joining the traffic pattern quandary
Old January 4th 05, 02:52 PM
Greg Esres
So if a RIGHT turn is permitted by the FARs onto downwind, then so
must a RIGHT turn onto final (where left traffic in effect).Hence the
quandary
There is no quandary.
The 45 right-turn entry into downwind is recommended by the AIM and
would not be so if it had ever been held to be illegal.
Once in the pattern, left turns are mandatory unless the stated ground
signals exist, if it's an untowered airport.
What's so hard about this?
then I could do a 90 degree right turn onto short final,
where left pattern is in effect.
No, you couldn't. Pilots have been violated for this and it has been
upheld by the NTSB. You would have to intercept final at a
"considerable" distance from the runway in order to not be "in the
pattern." The distance depends on what type of airplane you're
flying.
Old January 4th 05, 05:14 PM
Rob Montgomery
Let me make sure I understand this. The FAA wrote the rules, and the FAA
wrote the AIM. Therefore, the FAA must have determined that which is in the
AIM complied with the rules... until the FAA changes it's mind. So sayeth
the FAA. :-)
My understanding is that all of this "advisory" literature (the AIM, the
Advisory Circulars, etc.) are supposed to advise you of a way (but not,
necessarily, the only way) to comply with the regulations. I know of cases
where people have been hauled in for "violations" only to be let off because
they pointed out an advisory that explicitly said that they could do what
they were accused of.
All that being said, I still think the Canadian method (mid-field
crosswinds) is better.
Just my two cents.
-Rob
"Greg Esres" wrote in message
quandary
flying.
Old January 4th 05, 05:20 PM
On Tue, 4 Jan 2005 11:14:57 -0500, "Rob Montgomery"
the FAA. :-)
Or, more precisely, one hand of the FAA wrote the rules, while another
hand of the FAA wrote the AIM, and sometimes, the left hand doesn't
know what the right hand is doing.
Steven P. McNicoll
"Rob Montgomery" wrote in message
the AIM complied with the rules... until the FAA changes it's mind. So
sayeth the FAA. :-)
The 45 degree turn to downwind violates the letter of the law regardless
what the FAA sayeth.
Old January 5th 05, 01:33 PM
Greg, Gene, Roy, Steven, or anyone out the
Is there a database or such anywhere that lists the violations that
have occurred over the past month, or year, or 10 years?
I've heard plenty that "others have been violated for that" , or "you
can get violated for that", over such items as:
"incorrectly entering the circuit"
"landing below vis limits, but not below rvr limits"
"departing without required obstacle clearance gradients"
"not having a weight and balance prepared"
Now before Steven or others join in to tell me the above are not
violations of the FARs, I've just said that that is what I've "read".
Mostly news group.
And thus I ask, any list of violations that one can peruse, or web
site that lists enforcement actions, that we can use as a guide as to
what the FAA is really enforcing?
Stan
been regulations that those who were found to be in violationOn Tue,
upheld by the NTSB.
Old January 4th 05, 02:58 PM
Roy Smith
Thanks, Roy
As I've just posted to Bob, if "approaching to land" means "already in
the pattern", then I could do a 90 degree right turn onto short final,
Hence the quandary
Well, like I said, you need to apply common sense. Somebody just posted
about this instrument approach:
http://www.airnav.com/depart?http://...00379LDBCA.PDF
Let's say you're coming in from San Marcus. What are you supposed to do
when you reach KOAKS? You make a (gasp) right turn onto final. Surely
you're "approaching to land", since you're flying an approach procedure.
Are you going to worry that the runway may have a left traffic pattern and
therefore 91.126 won't let you make a right turn? Of course not.
You need to apply common sense. If you're going to look for
inconsistencies and stupidities in the FARs, you'll spend your whole life
getting hung up on stuff like this.
Old January 4th 05, 03:05 PM
William W. Plummer
Roy Smith wrote:
Thanks, Roy
Hence the quandary
Well said, Roy. Experience brings confidence and judgment. Reliance
on rigid reading of laws is just the start.
Old January 4th 05, 03:12 PM
Steven P. McNicoll
"Roy Smith" wrote in message
§ 91.126 Operating on or in the vicinity of an airport in Class G
airspace.
(a) General. Unless otherwise authorized or required, each person operating
an aircraft on or in the vicinity of an airport in a Class G airspace area
must comply with the requirements of this section.
If an IAP requires a right turn to the final approach course you're clearly
"otherwise authorized or required".
Old January 4th 05, 04:00 PM
Roy Smith
True enough. And making a right turn from the 45 to left downwind is
just as clearly required.
AOPA and ATC Privatization Chip Jones Instrument Flight Rules 139 November 12th 03 09:26 PM
Requirement to fly departure procedures [email protected] Instrument Flight Rules 77 October 15th 03 07:39 PM
Riddle me this, pilots Chip Jones Instrument Flight Rules 137 August 30th 03 05:02 AM
