Accident report - PDA's can restrict emergency exit
Old December 9th 06, 07:51 PM posted to rec.aviation.soaring
Simon Taylor
Default Accident report - PDA's can restrict emergency exit
At 14:36 08 December 2006, T O D D P A T T I S T wrote:
new mac laptop and they made the
power cord attach w/a magnet, to keep the computer
from hitting the
ground when someone trips on the power cord.
My wife has a hot pot that constantly holds near-boiling
water and dispenses with a pump on request. It uses
one of
those magnetically attached power cords to prevent
anyone
from getting burned if you trip over the cord. They
must be
sold somewhere.
T o d d P a t t i s t - 'WH' Ventus C
(Remove DONTSPAMME from address to email reply.)
Wouldn't the magnet ideas cause compass issues?
Old December 12th 06, 08:22 AM posted to rec.aviation.soaring
Bert Willing
Ever tried to pull off an USB connector by pulling across ?!
Any cable on the canopy system is a serious thread.
"ContestID67" wrote in message
Interesting topic. I had considered putting the PDA on the rail of the
canopy.
One possible simple "break away" connector that was recently
recommended to me is a USB connector. They are simple and inexpensive
gold plated slide connectors with four contacts. Purchase a USB
"extension cord" which has a male and a female connector (don't ask me
which is which). Cut the cord in the middle and splice it into your
serial connection to the PDA
All you need are four connections;
USB Pin 1 - Power +5Vdc - DB-9 pin 8 (may be vendor specific)
USB Pin 2 - Transmit - DB-9 pin 2
USB Pin 3 - Recieve - DB-9 pin 3
USB Pin 4 - Ground - DB-9 pin 5
Anyway, if you cut the PDA cradle cable, there should only be four
wires. Three may be a shield which you should connect to the shield of
the USB. Connect each to whatever you want at the USB connector and
call it the "fill in your last name proprietary cabling standard".
- John
Old December 12th 06, 08:48 PM posted to rec.aviation.soaring
Ian[_1_]
On Tue, 12 Dec 2006 09:22:59 +0100, Bert Willing wrote:
Ever tried to pull off an USB connector by pulling across ?! Any cable on
I have a Volkslogger mounted on the canopy frame of our LS3a. I spliced a
male/female pair of "mic" cables into the wire connecting it to the
battery such that they will part if the canopy is jettisoned. Some
comments:
- The screw retaining ring on the plugs has been removed.
- The cables on either side of the plugs are secured onto the support post
and canopy frame respectively with cable ties. The geometry is such that
if the canopy jettison latch is released the load on the wires will always
be axial which quickly pulls the plugs apart.
- There is a small loop in the cable to allow just enough slack for the
canopy to open on its "parallelogram" mechanism without the cable becoming
tight.
- When the canopy is closed the loop forms in a location where it can't be
easily kicked loose on entry/exit or in flight.
- A fair amount of planning and testing went into getting it to work
just right. These installations are easier to wrong than right.
I have tested it a number of times by taking the canopy off without
first releasing the cable. It always pulls out cleanly without any force
or damage. On the flip side we have yet to loose a trace due to the wire
coming loose when it is not supposed to.
My mic plugs have 4 pins, of which I am using two so there are two spare.
When I finally get around to installing a PDA I have some options to
use the same cable for PDA power etc.
But when we installed a Flarm I avoided mounting it on the canopy because
that would have required a second plug set for the remote display cable.
Getting this to work side by side with the existing cable looked a bit
tricky.
If I did it again I would experiment with RJ45 plugs with the
locking tabs broken off. It may be possible to mount two cables in
parallel to have enough pairs to meet future requirements.
Regards
Ian
Old December 20th 06, 06:00 PM posted to rec.aviation.soaring
Jim Vincent
I also used male and female sterop plugs for the connections made to the
canopy.
The issue that's been bugging me is what to do with the external catheter.
In the flurry of an egress, it does take a few moments to disconnect the QD
from the drain tubing. Maybe a winter project is a small spring loaded
guillotine below the seat pan that would cut the drain tubing.
"Ian" wrote in message
news
comments:
tight.
tricky.
Regards
Ian
Old December 20th 06, 06:09 PM posted to rec.aviation.soaring
01-- Zero One
Jim, let's not discuss spring-loaded guillotines and pee tubes in the
same thread! :-)
Larry
"01" Zero One
USA
"Jim Vincent" wrote in message
canopy.
news
comments:
tight.
tricky.
Regards
Ian
Old December 21st 06, 05:45 PM posted to rec.aviation.soaring
Jim Vincent
I just did some calculations considering accelerations, masses and mechanics of materials. It turns out that if I stay connected to the pee tube and bail out at under 103 kts, the force of the bail out will extend my penis by 2.8" before the latex tubing breaks (in colder temperatures the max bailout speed does drop). Well, that extension of 2.8" falls just between the elastic and yield (not ultimate) values of my penis, so after extending out by 2.8", my penis will retract by 1.6" for a net permanent gain of 1.2" Mind you, 1.2" is only about a 10% increase over current length, but that's OK too. ;-)
However, after some feedback from some friends, I decided it is best to only connect the quick disconnect when I have to use the pee tube. No need for the guillotine.
"01-- Zero One" wrote in message . ..
Jim, let's not discuss spring-loaded guillotines and pee tubes in the same thread! J
Larry
"01" Zero One
USA
"Jim Vincent" wrote in message :
canopy.
news
comments:
tight.
tricky.
Regards
Ian
Old December 21st 06, 06:57 PM posted to rec.aviation.soaring
bumper
Real glider pilots have no need for pee tubes, quick connects, funnels,
misc. plumbing parts etc. Why do you think they installed that storm window
so low on the canopy side instead of directly overhead?
Just be sure to slow to below 60 knots prior to "gear" extension to avoid
the possibility of flutter - - guaranteed to be an unpleasant experience.
Frostbite, though rare, can be nasty.
bumper
OK too. ;-)
the guillotine.
thread! J
Larry
"01" Zero One
USA
canopy.
QD
news
on
a
comments:
post
always
becoming
tight.
be
spare.
because
tricky.
Regards
Ian
Old December 21st 06, 07:04 PM posted to rec.aviation.soaring
And L\D refers to Length\Diameter?
Bob
Old December 21st 06, 07:36 PM posted to rec.aviation.soaring
Nyal Williams
Oh, my!
We didn't get to this conversation until February,
a couple of years ago.
That one was finished by some PW-5 pilot who claimed
to 'tap it' with the rudder.
connects, funnels,
that storm window
Just be sure to slow to below 60 knots prior to 'gear'
extension to avoid
bumper
'Jim Vincent' wrote in message
to the pee tube and
2.8' before the latex tubing breaks (in colder temperatures
the max bailout
speed does drop). Well, that extension of 2.8' falls
just between the
by 2.8', my penis will retract by 1.6' for a net permanent
gain of 1.2'
Mind you, 1.2' is only about a 10% increase over current
length, but that's
OK too. ;-)
it is best to only
the guillotine.
'01-- Zero One' wrote in message
thread! J
Larry
'01' Zero One
USA
made to the
canopy.
to disconnect the
QD
tubing.
'Ian' wrote in message
news
across ?! Any cable
on
a
male/female pair of 'mic' cables into the wire connecting
it to the
jettisoned. Some
comments:
removed.
onto the support
post
on the wires will
always
canopy to open on its 'parallelogram' mechanism without
the cable
becoming
tight.
where it can't
be
getting it to work
than right.
canopy off without
without any force
so there are two
spare.
some options to
it on the canopy
because
cable looked a bit
tricky.
with the
two cables in
Regards
Ian
Who's At Fault in UAV/Part91 MAC? Larry Dighera Instrument Flight Rules 24 April 29th 04 03:08 PM
Single-Seat Accident Records (Was BD-5B) Ron Wanttaja Home Built 41 November 20th 03 05:39 AM
HH-60 ACCIDENT REPORT RELEASED Otis Willie Military Aviation 0 July 4th 03 03:06 AM
