Flaps/spoilers on which sailplanes?
Old December 28th 06, 02:12 PM posted to rec.aviation.soaring
Robin Birch
Default Flaps/spoilers on which sailplanes?
At 01:18 28 December 2006, Tony Verhulst wrote:
I have the SSA's 'Directory of Sailplanes' from sometime
in the
1970s(?), which is a great resource for finding the
basics of certain
models of sailplanes, but I'm looking for something
more detailed on
glidepath control. For example, if I want to find
out if the Slingsby
Kestrel uses flaps or spoilers, or I want to find
out if the Phoebus C
uses flaps or spoilers, or...
Is there such a resource?
Ric T.
Hi, The Kestrel has flaps, airbrakes and chute. The
flaps have (given all the normal mods) two landing
flap positions which are independant of the normal
flying flap system in that they can be raised and lowered
without affecting the aileron setting.
The first position is roughly equivalent to full +2
flying flap, the second is about twice this.
There are then upper surface airbrakes. These are
fairly ineffective on their own but with flaps are
very good for control. There is a mod to add extra
depth to the paddles in the same way as Ciruses do.
If this isn't enough then there is a tail chute that
makes you feel like you are pointing straight down.
Between this lot there is a landing combination that
suits most eventualities.
By the manual, landing speed with flaps and airbrake
is 50 kts and with chute 55kts.
The various mechanisms to make all this work is what
gives the Kestrel its reputation for having loads of
knobs and levers.
Robin
Kestrel driver
A *great* but hard to find book is 'Sailplanes 1965-2000'
by Martin
Simons. See
http://home.comcast.net/~verhulst/GB...cellaneous.htm
Tony V.
Old December 28th 06, 02:41 PM posted to rec.aviation.soaring
Frank Whiteley
The Kestrel 19 landing flaps are half span. IIRC, the actual
deflection is 15 degrees in notch one and 35 degrees in notch two.
Notch one can be used for winch launching and results in about 200ft
additional height on a 4500ft run. Lotta drag and a lotta lift.
Frank Whiteley
in the
basics of certain
more detailed on
out if the Slingsby
Ric T.
knobs and levers.
Robin
Kestrel driver
by Martin
Simons. See
Tony V.
Vintage Sailplanes at Elmira, Aug 20-27 [email protected] Soaring 5 August 22nd 05 02:16 PM
Frise ailerons on sailplanes Mark James Boyd Soaring 24 February 25th 05 09:43 PM
Goal - Racing Sailplanes Article in Air and Space Magazine Snead1 Soaring 2 September 10th 04 03:55 PM
Russia Sailplanes website Willie Soaring 42 February 23rd 04 09:06 PM
New Sailplanes For the American Soaring Market? Dan Dawson Soaring 34 February 4th 04 12:16 PM
