degaussing for compass
Old December 8th 06, 10:06 PM posted to rec.aviation.piloting
Neil Gould
Default degaussing for compass
Recently, nrp posted:
It may be a more tricky task than it appears, since to
degauss the object one has to apply exactly?
Degaussers work from line power by generating a strong 60 Hz
alternating flux which is slowly decreased in intensity by removing
the degausser coil away from the subject.
My over-generalization was in response to the typical use of a magnetic
tape degausser where the size of the coil is much larger than the item
being degaussed and the purpose is only to randomize the magnetic
alignment of the oxide particles. In that use, residual magnetism isn't
critical, but I don't think it would be the same for magnetized bars (the
braces) that are much *larger* than the coil.
I'd remove the compass and
any electronics first though for that reason.
I'd think a strong or larger degausser could be temporarily made from
a 500 ft coil of three conductor (plus ground) # 14 romex wiring
cable. The ends should be connected to make a 2000 ft coil, and the
whole mess tied together with tie wraps. As an alternate the whole
mess could be made with 3 conductor extension cords. & a suicide
plug/socket arrangement.
Has anyone ever tried something like this?
Well... I still think it would be better to remove the braces from the
plane first. Using that size coil in-situ sounds risky.
Neil
Jim Macklin
AC 43.13-1 5-28
a. Demagnetization. Demagnetize between
successive magnetization of the same
part, to allow finding defects in all directions,
and whenever the residual magnetism interferes
with the interpretation of the indications.
Also, demagnetize all parts and materials after
completion of magnetic particle examination.
Test all parts at several locations and parts for
residual magnetism of complex configuration
at all significant changes in geometry. Repeat
demagnetization if there is any appreciable deflection
of the field indicator needle.
(1) AC method. Hold the part in the
AC demagnetizing coils and then move the
part slowly and steadily through the coils and
approximately 3 to 4 feet past the coils. Repeat
this process until the part loses its residual
magnetism. Rotate and tumble parts of complex
configuration as they are passed through
the coils.
(2) DC method. Place the part in the
same relative position as when magnetized and
apply reversing DC current. Gradually reduce
the current to zero and repeat the process until
the residual magnetic field is depleted.
You can make a loop of heavy insulated wire
"john smith" wrote in message
| Degaussing an airframe is not quite the same as degaussing
a magnetic
| tape or CRT.
| I have "heard" of people doing it with a 110VAC line and a
100W light
| bulb for a load.
Old December 8th 06, 11:53 PM posted to rec.aviation.piloting
Jim Macklin
No
"Jose" wrote in message
| ...I'd remove the compass and any
temporarily made...
| Is degaussing an airplane considered by the FAA as
something that an
| owner/pilot could do?
| Jose
| "There are 3 secrets to the perfect landing.
Unfortunately, nobody knows
| what they are." - (mike).
| for Email, make the obvious change in the address.
Old December 9th 06, 02:41 PM posted to rec.aviation.piloting
nrp
What's a reversing DC current?
Old December 9th 06, 03:17 PM posted to rec.aviation.piloting
Blueskies
"nrp" wrote in message ups.com...
: (2) DC method. Place the part in the
: same relative position as when magnetized and
: apply reversing DC current.
: What's a reversing DC current?
Just opposite polarity...
Old December 9th 06, 05:05 PM posted to rec.aviation.piloting
Jim Macklin
opposite polarity, switch direction manually. Use less
current (amps) with each cycle. There are machines that do
this automatically, but you can rig up something to do it
from odd bits and pieces.
Old December 9th 06, 07:03 PM posted to rec.aviation.piloting
nrp
this automatically,
Isn't this the 60 Hz line? Just withdrawing the coil will fade the
cyclic magnetic flux.
BTW I had in mind a several ft diameter for the #14 wire concept, so
that a steel tube fuselage could be degaussed.
Old December 9th 06, 11:51 PM posted to rec.aviation.piloting
Jim Macklin
There are direct current machines for doing magnetic
particle inspection [MagnaFlux] and these machine do have a
built in degaussing procedure with DC current.
Yes, a large coil with AC can be used to degauss by
withdrawing the coil to several feet. Putting a tool or
tube in the AC field and switching OFF will magnetize
because the induced field is cut suddenly.
do
it
| this automatically,
fade the
concept, so
Old December 10th 06, 04:28 PM posted to rec.aviation.piloting
RST Engineering
That works ... sort of. How much magnetism (if any) you get, and of which
polarity is a function of where in the waveform the coil is when you switch
the current off.
Degaussing a Warrior DavidM Owning 22 November 8th 05 12:01 AM
