My tuppence-worth comments on the goals listed at the bottom of the
linked page: Goals: Raise awareness in the general aviation public of the advantages of the inline twin configuration to drive new product development with regulatory relief in the form of: 1) In regards to pilot licensing, petition FAA to count the number of thrust lines rather than the number of engines. Would allow single engine pilots to fly in-line twins such as the Cessna 337 with just a type checkout like any other new aircraft. This being done to reflect the particular training requied to handle the most serious issue in tradition twin engine aircraft: yaw moment induced by loss of power on one side, especially at low airspeeds. IIRC, inline-twin is a separate category. Just because you're rated to fly a 337 doesn't mean you can strap on an Apache. The feds already recognize the distinction. 2) Petition FAA to allow for longer (2x?) intervals between mandatory service/inspection for aircraft using in-line twin configuration due to robust operation of inline twin configuration. Doesn't make sense. The complexity of a system drives the inspection / MX schedule. The location of the system's components has little to do with its complexity. 3) Petition FAA to allow otherwise compliant twin aircraft with a single line of thrust (but 2 engines) to be part of the new "Sport" aircraft classification. Works fer me. 4) And regarding Sport classification, remove top speed limitation, the stall speed requirement is sufficient; if someone can build a wing with low speed stall characteristic and high top speed, then we'd all like to have it. A wing with those characteristics needs moving parts such as Fowler flaps and slats. Think 727. That's likely to either be so heavy as to outweigh the category, or require such exotic materials as to be unaffordable. |
![]() ----clip---- 4) And regarding Sport classification, remove top speed limitation, the stall speed requirement is sufficient; if someone can build a wing with low speed stall characteristic and high top speed, then we'd all like to have it. A wing with those characteristics needs moving parts such as Fowler flaps and slats. Think 727. That's likely to either be so heavy as to outweigh the category, or require such exotic materials as to be unaffordable. The 727 is the dirtiest bird I ever saw when configured for landing on final approach. I thing they hang everything out except the kitchen sink. G Some 727 history. When the 727 first came out, the final approach speed had been established by test pilots. They were able to transition from the high drag landing configuration and flare properly to make a safe landing without stalling. This (while by the book) approach speed was as low as possible to qualify the bird for landing on some of the short commercial runways. When bird became operational with the Airlines there were a couple of hard landings (crashes) where the bird (and some passengers) received serious damage because the pilots flared and stalled due to high drag from landing configuration. Airlines were about ready to stop flying the bird when someone suggested that the approach speed be increased 3-5 MPH to allow time line pilots to flare and make normal landing. From then on every one knows the success of the 727 for years and years. And another round of hanger flying G Big John One of the landing accidents was at Salt Lake City. High density altitude, etc. Bird fell out of the sky on flare and hit in the over run short of R/W. |
![]() Jay I took a look at your design concept and your web page. It is a fantastic concept but I would really hate to be in it flying somewhere always looking at where I had been instead of where I was going. I took the liberty to copy a couple some things here for the sake of discussion that you say on your web page which I take exception with and almost find offensive to those of us that take pride in the aircraft we built and fly. -------------------------------------- and economics has a direct effect on public saftey bacause: * Expensive up-keep is more likely to be put off. * Engine replacement will be put off long past when it should be. * Used engines and components (no joke) will be used and reused in active aircraft. * More likely that a broken or worn part will try to be repaired instead of replaced as it should be. * Airframe manufacturers are more likely to underpower their aircraft to reduce cost of goods sold, and increase the proportion of the aircraft that they build. ----------------------------------------- I find fault in just about everything you say in the above sentences, I do not believe that any of it is true and to try to sell a concept on the above statements is wrong IMO. I post this here because I would like you to submit any proof you have that the above is true. don't get me wrong I wish you all the luck in the world with your design but lets keep it real. Jerry I liked his concept of design too Jerry. But I think the guy is either a guy who never built an airplane then maintained it or he's just a statistical outlier. Nobody I know who has an experimental flying machine whether it be a helicopter, balloon or airplan takes the short cuts he proposes. I know YOU don't, and I never have. -- Expensive up-keep is too bad, but it is what it is. If you don't do it, you die. --Engine replacement is usually done long before it's needed. When things start to show significant wear, the engine is rebuilt. I've done it, you've done it. --Used parts that are time proven are better than new parts in many cases. Take a CAM. Once a CAM has proved to you it doesn't have some goofy area in it that wears away in the first 1000 hours, you reprofile it and use it again. It's much safer than a new CAM, casted with some new ****ing alloys that have not been run 1000 hours. Same wtih an engine case. Give me one that's been cycled 2000 times and I'll build you an engine where the case won't crack. -- I dont' get the broken part piece. It depends on the part. For christ's sake, I had a broken NAV light the other day. I bought a new one. I don't get his point there at all. If a part is critical and it's busted...and it can't be fixed to new specs, then no homebuilder I know would want to risk his ass on it. You buy a new one, or you fix the bad one to original or better than new specs. -- I don't see this. What albout the Harmon Rocket? The Glassair? The Lancair. Christ. All of them are like flying a Lycoming strapped to your back. What is this underpowered engine ****? This guy is just writing to see his name show up on the screen. I find fault in just about everthing he says too. He's just a big bag of wind like most of the rest of RAH. It always has been and it will always be...because the idiots and the Galactically stupid muther ****ers can post here and act like the real guys who have done it for real and done it for years...guys like you and guys like me. BWB |
David, what you say makes a good deal of sense. You can read about a
fancy-schmancy design in this month's Flying - Pete Garrison finally got his Melmoth II in the air. But even first-time builders with modest ambitions may have certain requirements. Example: I'm looking for a moderately-performing 2-place low-wing wood design such as the Piel Emeradue or Cvjetcovic CA-65, with a folding wing so that the aircraft can be stored off-airport and trailered. Is that so much to ask? The kind souls on the Emerauder list have clued me in about one particular 3-piece-wing design for the Piel. With a couple of hours of hard work, it appears possible to remove & replace the outer wing panels - not what I'm looking for. Perhaps the Cvjetcovic design is more "user-friendly" - at least the outer panels stay attached - but information is hard to come by. However, I've got time to do some more digging - I probably won't be able to even begin building for another couple of years. I frankly doubt that I'll be able to build more than one airplane. I'm 41 now. It's clear that the process takes from 5 to 10 years, especially if you have a family - and I do. Maybe I'll have to settle for a Volksplane in the end. But here at the beginning, I prefer to keep my options open. Corrie David O wrote in message . .. There have been many posts in recent months by people contemplating their own complicated and even radical designs. Reading between the lines, it appears that many of those people have yet to build their first plane. May I kindly suggest that one's first plane should be a time-proved kit or plans-built plane with no major builder modifications. Build it, fly it, and maintain it for several hundred hours. After you've accomplished this, revisit your fancy schmancy dream machine. I expect that by that time, for most people anyway, reality will have dawned. David O -- http://www.AirplaneZone.com -- Oshkosh Bound!!! |
Corrie wrote:
David, what you say makes a good deal of sense. You can read about a fancy-schmancy design in this month's Flying - Pete Garrison finally got his Melmoth II in the air. But even first-time builders with modest ambitions may have certain requirements. Example: I'm looking for a moderately-performing 2-place low-wing wood design such as the Piel Emeradue or Cvjetcovic CA-65, with a folding wing so that the aircraft can be stored off-airport and trailered. Is that so much to ask? The kind souls on the Emerauder list have clued me in about one particular 3-piece-wing design for the Piel. With a couple of hours of hard work, it appears possible to remove & replace the outer wing panels - not what I'm looking for. Perhaps the Cvjetcovic design is more "user-friendly" - at least the outer panels stay attached - but information is hard to come by. However, I've got time to do some more digging - I probably won't be able to even begin building for another couple of years. I frankly doubt that I'll be able to build more than one airplane. I'm 41 now. It's clear that the process takes from 5 to 10 years, especially if you have a family - and I do. Maybe I'll have to settle for a Volksplane in the end. But here at the beginning, I prefer to keep my options open. Corrie David O wrote in message . .. There have been many posts in recent months by people contemplating their own complicated and even radical designs. Reading between the lines, it appears that many of those people have yet to build their first plane. May I kindly suggest that one's first plane should be a time-proved kit or plans-built plane with no major builder modifications. Build it, fly it, and maintain it for several hundred hours. After you've accomplished this, revisit your fancy schmancy dream machine. I expect that by that time, for most people anyway, reality will have dawned. David O -- http://www.AirplaneZone.com -- Oshkosh Bound!!! A couple of things, Corrie? One, I'd hardly refer to Melmoth II as fancy-schmancy. Maybe it's more airplane than most. But there's nothing wrong with that. And two, IIRC, Melmoth (I?) was a first-time origional design - designed, built, and flown by one man - Pete Garrison. Nothing wrong with that, either. But for the likes of most of our gentle readers, dream on. That's what P-51 Syndrome is all about. For you to build something like Melmoth (either) could indeed take a dozen years or more. (Pete? What was it? 6 year?) There's just so much you have to learn how to do, and do well. It would take me a lot longer than that - just to pay for it! It's just not a reasonable thing for most people to do. Let me offer a suggestion. Take five or siz thoushand bucks and Build something a lot simpler. A SINGLE seater. Perhaps like a Volksplane (although I like my parasol a lot better. Go figure) If you are 41, and you want to build an airplane, you maybe better get off your dead a$$ and get started - on something. Even if it's not a P-51... Richard http://home.flash.net/~lamb01/ |
Richard Lamb wrote ...
... get started - on something. And THAT is the fundamental difference between a dream machine and a flying machine. Daniel |
I'd love to. But it's probably going to be at least a year, perhaps
three, before I'm able to *begin* construction on an airplane. Y'see, I have some "home-building" projects queued up ahead of the "homebuilt" project. However, please feel free to explain to my wife why I need an airplane before she gets a garage, or the kids get their own bedrooms. I'll show her the best of them, and post her responses here. Corrie - planning ahead (Daniel) wrote in message . com... Richard Lamb wrote ... ... get started - on something. And THAT is the fundamental difference between a dream machine and a flying machine. Daniel |
On 30 Jul 2003 09:33 AM, Corrie posted the following:
I'd love to. But it's probably going to be at least a year, perhaps three, before I'm able to *begin* construction on an airplane. Y'see, I have some "home-building" projects queued up ahead of the "homebuilt" project. However, please feel free to explain to my wife why I need an airplane before she gets a garage, or the kids get their own bedrooms. I'll show her the best of them, and post her responses here. I can't help you much with the bedrooms issue, but at some point you are going to have to explain to your wife that the garage (henceforth to be known as the "shop") is for building the airplane, and not for storage of automobiles and/or overflow of household items. You might as well start prepping her for the idea, rather than hitting her with it all at once. My own "shop" is not terribly huge, but it works fine for my purposes since the ground transportation sleeps outside. I don't know where you live, but it works for me here in Anchorage, so quitcher bitchin and start building. Though on second thought, I am reminded of a friend of mine, who grew up sleeping on the couch in his parents' living room since his dad wasn't willing to give up the gun room.... ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
Corrie wrote ...
I'd love to. But ... I have some "home-building" projects queued up ahead of the "homebuilt" project. Me too. Floor beams & joists, plumbing, septic, 2 & 1/2 baths, all wiring, new kitchen, 3.5 tons of ceramic tile, roof, dual heating & AC, attic insulation, french doors, brick work.... The plus side of it is that I find a great many new tools and materials are indispensible for plane building. Ooops, I mean homebuilding. "Can't put on new roof without a big air compressor." "Gotta have a big router to duplicate interior trim." "Yes honey, that's a LOT of sandpaper, but it's cheaper that way." "Yes, I need a LONG workbench, it's faster to finish 2 doors at once." "Of course we need a disc/belt sander." "Spraying gives a better finish" "That aluminum? I used it to line up the walls. It's straighter than wood & I'll find another use for it." "The angle grinder? For cutting off nails & rebar." "A random orbit sander is a must to refinsih those cabinets." "My old drill bits were shot." "You need good bolts or we'll end up redoing it in 4 years." "You need a high quality paint mask with this varnish." "You need MEK to clean it before you seal it & 5 gallon pails are much cheaper." The possibilities are endless, but you have to be careful. I'm open to suggestions. Strobe lights to keep kids from falling in the hole for the septic tank might not fly. Daniel |
