Oil pressure problem
Old January 4th 07, 02:09 AM posted to rec.aviation.piloting
Aluckyguess
Default Oil pressure problem
"Capt.Doug" wrote in message
"Aluckyguess" wrote in message
I have a Bonanza V35 with a IO 470. Before and after engine overhaul the
oil
pressure after the engine warms up goes just into the red. They have
tried
turning the pressure up but this seems to only make the pressure go up
when
cold. If the temperature outside is real cool the pressure goes over 200
psi. The engine builder said its in spec. I think there is a problem
somewhere. I want the oil pressure to run in the green. Does anybody have
any ideas on what could be causing this.
Start first by checking calibration on your oil pressure guage.
Gage was sent out for calibration and it was good.
Then check the bypass valve for proper operation (a good rebuilder will
have
replaced it).
I will ask about this.
Ask the rebuilder to see his records for bearing/crankshaft clearance
measurements because the pressure is going out the gaps.
I'm afraid its going to blow the gage out one cold morning.
More likely to blow out an oil cooler.
D.
Old January 4th 07, 02:10 AM posted to rec.aviation.piloting
Aluckyguess
I am in Southern Ca. Engine now has over 200 hours and burns no oil.
"Larry Dighera" wrote in message
On Wed, 3 Jan 2007 16:03:33 -0800, "Aluckyguess" wrote in
The pressure is to high when the engine is first started then when warm
its
to low.
Now I understand. How cold is it when you start? Perhaps you need an
engine heater in the winter. Where are you located. Is the aircraft
hangared?
You said it did this to high when cold and too low when warm syndrome
before the overhaul too?
What grade of break-in oil are you using?
No I have not contatcted Lycoming but I will try.
There's a trouble shooting guide he
http://www.lycoming.textron.com/main...ort/index.html
Old January 4th 07, 02:12 AM posted to rec.aviation.piloting
Aluckyguess
ps.com...
Before and after engine overhaul the oil
tried turning the pressure up but this seems to only make the pressure
go
up when cold. If the temperature outside is real cool the pressure
goes
over 200 psi. The engine builder said its in spec. I think there is a
problem somewhere. I want the oil pressure to run in the green. Does
anybody have any ideas on what could be causing this. I'm afraid its
Sounds like the relief valve is sticking. That'll cause low oil
pressure when hot and high when cold.
Dan
I will ask the mechanic about this. I know they have replaced the oil pump
and a few other things before I bought it.
Old January 4th 07, 04:00 AM posted to rec.aviation.piloting
That is PRECISELY what happened to mine. Oil cooler split on start-up,
unbeknownst to us. Dumped a fair amount of oil right there where we
started, trailed to the run-up area with another puddle there. Gauges
continued to read green/normal until 6 minutes into the flight when we
suddenly had zero oil pressure. Oil temp never went up, probably because
there was never enough oil in there to temp. Less than a minute after
the gauge dropped to zero, it began to buck and shake as the engine
seized, and less than a minute after that, we were down. Thank God we
were over the desert (less than a mile from the intended runway), but
the desert floor is NOT as flat as it looks from 100 or 50 feet. We are
grateful to have walked away with only bruises, but the airplane was
totaled.
I had never heard of an oil cooler failing before this, but since, some
people have said, "oh yeah, they fail sometimes." I also was never
taught to look behind me after taxiing away from start-up or run-up to
check for puddles of oil or fuel.
Shirl
Old January 4th 07, 04:24 AM posted to rec.aviation.piloting
Larry Dighera
On Wed, 03 Jan 2007 21:00:40 -0700, unicate wrote
in :
totaled.
Shirl
That's a lot of good information. Many thanks.
Old January 4th 07, 08:37 AM posted to rec.aviation.piloting
Ron Rosenfeld
On Wed, 3 Jan 2007 14:13:28 -0800, "Aluckyguess" wrote:
I have a Bonanza V35 with a IO 470. Before and after engine overhaul the oil
pressure after the engine warms up goes just into the red. They have tried
turning the pressure up but this seems to only make the pressure go up when
any ideas on what could be causing this. I'm afraid its going to blow the
Thanks
When this was happening to my Lycoming IO360A1A, the problem turned out to
be a leaking nose bearing. Oil temperatures were also running high.
It was diagnosed by measuring differential pressures between the front and
rear of the case.
--ron
Old January 5th 07, 07:10 AM posted to rec.aviation.piloting
Aluckyguess
"Ron Rosenfeld" wrote in message
oil
when
Thanks
rear of the case.
--ron
Was it leaking back into the engine or on to the ground.?
Old January 5th 07, 11:50 AM posted to rec.aviation.piloting
Ron Rosenfeld
oil
when
Thanks
rear of the case.
--ron
There was no oil leaking to the ground.
But I'd be surprised if the problem, in your case, survived an overhaul. I
suppose it could've happened, but ...
--ron
So...about that plane on the treadmill... Ray Piloting 135 December 18th 06 10:30 PM
Jet engines vs. leaf blowers 01-- Zero One Soaring 6 September 8th 05 01:59 AM
High Oil Pressure (was: Low oil pressure, high oil temp?) Thomas Ploch Owning 4 October 5th 04 04:34 AM
Why are TE probes so long? Duane Eisenbeiss Soaring 36 May 9th 04 06:58 AM
Manifold pressure gauge problem Dave Russell Aerobatics 3 January 29th 04 03:46 AM
