You either terminate with a missed approach or a landing. The missed
approach doesn't include a 'circle to land'. A clearance for a missed doesn't include a clearance for a circle, but one can certainly go missed after circling. Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
Jose wrote: You either terminate with a missed approach or a landing. The missed approach doesn't include a 'circle to land'. A clearance for a missed doesn't include a clearance for a circle, but one can certainly go missed after circling. Jose Just to be clear about this... Let's say the airport is using 34, and you're cleared by approach control for the ILS-16 circle to 34 in VFR conditions as a practice approach. It would be a very poor idea indeed for you to execute the circling maneuver, do a low approach, then decide to execute the published missed on your own. This would have you swimming upstream against the traffic on final for 34. If that's what you really want to do, make sure you verify your intentions with the tower. If there's no conflicting traffic, they should be able to let you do it, but that would be unusual. When I'm with a student, negotiating these sorts of things with ATC is part of my job. |
A Lieberma wrote: Was out doing approaches this morning to knock off the rust. Called into JAN approach and requested ILS approaches into HKS under visual rules. Was 5 miles outside Brenz final approach fix and received the clearance; Cleared for the ILS 16 approach or circle to land 34 Hawkins. Exactly what is expected for a circle to land? Should I jog over to the right of the runway on my descent and enter downwind? At what altitude? The airport terminal is immediately to the right as well as the tower. Winds were 290 at 8 knots under VMC. Allen With winds 290 @ 8, landing 16 vs. landing 34 means taking a 5 kt tailwind instead of a 5 kt headwind. It's a 5400 foot runway; you didn't say what you were flying, but I'm guessing 5400 feet is about 3 times what you really need. On a real approach in IMC (especially at night), I'd take the 5 kt tailwind over circling to land any day. But, if it's day VFR and you want to practice the CTL maneuver, you need to negotiate with the tower. If you're the only one around, they'll let you do anything you want. You can come down to the circling MDA of 940 MSL (598 AGL) on the ILS. Once you've got the runway in sight, you can maneuver to enter a left or right downwind at your option. If you have the runway in sight higher than the MDA, you can (and probably should) do your circling at that higher altitude. In reality, if there's any traffic at all, the tower will give you circling instructions. |
![]() -----Original Message----- From: A Lieberma ] Posted At: Friday, December 22, 2006 4:46 PM Posted To: rec.aviation.ifr Conversation: Cleared for the ILS 16 or circle to land 34 question? Subject: Cleared for the ILS 16 or circle to land 34 question? Was out doing approaches this morning to knock off the rust. Called into JAN approach and requested ILS approaches into HKS under visual rules. Was 5 miles outside Brenz final approach fix and received the clearance; Cleared for the ILS 16 approach or circle to land 34 Hawkins. Exactly what is expected for a circle to land? Should I jog over to the right of the runway on my descent and enter downwind? At what altitude? The airport terminal is immediately to the right as well as the tower. Winds were 290 at 8 knots under VMC. Allen Al, Since your question seems to be more about the mechanics of the process than the clearance terminology, my approach has always been to circle such that I can keep a visual on the landing zone. That typically means a left circle regardless of what the published traffic pattern might be. Since circle to land is published for a fixed altitude, I am assured of obstacle clearance no matter which direction I turn. I just prefer to keep the old Mk1 eyeball on the target throughout the approach. Circle to land at minimums is a very exciting end to a journey and usually reminds me exactly how small my bladder happens to be. I need all the advantage I can get so the left turns help out. |
"Jim Carter" wrote in news:001701c7262a$f464b0f0
$4b01a8c0@omnibook6100: Al, Since your question seems to be more about the mechanics of the process than the clearance terminology, my approach has always been to circle such that I can keep a visual on the landing zone. That typically means a left circle regardless of what the published traffic pattern might be. Since circle to land is published for a fixed altitude, I am assured of obstacle clearance no matter which direction I turn. I just prefer to keep the old Mk1 eyeball on the target throughout the approach. Circle to land at minimums is a very exciting end to a journey and usually reminds me exactly how small my bladder happens to be. I need all the advantage I can get so the left turns help out. Thanks Jim! Yes, when it's a long trip, anything to shorten the approach phase is always appreciated when "nature calls" *big smile*. I am used to circle to approach landings at my own airport, just never had one for opposite ends of the runway Allen |
On 12/22/06 21:11, A Lieberma wrote:
"Jim Carter" wrote in news:001701c7262a$f464b0f0 $4b01a8c0@omnibook6100: Al, Since your question seems to be more about the mechanics of the process than the clearance terminology, my approach has always been to circle such that I can keep a visual on the landing zone. That typically means a left circle regardless of what the published traffic pattern might be. Since circle to land is published for a fixed altitude, I am assured of obstacle clearance no matter which direction I turn. I just prefer to keep the old Mk1 eyeball on the target throughout the approach. Circle to land at minimums is a very exciting end to a journey and usually reminds me exactly how small my bladder happens to be. I need all the advantage I can get so the left turns help out. Thanks Jim! Yes, when it's a long trip, anything to shorten the approach phase is always appreciated when "nature calls" *big smile*. I am used to circle to approach landings at my own airport, just never had one for opposite ends of the runway The circle to land is required anytime the landing runway is more than a set number of degrees from the approach course (I can't remember the exact number of degrees - maybe 10 or 30?). Obviously, the runway opposite to the approach course would qualify ;-) Allen -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
Mark Hansen wrote:
The circle to land is required anytime the landing runway is more than a set number of degrees from the approach course (I can't remember the exact number of degrees - maybe 10 or 30?). Obviously, the runway opposite to the approach course would qualify ;-) 30 degrees for ground based, 15 for RNAV. Also, descent gradient limitations, straight-has to be to TDZ; circling just to MDA. And, a third, less often an issue, are limitations on the electronic guidance's proximity to the runway centerline, extended. |
Jim Carter wrote:
Since circle to land is published for a fixed altitude, I am assured of obstacle clearance no matter which direction I turn. I just prefer to keep the old Mk1 eyeball on the target throughout the approach. Just don't miss the occasional note that prohibits circling on one side of some airports. |
On 12/22/06 16:40, Jim Carter wrote:
-----Original Message----- From: A Lieberma ] Posted At: Friday, December 22, 2006 4:46 PM Posted To: rec.aviation.ifr Conversation: Cleared for the ILS 16 or circle to land 34 question? Subject: Cleared for the ILS 16 or circle to land 34 question? Was out doing approaches this morning to knock off the rust. Called into JAN approach and requested ILS approaches into HKS under visual rules. Was 5 miles outside Brenz final approach fix and received the clearance; Cleared for the ILS 16 approach or circle to land 34 Hawkins. Exactly what is expected for a circle to land? Should I jog over to the right of the runway on my descent and enter downwind? At what altitude? The airport terminal is immediately to the right as well as the tower. Winds were 290 at 8 knots under VMC. Allen Al, Since your question seems to be more about the mechanics of the process than the clearance terminology, my approach has always been to circle such that I can keep a visual on the landing zone. That typically means a left circle regardless of what the published traffic pattern might be. Since circle to land is published for a fixed altitude, I am Minimum altitude, not fixed, right? assured of obstacle clearance no matter which direction I turn. I just Actually, the IAP may prohibit circling to one side or the other. prefer to keep the old Mk1 eyeball on the target throughout the approach. Circle to land at minimums is a very exciting end to a journey and usually reminds me exactly how small my bladder happens to be. I need all the advantage I can get so the left turns help out. -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
I'm not sure why JAN approach was giving you landing instructions.
Shouldn't that be left for the HKS tower, after approach control had sequenced you in for the approach? "A Lieberma" wrote in message . 18... Was out doing approaches this morning to knock off the rust. Called into JAN approach and requested ILS approaches into HKS under visual rules. Was 5 miles outside Brenz final approach fix and received the clearance; Cleared for the ILS 16 approach or circle to land 34 Hawkins. Exactly what is expected for a circle to land? Should I jog over to the right of the runway on my descent and enter downwind? At what altitude? The airport terminal is immediately to the right as well as the tower. Winds were 290 at 8 knots under VMC. Allen |
Circle to land question | A Lieberman | Instrument Flight Rules | 33 | May 24th 05 04:22 AM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
One more question regarding great circle and two intersecting course. | Sims | Piloting | 7 | October 9th 03 07:25 PM |
Defensive circle | Dave Eadsforth | Military Aviation | 23 | October 9th 03 06:13 PM |
NACO charts - why have a reference circle? | Bob Gardner | Instrument Flight Rules | 5 | September 6th 03 01:15 PM |
