Commercial 250nm VFR flight - all 3 landings on the same day?
Old December 16th 06, 01:40 PM posted to rec.aviation.piloting,rec.aviation.ifr
Jim Macklin
Default Commercial 250nm VFR flight - all 3 landings on the same day?
The long flight does NOT have to be on the same day, it is
acceptable to have a stop, but it must be as it says below
[regulation] landings at three places, with one a straight
line of 250 NM. I would log the flight as stages, with the
citation of 61.129 in the remarks, with notes that it was a
continuous trip, with stops at three airports. This may
have already been meet with you previous experience. I
would endorse you on the trips you listed, but the issue is
what the designated examiner wants. Ask your CFI who he
would send you to for the test and then both of you should
speak to the eaxminer. But nowhere in the regulation does
it say "one day" so as long as the flights are all legs
longer than 50 miles and the longest is 250 miles straight
line from the departure, you should be OK.
Be sure the flights are SOLO, no passengers allowed, no dual
allowed.
http://ecfr.gpoaccess.gov/cgi/t/text...4/14tab_02.tpl
§ 61.129 Aeronautical experience.
(a) For an airplane single-engine rating. Except as provided
in paragraph (i) of this section, a person who applies for a
commercial pilot certificate with an airplane category and
single-engine class rating must log at least 250 hours of
flight time as a pilot that consists of at least:
(1) 100 hours in powered aircraft, of which 50 hours must be
in airplanes.
(2) 100 hours of pilot-in-command flight time, which
includes at least-
(i) 50 hours in airplanes; and
(ii) 50 hours in cross-country flight of which at least 10
hours must be in airplanes.
(3) 20 hours of training on the areas of operation listed in
§61.127(b)(1) of this part that includes at least-
(i) 10 hours of instrument training of which at least 5
hours must be in a single-engine airplane;
(ii) 10 hours of training in an airplane that has a
retractable landing gear, flaps, and a controllable pitch
propeller, or is turbine-powered, or for an applicant
seeking a single-engine seaplane rating, 10 hours of
training in a seaplane that has flaps and a controllable
pitch propeller;
(iii) One cross-country flight of at least 2 hours in a
single-engine airplane in day VFR conditions, consisting of
a total straight-line distance of more than 100 nautical
miles from the original point of departure;
(iv) One cross-country flight of at least 2 hours in a
single-engine airplane in night VFR conditions, consisting
of a total straight-line distance of more than 100 nautical
miles from the original point of departure; and
(v) 3 hours in a single-engine airplane in preparation for
the practical test within the 60-day period preceding the
date of the test.
(4) 10 hours of solo flight in a single-engine airplane on
the areas of operation listed in §61.127(b)(1) of this part,
which includes at least-
(i) One cross-country flight of not less than 300 nautical
miles total distance, with landings at a minimum of three
points, one of which is a straight-line distance of at least
250 nautical miles from the original departure point.
However, if this requirement is being met in Hawaii, the
longest segment need only have a straight-line distance of
at least 150 nautical miles; and
(ii) 5 hours in night VFR conditions with 10 takeoffs and 10
landings (with each landing involving a flight in the
traffic pattern) at an airport with an operating control
tower.
"Peter" wrote in message
|I cannot find an answer on the FAA Q&A site (the one with
the personal
| login, but which in fact appears to be rather bare), so I
wrote to
| them. However they often don't reply with anything
meaningful, so I
| would appreciate any references anybody here can dig out.
| I am doing the CPL in the UK and the CFI says that it all
needs to be
| done on the same day. The winter weather here is dreadful
and doing a
| ~ 600nm trip (there and back) under VFR is quite
difficult, unless I
| skirt around the coastline at low level, on autopilot, all
the way to
| Scotland. I have the IR also but can't really do it that
way It's
| also a waste of a lot of fuel for what might be a
pointless logbook
| entry.
| This is what I wrote to them:
| I am doing the FAA commercial certificate, and need
guidance on the
| 250/300nm VFR solo flight with three landings.
| I have about 700 hours and have flown all over Europe, and
have lots
| of flights in my logbook which are along the lines of
| 500nm
| 500nm
| 2 days' stop
| 500nm
| 500nm
| Some get closer to a 1-night stop:
| 25/8/03 EGBW LFBT 544NM
| 26/8/03 LFBT EGBW
| 26/8/03 EGBW EGKB
| or are much longer than 300nm GC distance:
| 31/8/03 EGKA LFBZ 444NM
| 31/8/03 LFBZ LEAX 417NM
| 3/9/03 LEAX LFBZ
| 3/9/03 LFBZ EGKA
| and some have a number of landings but never 3 on the same
day:
| 12/9/04 EGKA LSZG 374NM
| 12/9/04 LSZG LSPV 59NM
| 16/9/04 LSPV LSGS
| 16/9/04 LSGS LSPV
| 17/9/04 LSPV LGKR 690NM
| 18/9/04 LGKR LGST
| 23/9/04 LGST LGKR
| 24/9/04 LGKR LFKB
| 25/9/04 LFKB EGKA
| etc
| I cannot find a flight which has all 3 landings on the
*same* day.
| Also, is it necessary for all 3 landings to be at
different airports?
| Recently, somebody sent me this, purporting to come from
John Lynch
| himself, but I cannot find an online reference to it. I
have tried
| googling on various verbatim phrases from it but nothing
turns up.
| Quote:
| QUESTION: A question has come up regarding §
61.129(a)(4)(i) from an
| examiner in our district.
| A private pilot conducted a cross-country flight from
Pompano, Fl to
| Virginia making ONE stop in South Carolina. He stayed
overnight visiting friends
| and the next day he returned to Florida using the
reverse route. He now wants
| to apply this cross-country flight to meet the
requirement for §
| 61.129(a)(4)(i).
| The questions a 1) If this is one flight, how many
days can elapse and
| still be counted as one flight? i.e. one night, three
nights, 2 weeks, 1
| month, etc?
| ANSWER: Ref. § 61.129(a)(4)(i) and § 61.1(b)(3)(ii);
Yes, it is a good
| cross-country. This cross-country can be counted for §
61.129(a)(4)(i) purposes
| and also for § 61.65(d)(1) purposes.
| If my geography is correct, a cross-country flight from
Pompano, Florida to
| Virginia and return is a ". . . cross-country flight of
not less than 300
| nautical miles total distance." And the first stop in
South Carolina is ". . .
| at least is a straight-line distance of at least 250
| original departure point" (i.e., Pompano, Florida). And
the cross-country
| flight involved ". . . landings at a minimum of three
points . . ." (i.e.,
| airport at South Carolina, Virginia, and Pompano,
Florida). Yes, the landing on
| the return trip back to Pompano, Florida counts as one
of the 3 landings.
| {Q&A-433}
| Peter.
| Return address is invalid to help stop junk mail.
| E-mail replies to but remove
the A and the B.
| Please do NOT copy usenet posts to email - it is NOT
necessary.
CFI without commercial? Jay Honeck Piloting 75 December 8th 10 04:17 PM
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 27th 04 11:49 PM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 01:27 PM
