#11
In article om,
" wrote: Plus I'm pretty sure my statement was pretty odvious in it's direction to the original author fwiw - no, your intended direction was not all obvious. -- Bob Noel Looking for a sig the lawyers will hate |
![]() "Dan" wrote in message ups.com... Ok, this is a followup to the previous discussion about forward control pressure during the landing rollout. Can someone tell me if the elevator/stabilator can actually generate an _upward_ force, or does it simply generate a downward force for climbing and less downward force for a decent? Does the nose fall due to the CG being forward of the center of lift, or does the elevator actually push the tail up? We are talking about tricycle gear planes, not taildraggers... The PA28 series specifically. --Dan I once saw a pair of mechanics doing a full power run-up in a Maule. They were holding brakes on and forward elevator, the tail was about six feet in the air standing still. So yes. Why do you separate the nosewheel from the tailwheel? They both fly with the same principles. Allen |
![]() Allen wrote: I once saw a pair of mechanics doing a full power run-up in a Maule. They were holding brakes on and forward elevator, the tail was about six feet in the air standing still. So yes. Why do you separate the nosewheel from the tailwheel? They both fly with the same principles. Allen Aha, but you have to allow for the thrust line being so far above the drag line, which in this case is the ground where the wheels are locked. That thrust produces a pitching couple that raises the tail much more effectively than the down-elevator. If the pilot holds full forward elevator at the start of the takeoff roll, the tails of most taildraggers won't come up until some considerable forward speed is attained, and then the tail is rising mostly because the centre of pressure of the wing, being behind the mains, is lifting it. Using forward elevator will lift the tail sooner but it sure is not entirely responsible for the rise. Wheelbarrowing is also mostly caused by too-fast landing speeds, not just forward elevator. It's worse with flaps down because the wing's CP is ahead of the mains and is raising the tail. Down-elevator isn't even necessary at high-enough speeds. The nosewheels of most trikes is closer to the ground than the mains in level flight attitude, and will contact first with the high airspeed reducing AOA. Dan (Instructor in taildraggers and trikes and a mechanic too) |
Yes, the elevetor generates lift, negative lift, 99.9% of the time, in
stable flight. If you look at most diagrams of aircraft forces, you will see the CG with a force vector down, then behind that the center of lift with a force vector upwards. Finally, the elevator is usually drawn with a force vector downwards as well. I would say there is a distinction between tailwheels and tricycle gear aircraft. On a tailwheel, the CG is behind the main gear, on a tricycle gear plane the CG is in front of the main gear. Thanks for the example of the outside loop, I understand now. While observing the range of stabilator deflection on a PA28, it seems to be able to generate a _heck_ of a lot more downward force than upward force, but apparently upward force is possible as well. --Dan wrote: I'm kind of alarmed to hear that an instructor didn't explain to you that the elevator generates lift. |
ups.com... Ok, this is a followup to the previous discussion about forward control pressure during the landing rollout. Can someone tell me if the elevator/stabilator can actually generate an _upward_ force, or does it simply generate a downward force for climbing and less downward force for a decent? Does the nose fall due to the CG being forward of the center of lift, or does the elevator actually push the tail up? We are talking about tricycle gear planes, not taildraggers... The PA28 series specifically. --Dan Take the seat belt off the yoke of your PA28 and measure the angle between : horizontal and the airfoil chord ( a line from the leading edge of the stabalizer and the trailing edge of the elevator). You can use a yardstick and protractor to get close enough. This will approximate the angle of attack of the tail feathers with the aircraft in a level flight when full forward stick is applied - right?. I suspect that it will be, what, 10 - 15 degrees? So, if the tail foil has a significant positive angle of attack, how could it not be generating postitive lift? -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
![]() wrote in message ups.com... Allen wrote: I once saw a pair of mechanics doing a full power run-up in a Maule. They were holding brakes on and forward elevator, the tail was about six feet in the air standing still. So yes. Why do you separate the nosewheel from the tailwheel? They both fly with the same principles. Allen Aha, but you have to allow for the thrust line being so far above the drag line, which in this case is the ground where the wheels are locked. That thrust produces a pitching couple that raises the tail much more effectively than the down-elevator. If the pilot holds full forward elevator at the start of the takeoff roll, the tails of most taildraggers won't come up until some considerable forward speed is attained, and then the tail is rising mostly because the centre of pressure of the wing, being behind the mains, is lifting it. Using forward elevator will lift the tail sooner but it sure is not entirely responsible for the rise. Wheelbarrowing is also mostly caused by too-fast landing speeds, not just forward elevator. It's worse with flaps down because the wing's CP is ahead of the mains and is raising the tail. Down-elevator isn't even necessary at high-enough speeds. The nosewheels of most trikes is closer to the ground than the mains in level flight attitude, and will contact first with the high airspeed reducing AOA. Dan (Instructor in taildraggers and trikes and a mechanic too) I have seen a Super Cub land with a 40 knot (or so) headwind and come to a complete stop, then raise the tail off the ground with the engine at idle. I see you point about the thrust affecting pitch though, used that all the time landing the Lear, as you bring the power levers to idle the nose pitches up and automatically puts you into the flare. Allen |
![]() Allen wrote: wrote in message ups.com... Allen wrote: I once saw a pair of mechanics doing a full power run-up in a Maule. They were holding brakes on and forward elevator, the tail was about six feet in the air standing still. So yes. Why do you separate the nosewheel from the tailwheel? They both fly with the same principles. Allen Aha, but you have to allow for the thrust line being so far above the drag line, which in this case is the ground where the wheels are locked. That thrust produces a pitching couple that raises the tail much more effectively than the down-elevator. If the pilot holds full forward elevator at the start of the takeoff roll, the tails of most taildraggers won't come up until some considerable forward speed is attained, and then the tail is rising mostly because the centre of pressure of the wing, being behind the mains, is lifting it. Using forward elevator will lift the tail sooner but it sure is not entirely responsible for the rise. Wheelbarrowing is also mostly caused by too-fast landing speeds, not just forward elevator. It's worse with flaps down because the wing's CP is ahead of the mains and is raising the tail. Down-elevator isn't even necessary at high-enough speeds. The nosewheels of most trikes is closer to the ground than the mains in level flight attitude, and will contact first with the high airspeed reducing AOA. Dan (Instructor in taildraggers and trikes and a mechanic too) I have seen a Super Cub land with a 40 knot (or so) headwind and come to a complete stop, then raise the tail off the ground with the engine at idle. I see you point about the thrust affecting pitch though, used that all the time landing the Lear, as you bring the power levers to idle the nose pitches up and automatically puts you into the flare. Allen But that 40-knot headwind is still lifting the wing, even with the airplane motionless, making it very easy for the elevator to lift the tail. The airplane is almost flying. Dan |
![]() wrote in message oups.com... Allen wrote: wrote in message ups.com... Allen wrote: I once saw a pair of mechanics doing a full power run-up in a Maule. They were holding brakes on and forward elevator, the tail was about six feet in the air standing still. So yes. Why do you separate the nosewheel from the tailwheel? They both fly with the same principles. Allen Aha, but you have to allow for the thrust line being so far above the drag line, which in this case is the ground where the wheels are locked. That thrust produces a pitching couple that raises the tail much more effectively than the down-elevator. If the pilot holds full forward elevator at the start of the takeoff roll, the tails of most taildraggers won't come up until some considerable forward speed is attained, and then the tail is rising mostly because the centre of pressure of the wing, being behind the mains, is lifting it. Using forward elevator will lift the tail sooner but it sure is not entirely responsible for the rise. Wheelbarrowing is also mostly caused by too-fast landing speeds, not just forward elevator. It's worse with flaps down because the wing's CP is ahead of the mains and is raising the tail. Down-elevator isn't even necessary at high-enough speeds. The nosewheels of most trikes is closer to the ground than the mains in level flight attitude, and will contact first with the high airspeed reducing AOA. Dan (Instructor in taildraggers and trikes and a mechanic too) I have seen a Super Cub land with a 40 knot (or so) headwind and come to a complete stop, then raise the tail off the ground with the engine at idle. I see you point about the thrust affecting pitch though, used that all the time landing the Lear, as you bring the power levers to idle the nose pitches up and automatically puts you into the flare. Allen But that 40-knot headwind is still lifting the wing, even with the airplane motionless, making it very easy for the elevator to LIFT THE TAIL. The airplane is almost flying. Dan Ah ha, the answer to the OP's question. Allen |
ps.com... Plus I'm pretty sure my statement was pretty odvious in it's direction to the original author... just like you said... your post had nothing to do with it. Sorry if I've caused irrperable offense. It should be apparent by my reply that it was *not* obvious. You replied to my post, rather than the one to which you were commenting, which made it look very much like you were addressing my post (even though you weren't). As far as your apology goes...there's no irreparable offense to apologize for, but you could instead simply apologize for not quoting, and posting in reply to the wrong post, causing confusion. Thanks, Pete |
ups.com... Yes, the elevetor generates lift, negative lift, 99.9% of the time, in stable flight. If you look at most diagrams of aircraft forces, you will see the CG with a force vector down, then behind that the center of lift with a force vector upwards. Finally, the elevator is usually drawn with a force vector downwards as well. In straight and level flight on most airplane designs, the elevator *does* provide a downward-directed force. So that's what is put in diagrams of aircraft forces by default. That doesn't mean that's what the elevator always does. I would say there is a distinction between tailwheels and tricycle gear aircraft. On a tailwheel, the CG is behind the main gear, on a tricycle gear plane the CG is in front of the main gear. In the air, the location of the CG relative to the main gear is entirely irrelevant. Even on the ground, the location of the CG relative to the main gear has nothing to do with what aerodynamic forces the elevator can generate. Thanks for the example of the outside loop, I understand now. While observing the range of stabilator deflection on a PA28, it seems to be able to generate a _heck_ of a lot more downward force than upward force, but apparently upward force is possible as well. I haven't looked closely, but I'm pretty sure that a typical design for a horizontal stabilizer is to give it an angle of incidence that provides for some preferred amount of downward force in straight and level cruise flight. Assuming symmetrical deflection of the elevator up or down, this would limit the upward force to something less than the downward force. Of course, this design restriction could be avoided by providing greater downward deflection by the elevator than upward. Pete |
Air Force Aerial Refueling Methods: Flying Boom versus Hose-and-Drogue | Mike | Naval Aviation | 26 | July 11th 06 11:38 PM |
Air Force FB-22 Bomber Concept - CRS | Mike | Naval Aviation | 2 | June 18th 06 09:32 PM |
Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 02:39 AM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
