Direct to intermediate approach fix?
Old December 17th 06, 03:28 AM posted to rec.aviation.ifr
Roy Smith
Default Direct to intermediate approach fix?
Sam Spade wrote:
Clearances
direct-to the IF on RNAV approaches is now legal provided certain
protocols are observed.
It has been in the AIM for perhaps a year now. ;-)
What are the protocols? I just took a look through what I thought were the
likely parts of the AIM and didn't find anything about this. Do you have a
specific section I should look at?
In any case, if they're allowed to clear you direct to an IF, then the
databases should start including the IFs in the "where do you want to start
the approach from?" menus.
Old December 17th 06, 04:35 AM posted to rec.aviation.ifr
Stan Prevost
Just to be clear, it applies only to RNAV approaches and an RNAV-capable
aircraft. The ILS approach you were on does not meet that criterion.
The 7110.65 provides for controllers to issue the instruction. It is 5-4-7i
in the AIM.
"Roy Smith" wrote in message
Sam Spade wrote:
Clearances
a
start
Old December 17th 06, 04:55 AM posted to rec.aviation.ifr
Roy Smith
in the AIM.
Ah, thanks. 5-4-7-i says:
i. ATC may clear aircraft that have filed an Advanced RNAV equipment suffix
to the intermediate fix when clearing aircraft for an instrument approach
procedure. ATC will take the following actions when clearing Advanced RNAV
aircraft to the intermediate fix:
1. Provide radar monitoring to the intermediate fix.
2. Advise the pilot to expect clearance direct to the intermediate fix at
least 5 miles from the fix.
NOTE-
This is to allow the pilot to program the RNAV equipment to allow the
aircraft to fly to the intermediate fix when cleared by ATC.
Which is fine. If the guy had told us 5 miles earlier, "expect direct
FARAN", that would have given us a couple of minutes to set the box up.
I'm not going to pick nits about RVAV vs. ILS, I'm just looking for a the
time it takes to do all the button pushing I have to do to comply with his
instruction.
The other thing I don't understand is why the controller preferred "direct
FARAN" to "fly heading 200 to intercept the localizer". They both boiled
down to about the same ground track. They both required that he monitor
our progress on radar. The heading to intercept was certainly easier for
us to execute. Was there some advantage to the controller to issue it the
way he did?
Old December 17th 06, 07:55 AM posted to rec.aviation.ifr
Stan Prevost
5-4-7i
in the AIM.
suffix
NOTE-
instruction.
way he did?
Not sure why you call it a nit. Your question related to whether the
instructions you received were legit. They were not. They were not issued
in accordance with the 7110.65 which is quite clear on this. When the rule
was changed to allow vectors to an IF, it was very specifically limited to
RNAV approaches.
From the 7110.65:
4-8-1. APPROACH CLEARANCE
snip
b. For aircraft operating on unpublished routes, issue the approach
clearance only after the aircraft is:
...........snip
4. Established on a heading or course that will intercept the intermediate
segment at the intermediate fix, when an initial approach fix is published,
provided the following conditions are met:
(a) The instrument approach procedure is a GPS or RNAV approach.
(b) Radar monitoring is provided to the Intermediate Fix.
(c) The aircraft has filed an Advanced RNAV equipment suffix.
(d) The pilot is advised to expect clearance direct to the Intermediate Fix
at least 5 miles from the fix.
(e) The aircraft is assigned an altitude to maintain until the Intermediate
Fix.
(f) The aircraft is on a course that will intercept the intermediate segment
at an angle not greater than 90 degrees and is at an altitude that will
permit normal descent from the Intermediate Fix to the Final Approach Fix.
Note that (d) addresses your concern for more advance notice.
This controller did not seem to understand the rule, as did not the one who
gave me direct to an IF on a non-RNAV approach. The controller also did not
seem to know the IAP, based on your statement about his thinking FARAN was
an IAF.
Another "nit" is that your instructions did not meet the criteria for
skipping the PT.
Old December 17th 06, 11:37 AM posted to rec.aviation.ifr
Ron Rosenfeld
On Sat, 16 Dec 2006 18:15:32 -0800, Sam Spade wrote:
Roy Smith wrote:
If they want to send people direct to FARAN (which they often do), why
don't they just declare FARAN to be an IAF? Then it would get into the
database that way, it would show up on everybody's IAF menus, and we would
all be happy campers.
We went through all this perhaps a year ago on this group. Clearances
It seems that although the AIM does not restrict this to RNAV approaches,
there is such a restriction in the controllers manual 7110.65R, at least
the version currently on the web.
Am I missing something here?
Old December 17th 06, 03:51 PM posted to rec.aviation.ifr
Sam Spade
way he did?
Stan is right, this is for RNAV only. I missed the part about the ILS
in your original post.
The likely reason the controller used the procedure for the ILS is
because controllers have a way of bending the rules to suit their
personal perception of things. When the proposal was discussed between
the FAA and industry user groups, some proposed making it okay for all
types of approaches that have intermedite fixes. The FAA wheel in
charge said he did not want to to be used with other than RNAV because,
unless you have RNAV, you can't get there on a ground-based IAP.
Someone else said controllers would do it anyway for all type of IAPs
with /G aircraft. ;-)
In the case of an ILS, they are always video mapped where TRACON has
coverage, and vectors to final are the rule except for the full
approach. But, your controller obviously was lazy.
A radar monitor is a whole lot easier than a vector and sometimes they
don't even monitor the track. In fact, in the case of RNAV IAPs the IF
often is not on the video map so it is a wag on their part in any case.
Old December 17th 06, 04:48 PM posted to rec.aviation.ifr
Robert Chambers
Also NY Tracon management has a "quality assurance" office which one of
the guys gave us numbers for back at a safety meeting. When I got
verbally berated for flying legally I called that number and spoke to an
individual. Gave him date/time/tail number and where I talked to the
controller and they pulled the tapes.
As a quality assurance issue you might want to express your misgivings
as to being given an awkward at the least and possibly dangerous at the
worst clearance.
Robert
Bob Gardner wrote:
One of the ways to educate controllers is by using ASRS. When the NASA guys
at Moffet Field call NY TRACON, the offending controller(s) will get the
word.
Bob Gardner
Yesterday, we had filed /G (with a CNX-80). Our clearance was KPOU IGN
V157 HAARP -D- KHPN. Nothing out of the ordinary there.
HPN was using the ILS-16 (http://204.108.4.16/d-tpp/0612/00651I16.PDF) We
were on V157 somewhere north of VALRE when we got "fly heading 200 to
intercept, um, no, tell you what, proceed direct FARAN, cleared ILS-16".
This is a pretty common thing for NY Approach to say, but as I study the
chart now, I don't think it's legit.
I asked NY Approach for an initial heading to FARAN and got back an
annoyed
sounding, "it's the initial approach fix" (along with a 200 heading). The
problem is, it's NOT an IAF. Which means that you can't pick it out of
menu of IAFs for the approach. And since it wasn't on our original route,
you can't pick it out of the flight plan. You need to spell it out letter
by letter from the database (which takes a while, hence the request for an
initial heading).
The alternative would be to select IGN as the IAF from the approach menu,
execute that, then go into the flight plan and select direct to FARAN.
Except that it takes a while to figure that out, and I'm not even sure if
the box will let you do it.
It was my understanding that there's only two legit ways to clear a flight
for an approach -- give them direct to an IAF, or give them vectors to the
FAC. In this case, "direct FARAN, cleared ILS" is neither. Am I correct
that this is a bum clearance?
Old December 17th 06, 07:04 PM posted to rec.aviation.ifr
Newps
Ron Natalie wrote:
Newps wrote:
NASA guys at Moffet Field call NY TRACON, the offending controller(s)
will get the word.
You'd be much better off calling the TRACON.
Ask for the QA guy. They will research it and get you an answer.
QA or any supervisor. Give them the date and time so they can go listen.
Old December 18th 06, 12:16 AM posted to rec.aviation.ifr
Steven P. McNicoll
"Sam Spade" wrote in message
The likely reason the controller used the procedure for the ILS is because
controllers have a way of bending the rules to suit their personal
What rules are you referring to?
Old December 18th 06, 12:27 AM posted to rec.aviation.ifr
Sam Spade
7110.65P 4-8-1 b. 4.
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 07:31 PM
GPS approach question Matt Whiting Instrument Flight Rules 30 August 29th 08 04:54 AM
Where is approach good about multiple approaches and clearances in the air? Andrew Gideon Instrument Flight Rules 29 February 14th 04 03:51 AM
Study pilot workload during approach and landing Freshfighter Piloting 5 December 7th 03 05:06 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 10:03 PM
