Engine problem - Seneca II
Old January 5th 07, 01:42 AM posted to rec.aviation.piloting
Capt.Doug
Default Engine problem - Seneca II
"BDS" wrote in message
I wonder if the bearings could be changed out as opposed to replacing the
entire turbo.
Yes, along with the seals. However, when you pull the compressor off the
shaft to slide the bearings off, you disturb the balance. Balance is
critical at 130k rpm. Then there is that pesky FAA thing about engine
accessories having to be overhauled at a repair facility.
Do you use Marvel Mystery Oil?
D.
Capt.Doug
"Darkwing" wrote in message So what happens on a turbo
plane if you pull the power back real fast without a wastegate? On a car
if
the wastegate fails you can damage the engine.
The cylinders shock cool and crack with a strong pssibility of the heads
seperating from the barrels and/or seizure from the barrels shrinking around
the pistons.
I have had the distinct pleasure of driving a Lingenfelter Twin Turbo 01'
vette on more than one occasion, 650hp, 6 speed, BAD BAD BAD!!!
Sweeetttt!!!!
D.
Capt.Doug
"Scott Skylane" wrote in message That's correct, but it *does* have
pop-off boost valves.
So... I can firewall the throttle levers without overboosting the engines
on a Seneca 2?
D. (stock- as in from the factory)
Old January 5th 07, 02:20 AM posted to rec.aviation.piloting
Scott Skylane
on a Seneca 2?
Doug,
Doing so would exceed max rated M.P. by about 1". The Pop-offs are
designed to be last chance protection against overboost, and are not to
be relied upon in normal operation. See:
http://www.kellyaerospace.com/articl...bocharging.pdf
Look at the section titled "How do you spell relief" on page 8.
Happy Flying!
Scott Skylane
Old January 5th 07, 02:44 AM posted to rec.aviation.piloting
Capt.Doug
I remember 2 little lights in the upper middle of the instrument panel that
illuminate when overboosting. Are they activated by the PRV?
D.
Old January 5th 07, 11:01 AM posted to rec.aviation.piloting
Scott Skylane
D.
No, the P.R.V.'s (Pop-Offs) are purely mechanical in nature. They have
no electrical function.
Happy Flying!
Scott Skylane
Old January 5th 07, 03:45 PM posted to rec.aviation.piloting
BDS[_2_]
"Capt.Doug" wrote in message
entire turbo.
Not in this aircraft as of yet but I have used it in other non-turboed acft
in the past. Can it handle the heat of the turbo and do you think it might
help clean the bearings?
BDS
Old January 5th 07, 03:48 PM posted to rec.aviation.piloting
BDS[_2_]
engines
on a Seneca 2?
I think our overboost lights come on at just over 40 inches. I am pretty
sure you can go up to 42 for short periods, but I haven't tried. The
throttles on a stock Seneca II are quite sensitive - at sea level ours will
reach 40 in mp at about 75% of throw and you can get +/- 2 in by just
breathing on the throttles. Most of the time with the load and the runway
available I do not need to use more than 35 in so I don't even approach max
boost.
Old January 5th 07, 03:51 PM posted to rec.aviation.piloting
BDS[_2_]
"Kingfish" wrote in message
There were a few good suggestions from others already - Turbo bearing
coking does make sense, but you clearly know to let the turbo unspool
before shutdown so that might not be as likely. (IIRC there is a way to
clean up the turbo bearings without turbo removal if that's what it
turns out to be) My guess would be the fuel control unit gone wonky;
the fact that power returns after richening the mixture might back up
that theory, but what are the chances of both acting up simultaneously?
Maybe the alternate air diverter is partially open? Out of curiousity,
what CHTs are you seeing at 1425 EGT?
I know the fuel controls were double checked and adjusted when the problem
first came up. That doesn't mean they aren't the culprit, but they seem to
act normally when tested.
CHTs never get out of the green arc and typically remain at about 75% of the
scale.
BDS
Old January 6th 07, 01:41 AM posted to rec.aviation.piloting
Capt.Doug
acft
might
Don't know about turbocharged engines. I used it religiously in supercharged
R-985s, but that was to prevent sticking valves.
D.
So...about that plane on the treadmill... Ray Piloting 135 December 18th 06 11:30 PM
Engine noise recording in Motor Gliders Ian Strachan Soaring 2 October 16th 06 01:32 PM
light twins? Bellsouth News Server Home Built 83 August 12th 05 03:56 AM
ROP masking of engine problems Roger Long Piloting 1 September 25th 04 08:13 PM
Diesel engine Bryan Home Built 41 May 1st 04 08:23 PM
