the Airgizmo installation
I spent some time with an A&P friend last night and noticed an AirGizmo on
his desk. I relayed Jay's story and he said that after dozens of phone
calls and non-committal answers he was finally able to confirm that the
Milwaukee FSDO is ok with a log book entry but Minneapolis was sticking to a
field approval.
My A&P's answer to my question about the lack of conformity was based around
the current "no new hires" policy at some of the smaller FSDO's. With
Inspectors retiring or moving out, some of them are not getting replaced.
The smaller staffs are starting to take a closer look at it's ability to
retain it's "annality". Of course I'm sure that it also has something to do
with the A&P's ability to sell the FSDO on the point of it not being a major
repair, using the FAA's own AC's and definitions as proof.
"Jay Honeck" wrote in message
BTW, did they do this with just a log book entry? I assume you didn't go
for a field approval on this.
Correct?
I was afraid you'd ask that....
Yes, the shop in Waterloo did it with a log-book entry, with the
blessing of the Des Moines FSDO.
The other shop I contacted (in Galesburg, IL) was adamant that they
could NOT install it without field approval from a different FSDO.
Needless to say, they didn't get my business.
I hate how anal some FAA people get. The AirGizmo is a piece of plastic
that allows my GPS to snap in place, holding it securely, no different
than a yoke mount (and probably safer). Why, just because it's
mounted on the panel, anyone thinks it's a "major modification" is just
beyond me. Thankfully, the Des Moine FSDO guys are apparently blessed
with superior powers of common sense.
Anyway, the moral of the story is: Shop around. Not all FSDOs (or
shops) are created equal.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old December 2nd 06, 05:28 PM posted to rec.aviation.owning
karl gruber[_1_]
"Jim Burns" wrote in message
a
field approval.
I wouldn't accept just a log book entry.
It's too hard to move to a different AI, with different opinions. Or it's
hard to sell the plane with some "expert" telling you that you need a 337.
The Airgizmo mount is difficult to work with as well. It is way more
convenient to have the 3/496 in your hands for most operations.
It DOES look good though.
Karl
Old December 2nd 06, 07:07 PM posted to rec.aviation.owning
Jay Honeck
I don't understand what you mean by this, Karl. Can you expand a bit?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 2nd 06, 08:49 PM posted to rec.aviation.owning
Newps
field approval.
That is not FSDO's call to make. The mechanic is the one who decides
whether or not any particular alteration is minor or major. It is very
clearly spelled out for the mechanics.
Old December 2nd 06, 11:45 PM posted to rec.aviation.owning
Jim Burns
I agree 100%, but for the mechanics who are hesitant then call the FSDO for
clarity the worms de-can themselves all too easily. I wish I could find the
AC that came out a while back that discusses the issue of too many 337s and
or requests for field approvals being submitted and how if the 337 isn't
required that it will get rejected opening another can of worms. Are you
familiar with the guidance AC I'm referring to? Sorry I can't be more
precise.
Old December 2nd 06, 08:47 PM posted to rec.aviation.owning
Newps
Jay Honeck wrote:
BTW, did they do this with just a log book entry? I assume you didn't go for a field approval on this.
Correct?
Why on earth would he even call FSDO?
The main problem is a mechanic who would call FSDO in the first place.
This guy is just shirking his very well laid out responsibilities. If
you read the manual that the mechanic goes by you can see why the FAA
guys make life hard. The very fact that you called means that your
install is much more than a minor alteration.
Old December 2nd 06, 09:30 PM posted to rec.aviation.owning
Jay Honeck
I don't blame the avionics tech (not an A&P) for calling the FSDO. The
AirGizmo is in one of those famous regulatory "gray areas" that can
drive everyone nuts, both inside and outside the FAA.
*I* think it's obviously a minor alteration, but (in fairness to those
who think otherwise) the unit DOES occupy an avionics bay, and it does
require wiring that leads to (and through) the back of the AirGizmo
unit.
The only way this really differs from a standard avionics installation
is that the 496 is designed as a "portable" unit, and the AirGizmo
allows it to be removed from the panel without tools -- a fine line,
indeed.
Thus, the call to (and blessings from) the FSDO.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 2nd 06, 10:19 PM posted to rec.aviation.owning
Newps
There's nothing gray about it. It's so crystal clear that Mike Busch
wrote about it in detail in several publications. If you were to read
the regs the A&P goes by you would come to the same conclusion. He
quoted them in his article. Any mechanic who calls FSDO for an Air
Gizmo installation in incompetent.
It is nothing more than a cover over a hole. The fact that the hole is
designed for a radio is irrelavant
and it does
unit.
It requires no such thing. That you choose to hardwire the GPS to power
to make life convenient is your option. As for the GPS antenna you are
merely tucking those into convenient areas of the trim to make it look neat.
That is the crucial difference. The FAA deserves blame in a lot of
areas but not this one. Tell your mechanic to RTFM.
The Good, the Bad, the Ugly: AirGizmo PIREP, PS Engineering CD/Intercom woes, XM "service" Jay Honeck Owning 34 December 15th 06 03:02 AM
US ELT Installation mhr Soaring 57 December 31st 05 07:39 PM
magneto installation help Dick Home Built 5 February 10th 05 03:02 PM
Skycraft Landing Light Installation Pix Jay Honeck Owning 5 February 6th 05 02:05 PM
Buying an L-2 Robert M. Gary Piloting 13 May 25th 04 04:03 AM
