#11
this would be probably the only scenario where i'd rather hit the
ground.... pilot's last thought was that he was in deep **** padum-ding Don Tuite wrote: Appalling, but hard to ignore. http://sfgate.com/cgi-bin/article.cg...AGU8N26CP4.DTL Don |
Google Map
I reckon the settling pond is the square thing at 36 59 15.23 W 121 32 07.07 N (There are smaller aeration ponds just south of it.) Hollister (K3O7) is at: 36 53 28.08 N 121 24 29.24 W The pond is about 5 miles from the departure end of Runway 31, just to the left of the runway heading. Don |
Guys, three people died out there today, let's show some sensitivity.
Hilton P.S.: They were from the Flight School at which Cecil's teaches. No doubt he knew at least the CFI. "mad8" wrote in message ups.com... this would be probably the only scenario where i'd rather hit the ground.... pilot's last thought was that he was in deep **** padum-ding Don Tuite wrote: Appalling, but hard to ignore. http://sfgate.com/cgi-bin/article.cg...AGU8N26CP4.DTL Don |
It's a very unfortunate accident. Life can be very cruel and even
experienced pilots sometimes end up in situations out of their control. My instructor and I rent airplanes from Nice Air and I have had many opportunities to talk to the instructor involved in this accident. He was a very competent pilot with very respectable amount of flight hours. He was the nicest person and having witnessed him instruct and talk about his career goals I know that he had a true passion for aviation. Artie Don Tuite wrote: Appalling, but hard to ignore. http://sfgate.com/cgi-bin/article.cg...AGU8N26CP4.DTL Don |
On 2006-12-20, Greg Farris wrote:
Actually, in a small plane, you would -usually- rather hit the ground. Water landings tend to be unhappy events in light aircraft, especially fixed gear singles. Some are unhappier than others though - man! They are unhappy events as in you don't get to use the plane afterwards - but water landings are surprisingly survivable. Fixed gear or retractible gear doesn't seem to make a lot of difference in ditchings. http://www.equipped.com/ditchingmyths.htm -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
Don Tuite wrote:
Appalling, but hard to ignore. http://sfgate.com/cgi-bin/article.cg...AGU8N26CP4.DTL Must...resist...dark humor... -- John T http://sage1solutions.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 Reduce spam. Use Sender Policy Framework: http://spf.pobox.com ____________________ |
Water landings tend to be unhappy events in light aircraft, especially fixed gear singles. Some are unhappier than others though - man! They are unhappy events as in you don't get to use the plane afterwards - but water landings are surprisingly survivable. Fixed gear or retractible gear doesn't seem to make a lot of difference in ditchings. http://www.equipped.com/ditchingmyths.htm Very good info. I now see that much less water is needed before you should carry floatation equepment--expecially since that can may the water a far better emergency landing choice in a lot of situations. Peter |
"John T" wrote in message
... Don Tuite wrote: Appalling, but hard to ignore. http://sfgate.com/cgi-bin/article.cg...AGU8N26CP4.DTL Must...resist...dark humor... -- John T http://sage1solutions.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 Reduce spam. Use Sender Policy Framework: http://spf.pobox.com ____________________ Very difficult. Perhaps impossible. The situation really stinks! Peter |
On Wed, 20 Dec 2006 10:45:47 -0000, Dylan Smith
wrote: On 2006-12-20, Greg Farris wrote: Actually, in a small plane, you would -usually- rather hit the ground. Water landings tend to be unhappy events in light aircraft, especially fixed gear singles. Some are unhappier than others though - man! They are unhappy events as in you don't get to use the plane afterwards - but water landings are surprisingly survivable. Fixed gear or retractible gear doesn't seem to make a lot of difference in ditchings. http://www.equipped.com/ditchingmyths.htm Maybe so and maybe not. You are playing the odds. I lost a good friend just a couple weeks ago when he apparently dug a float in while landing. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
fuel tank plumbing | pwm | Home Built | 18 | January 27th 05 04:54 AM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 161 | September 25th 03 07:35 AM |
#1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 03:04 AM |
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 09:14 AM |
